Tires Removing loaded tires
/ Removing loaded tires #1
buckeyefarmer
Epic Contributor
MD
Kubota L3940 L5030 MF205-4 BX23
Discovered an issue with rear tire rims on my L3940 cracking at the lugs. . Looks like I can get a new disc for it. Just worried about the weight of removing the tire. I have BH so no problem jacking it up.
/ Removing loaded tires #2
Just keep the tire and rim vertical all all times. Once they start going over, get the heck out of the way as you cannot stop it so just keep it vertical. I will warn you the lug bolts on your Kubota are fine thread and when you put the rim back on. be very careful about making sure the tire and rim are aligned with the bolt holes in the mounting flange so the lug bolts thread in without requiring any assistance until close to bottoming. Very easy to bugger the threads on the bolts and they aren't cheap. I know, been there and did that. Just another reason why my tires aren't loaded and why I run cast centers instead. A loaded tire falling over can and will crush your foot or break your leg.
/ Removing loaded tires #3
Is it a 2 piece wheel? If so, you can just order the center disc. Other wise, the complete rim needs to be replaced. I have seen a a piece of steel welded into the center.
/ Removing loaded tires #4
Just curious, if you keep a B/H on particularly when using the FEL or at least another rear mount implement, why load the rears? Remotely possible loaded rear tire contributed to the crack. Without B/H, yes loaded rears are a must for FEL work but a B/H provides a much more adjustable counterweight than loaded tires particularly when working a hillside. Loaded rear tires with a B/H is at best is overkill IMHO.
/ Removing loaded tires #5
If you get it lifted just a small amount so the tractor weight is off the rim once it's unbolted you can walk it off the studs and roll it to some were to let it stand up.
Just watch the balance of it and keep it standing up straight and they are not too bad to roll around on hard ground.
Only thing is if starts to tilt too much just get out of the way and let it fall,
once they get tipped to far to easily straighten back up they become impossible for one man to handle.
/ Removing loaded tires #6
Discovered an issue with rear tire rims on my L3940 cracking at the lugs. . Looks like I can get a new disc for it. Just worried about the weight of removing the tire. I have BH so no problem jacking it up. View attachment 754795
Theres a guy not too far from you (Lancaster PA) who sells a lot of new & used rims, centers, tires, etc. PM me if you want name/number.
Do you have a 2nd tractor with pallet fork or bale spear? I usually drive the fork right into the center of the rim, then wiggle the tire/rim onto the fork/spear. Then you can carefully curl the fork upward slightly back up slowly and drive it away.
/ Removing loaded tires #7
I'd strongly recommend a bottle jack and safety stands instead of relying on the BH jacks.
Basically you want to take the load off the tire but not lift it off the ground. Roll the tire out and back into place. The bottle jack will give you fine control over the tractor height for getting the lugs in place.
If you have a smooth concrete floor to work from you life will be much easier.
/ Removing loaded tires #8
I disagree but your opinion and mine differ. I don't even own a BH attachment and I've never felt the need for one and none of my tires are loaded either. Why I run cast centers which is an option on all larger Kubota tractors. The cast centers give you the stability without the loaded tires.
/ Removing loaded tires #9
All larger Kubota's have 2 piece wheels and some have 2 piece fronts depending on if the track is adjustable or not. Mine are.
/ Removing loaded tires #10
Lou... Kubota's of that size might have 2 location studs and the rest are screw in fine threaded lug bolts. I say might because neither of mine have them, all screw in bolts in fine thread and I always put them in 'wet', never dry. The fine threaded bolts really like to cross thread into the mating flange. Been there and did that and had to borrow the flange tap from my dealer to chase the threads. Kubota actually has an alignment tool to facilitate the mounting but I've found it just as easy to line up the flange and the rim using bottle jacks under the axle castings. I would never consider using a BH to line the axle flange up. There is no way you could 'modulate' the lift pads on the BH to achieve the alignment required to start the bolts in and have them thread properly.
