WR Long Install Need Brush Guard
/ WR Long Install Need Brush Guard #1
Username Taken
S Florida Winter/Michigan Summer
Kioti CX2510 HST
My Grapple from EA arrived last week and I'm in the process of the 3rd function installation. Mostly by myself. Got the main valve on so far and came close to using bad language when putting on the grapple valve on the loader's torque tube. The bracket from WR Long doesn't fit the two pre-installed (I'm gonna call them heli-coils but that can't be right) on the cover for the lines across the torque tube. Not even close. Drilled it out some and it still won't fit. PITD. Hammered one bolt (one only) down with my impact and walked away. Might get somebody to spot-weld it on for me but it's pretty solid for now. I think.
Then came the brush guard. Went to trial-fit the hoses onto the grapple valve and you can't get them by the grill guard. Had to remove that.
The point of this is not to knock anybody because I know it must be tough to keep up with all the variations in all the tractors but if this is 'custom' I really don't want to see something that isn't.
Question: I'm looking to replace the OEM 'brush guard'. Opinions? Cost matters, Thanks
/ WR Long Install Need Brush Guard #2
A picture would sure help your situation. This is the way I had a local welding shop mod my OEM brush guard/grill guard.
/ WR Long Install Need Brush Guard #3
Odd that the 3rd function would interfere with the grille guard; could you post up some pictures?
/ WR Long Install Need Brush Guard #4
My thoughts - something may not be going quite right. Here are two more pics of how the dealer installed the WR Long 3rd function valve, the hose routing and the grapple itself. The valve is mounted on the FEL vertical member, down low. The rubber hydraulic hosing is routed out the FEL arm - on the inside of the arm( bottom pic ).
I'm having a retired professional mechanic stop by sometime today -- I think. Never know with him :) 🍺 But he made his living working on Farm Machinery. We shall see.
I'm a little embarrassed to tell you that -- I don't really know how to post pictures to the forum. I could learn. I've done it in the past on other forums but I do it so seldom, I've forgotten. my bad
The bulkhead bracket WR Long sent me is kinda weird. It can only go one way (angled toward the tractor about 30 degrees) and; the hoses from EA (on the grapple) have about 6 inches of metal reinforcement that you just can't bend around the top part of the brush guard to get it to hook to the quick-connect. The bracket needs to be on the right ('passenger') side and the QC needs to be pointed upwards so that gives you exactly one way to attach it to the line cover across the torque tube.
Plus, the holes in the bracket don't match up to the pre-drilled and helicoiled (?) -- It's not really, it's drilled with a 12mm ID nut spot-welded on the back. Note; Kioti seems to delight in using metric sizes that won't cross-match to any SAE tools. I think it's the kimchee.
Once I get the seat off -- It weighs about 80 lbs and I just am not as strong as I used to be, for me it's a 2-man job -- I'll proceed and let you know. No way I'm letting my wife help with that seat. Cute ones are hard to find :).
I think every one of these things is different. The bulkhead bracket doesn't seem to be made for my tractor. Not sure any of them are specific but you'd think so. I guess there's just so many out there.
If this ia giving you a headache, think what it's doing to me.
/ WR Long Install Need Brush Guard #6
So...... how is your project going???
/ WR Long Install Need Brush Guard #7
I wouldn't use a grapple without an adequate brush guard.
Posting photos is pretty self explanatory if you follow the prompts after clicking the Attach File box below your post.
/ WR Long Install Need Brush Guard #8
Once again I was just lucky. About the time I bought my grapple - there was a post about somebody "holing" their radiator. They had pallet forks - not a grapple. I took it to heart and immediately had my grill guard modified. I seldom work with much brush. But it only takes once.
Regarding the posting of pictures. Once you get the steps figured out - it goes pretty easy. I ALWAYS have to resize anything I post. My little camera takes 3 to 5 MB pics. My large camera goes 12 to 15 MB. I have a fairly basic software package that makes resizing easy.
Thank you for your concern but my grapple and hoses are on, the 'brush guard' is off and I don't want to go through the hassle of re-attaching the 'bumper' (or whatever they call it) at this point.
