I bought a post hole digger from tractor supply for about $600. You can get different size augers and it is bullet proof. Worth every penny.if you need 10" holes you will need a 12" auger. a 3point tractor post hole digger would work nicely
Are you in an open area? A small 2 furrow plow might work for you. Pull the furrow back after placing tree roots.I'm looking at planting a row of bushes. My first inclination was a hand-held auger but that might be a rough go with holes maybe getting to 10". I could use a smaller bit and drill multiple holes and try and combine them into a larger hole but when you are talking something like 50+ holes like that....meh!. Then I started thinking that maybe a tiller for my tractor might work but those only go so deep and I still need to move the dirt out of the ditch. If I had my backhoe(on order) then I guess that would be an easy solution. Other then those options anyone have any other ideas for relatively inexpensive ways to dig these holes? Would a trencher be an option?
I have not read the responses yet but I'm sure folks will recommend an auger. If you dig nice round holes, the plants roots will grow in circles and never break into surrounding soil.I'm looking at planting a row of bushes. My first inclination was a hand-held auger but that might be a rough go with holes maybe getting to 10". I could use a smaller bit and drill multiple holes and try and combine them into a larger hole but when you are talking something like 50+ holes like that....meh!. Then I started thinking that maybe a tiller for my tractor might work but those only go so deep and I still need to move the dirt out of the ditch. If I had my backhoe(on order) then I guess that would be an easy solution. Other then those options anyone have any other ideas for relatively inexpensive ways to dig these holes? Would a trencher be an option?
My wife and I use an Earthquake two-person power auger with an 8-inch bit for landscaping holes. We call it "vertical tilling." For large holes, we bore 2, 3, or 4 adjacent holes, then swivel the auger among them to break down the walls and make a larger hole. Sometimes she'll dump in a bag of composted manure, and we use the auger to mix it with the soil.
A two-person auger is fairly easy to use. We wear ear protectors, but it's no problem hearing one person yell "UP!" when it's time to pull the auger out to clear dirt from the hole. We've bored nearly 200 holes with this auger over the years. More work than sitting on a tractor pulling levers, but definitely doable.
--- Mike
Definition of "expensive"? What is your time worth? 150 feet of "bushes" doesn't sound cheap either. Plants are expensive, IMHO.They are generally expensive even for the cheapo ones and I don't think I can get my hands on one in short order. I'm hoping/needing to get the bushes in the ground sooner than later.
This looks like a nightmare... To plant 150 feet of "bushes" in.How about a picture?
Somebody suggested a middle buster, I was going to suggest a couple passes with a single bottom plow Which I've done for planting hedgerows and shallow cables / pipes, but after looking at your pictures "lots of luck"How about a picture?
I was thinking of trenching the whole thing for the two staggered rows. Not much 'neat' about that other than maybe the outer sides but even then the plan is to be trenched out 2-3 ft from the base. What are your thoughts about panting now? Leave in pots or get them in the ground?I have not read the responses yet but I'm sure folks will recommend an auger. If you dig nice round holes, the plants roots will grow in circles and never break into surrounding soil.
As a landscape contractor I found that empoyees had a hard time grasping that while usually a perfectionist, I did not want nice neet holes. An auger will work well if you let it wobble around and break up the sides.
I like to take several passes with a trencher. Makes ragged holes that support root growth. Remember, Most common cause of tree decline for planted trees is planting too deep!
that's not the exact location of the bushes. The ground has been cleared up more than what you see here and is actually located in a different piece of the property. This is just what I had pictures of to give an idea of the soil type.This looks like a nightmare... To plant 150 feet of "bushes" in.
CT
That's nearly the price of a backhoe. I struggle to to justify spending $400 on a bucket spade for this work but thanks for posing. This would be cool. I've considered renting a walk behind from Home Depot.
This looks like an accident waiting to happen if those are handles at the upper L in picture. I don't want any part of me that close to a rotating auger.
yeah I was going to say some construction companies do rent them but I don't know how it perform in rocky soil thoThat's nearly the price of a backhoe. I struggle to to justify spending $400 on a bucket spade for this work but thanks for posing. This would be cool. I've considered renting a walk behind from Home Depot.
I haven't operate one myself but I know someone who did rent one to plant threes and he said they work really well and super easy to operate... to me you are no closer then a two men auger. Maybe you wouldn't operate that ether and that ok I am just sharing different options for OP.This looks like an accident waiting to happen if those are handles at the upper L in picture. I don't want any part of me that close to a rotating auger.
I use composted leaf mulch in the holes and then a good 3-4" around the base to retain moisture. If you have water at the site, get them in the ground now.FYI. I also have a chipper handy to mulch these bushes once they are in the ground. Should help with the water retention while they get established.
Rent a small trencher..that would it on a short amount of time.I'm looking at planting a row of bushes. My first inclination was a hand-held auger but that might be a rough go with holes maybe getting to 10". I could use a smaller bit and drill multiple holes and try and combine them into a larger hole but when you are talking something like 50+ holes like that....meh!. Then I started thinking that maybe a tiller for my tractor might work but those only go so deep and I still need to move the dirt out of the ditch. If I had my backhoe(on order) then I guess that would be an easy solution. Other then those options anyone have any other ideas for relatively inexpensive ways to dig these holes? Would a trencher be an option?
No water at the site other than 3 50 gallon barrels and the 25 gallons we bring every time we go. We've got some resources in town where we can refill as needed.I use composted leaf mulch in the holes and then a good 3-4" around the base to retain moisture. If you have water at the site, get them in the ground now.
If you don't have water at the site, then hold them and wait until September to install. Your idea of using the bucket and making two trenches is better than by hand. and or rent the trencher from HD then your tractor bucket to make wider if needed.
For a cheaper watering solution a few soaker hoses along the line of trees is easy and fast, or use drip hoses, if you have water at the site.