/ Removing loaded tires #11
Mine are a lot smaller, but that's what I did. Just enough off the ground to relieve the weight, then wiggle, walk and roll.
BH is kind of in the way to do that when I have it on, so I used a floor jack, then blocked.
Second tractor or other machine would make it a whole lot easier. The big tires are too heavy to handle, even if not loaded.
/ Removing loaded tires #12
The usual cause of stress cracks around the mounting bolts is, the bolts have backed out and the rim center is flexing against the mounting flange. I check the prevailing torque on mine regularly. Usually you can hear it as a popping sound, but sometimes not. I might add that once you dismount and remount the wheel you need to torque them to the value in your owners manual and then recheck them once again after a few hours use. In my case the prevailing torque is 175 foot pounds but yours will be different and probably less.
Just like a car rim, you always recheck the torque on the lug nuts after driving it a few miles.
A competent welder can weld the cracks but I'd recommend a new center instead.
/ Removing loaded tires #13
Looking at the pictures his rims have two studs with nuts and the others are lug bolts.
I utterly detest these manufactures that mount a wheel with lug bolts only.
Every time I have to work on one of those (like my wifes little jeep) or (my brothers old WD) I always get a couple of long bolts with the proper threads, cut the heads off and then put a screwdriver slot in the cut end and bevel it a bit.
Then I have stud to use to line up a wheel makes things so much easier.
My vehicles and equipment have a silver sheen in many places almost every threaded fastener or slip fit gets never-seize on it.
/ Removing loaded tires #14
I very rarely dismount anyway and if I do, I call my farm tire guy and he does it with his truck mount crane. I don't like handling large ag tires in the first place. Leave that up to the young bucks.
/ Removing loaded tires #15
Our tire guys are busy and high priced, between brothers and nephews and other tractors and loaders we do a lot of ours ourselfs.
Most of the tires on the farm are dry and depending on the issue we can break a tire down on the tractor and install a plug patch and or boot if needed and be back working in a few hours. Usually we will swap tractors around to get the priority work done then do the needed repairs in the next day or two and get it back in service. The few liquid filled tires it's a toss up if we do them or call the tires service.
Edit added this;
We seldom take a tire clear of the rim and any rear tractor tire is usually done on the tractor.
The smaller 2wd fronts get removed and often taken to town for repair on tire machines.
/ Removing loaded tires #16
Just to emphasize the previous posters... Don't rely on hydraulics (Jacks or backhoe) to hold the tractor. Always use stands or (my preferred) wood blocking. Especially when you're wiggling or manhandling heavy parts on or off the tractor. A falling Tire is one disaster, a falling tractor is several disasters at once. :eek:
/ Removing loaded tires #17
the days of my wrestling loaded rears are over. i hire a mobile tractor tire service to do the job on site. my rear tires are quite large. good luck & follow the above safety recommendations
Yes, it’s the 2 piece. Just worried about the weight and keeping the tire upright.
I was thinking of a frame on a pallet to strap the tire to, and then using pallet Jack to finely lift the tire off the 2 studs.
/ Removing loaded tires #19
If you have a come along and a beam overhead wrap the cable or strap around the wheel and put enough tension to hold upright then use the pallet jack to lift a bit and roll back. You don't need a lot of clearance - just a few " off the studs.
/ Removing loaded tires #20
Just went through this experience in late June. Blow baler tire. She went to the ground in about 1 minute. Took 3 bottle jacks on aluminum plates and a truckload of blocks.
Took a couple days. All done in the rain and mud, of course.
Challenger 35/45/55 Parts and Operation Manuals (A63117)
Challenger...
12,000 GAL FLAT BOTTOM ALUMINUM STORAGE TANK (A63291)
12,000 GAL FLAT...
Abaco Machines DVL500 Vacuum Lifter (A61573)
Abaco Machines...
2005 Sterling Acterra Tender Truck (A63688)
2005 Sterling...
2006 International 4200 2,000 Gallon Water Truck (A61573)
2006 International...
2013 International 4300 Bucket Truck 55' (A62613)
2013 International...