Here's a pic of a cab model --
Can you see how the 'bumper' has a decidedly forward lean to it? Then look at the protective cover that goes over the lines on the torque tube. Can you see the 2 pre-drilled and tapped holes in the cover? That's where WRLong made their bracket that holds the grapple's hoses.... That's where it fits.
if you mount the bracket, you can't get the hoses to connect because the 'bumper' forces you to make a bend that you just can't make.
So I had to remove the 'bumper' and here's what it looks like without the bumper. Try to imagine the grapple on over that. I'm trying to figure a way to fabricate or mount a true brush guard that doesn't use the OEM bumper. Thanks for taking the time to try to help me.
/ WR Long Install Need Brush Guard #11
"Rivet Nuts" might allow you to mount the bracket where you want to on your torque tube of your loader.
I am not sure what your grill guard issue is, but I would one.
/ WR Long Install Need Brush Guard #12
Confused? The factory guard is a good, easy base to build a brush guard. Added HD bumper and tow/tie-down hooks and ring.
You certainly can build from totally new stock. Would cost several times more.
/ WR Long Install Need Brush Guard #13
I'm guessing that what you call the "bumper" has a forward lean in order for the hood to clear it when you raise your hood?
The coupler mount that came with the diverter "kit" that I bought from another company didn't fit my loader tube very well either. I fabricated another mount using a piece of angle to locate the coupler where it needed to be.
If you can find a way to rework the factory bumper to add expanded metal or mesh for grill protection, even if it means reworking the coupler mount, that may be less work overall than having to rework the factory bumper.
The rounded contours the tractor makers are using for styling these days makes it a pain to fabricate anything that actually fits the tractors these days.
Probably not designed to fit the less common brands of tractors
I read somewhere that the market share for under-50HP tractors goes, 1) Kubota, 2) Deere, 3) Kioti with a 20% market share in their power segment
Don't know how true it is but I believe it. And, to me it seems that the majority of grapple sales would be to people operating tractors with under 70HP.
It would be nice if the independent grapple manufacturers would get together with the #1 3rd function valve maker and make some nice custom brackets. Although I realize it would be a major PITA, it would save customers a lot of aggravation.
I almost went with a Kioti grapple for this very reason even though the EA grapple is touted (deservedly so) as the best in the business. But Kioti hasn't gotten the bugs out just yet and their supply chain is iffy right now. So, EA and WRLong it is.
Not dissin' either one, just pointing out it's kind of a PITD to install, remove, re-install, re-remove, re-reinstall, fabricate, reinvent the wheel, etc. Plus, I'm lazy and want someone else to do the work for me :)
@Username Taken what bugs in the grapple are you speaking of? I've got one, quite happy with it thus far, paired with a WR Long 3rd function.
I like mine as well. I'm talking about the install. It was a bear. And I had a 20-year professional Farm Machine mechanic helping out. Well, sorta. He got frustrated and drank beer most of the time. Had a couple other guys help out as well.
The install was a female dog. Plus, the OEM bumper had to be removed in order to get the grapple hoses to fit where they had me mount the bracket for them. Had I known what I'd run into before I started, it would have been better. It's not like there aren't any CX2510 Kioti's with 3rd functions out there.
Here's a copy of the instructions:
I'll figure out a brush guard for it eventually. probably
Thinking about shimming out the bottom 2 bolts in order to reduce the angle. You don't wanna know. ;)
/ WR Long Install Need Brush Guard #20
Look closely at the picture - post#2. The top of the grill guard swings forward to allow the hood to open.
The top bolt locks the grill guard in the upright position. The bottom bolt is what the top of the guard swing on. The "swinging grill guard" is OEM on my M6040.
Invoices (A63116)
Invoices (A63116)
2025 Kubota SVL75-3HFWCC High Flow Cab Track Loader - 70 hours
2025 Kubota...
2025 Ligchine Spiderscreed Concrete Screed (A59228)
2025 Ligchine...
2006 Trail King TKT14U-202 9 Ton Tilt Deck T/A Equipment Trailer (A61568)
2006 Trail King...
2017 International Prostar 122 Day Cab (A62613)
2017 International...
2014 Timpte Hopper Bottom (A63118)
2014 Timpte Hopper...
