Kioti RX7320 No Tailights
/ Kioti RX7320 No Tailights
Sure. Only problem might be the flashers dont flash at the correct speed. Depends on if your flasher is electronic or old school bi-metal. Easy enough fix though.
I bought these to replace the BA15S (1156) bulbs. Haven't replaced the others yet.
Well the 2 pack of BAU15S ambers arrived today and sure enough the flashers blink same speed as if a bulb is burnt out. So what options does that leave, back to incandescent again ?? Surely they has to be one type of LED that will work in this application
/ Kioti RX7320 No Tailights #22
Track down your flasher and see what it is. If it isn't an 'Electronic', swap it out for one.
Why the LEDs hyper flash
This one is a 2-pin just for an example, but they have other versions if needed.
You can also use a 'load resistor' but easier to swap the flasher, unless you dont actually have a flasher.
I’ll finish reading your post soon as I have time to sit down but what a spot they had the flasher buried in. Is this what you or is called an electronic flasher ??
Not sure what the letters represent or why anything more than 2 pins are required for blinkers…hmmmm plus this OEM flasher has a metal lug where it bolts up underneath the dash
/ Kioti RX7320 No Tailights #25
Yep. Replace that with an electronic one made for leds.
B is Pos+, E is Neg- and L is the output to the leds..
Well hopefully this will do the trick because I just ordered it. Has a potentiometer on it to adjust speed.
/ Kioti RX7320 No Tailights #27
That should do. If the pinouts are different you can use the wire pigtails to solve that.
Can’t Thank you enough for all your help. Flasher is supposed to be here Saturday so fingers crossed it’ll solve things. I’ll let you know. Tnx again. Ernie
/ Kioti RX7320 No Tailights #30
No problem. Glad to help. At least no one will be able to say they didnt see your lights :)
Well the LED flasher arrived and sure enough the positive and negative prongs coming off the flasher were opposite to the OEM but as you mentioned to use the supplied wires it worked like a charm.
I also ordered a cell phone charger and installed it into the plastic dash and have 2 LED lights to face forward off the ROPS and one facing rearward which will be so handy. I see there’s a fuse block at the firewall on the right side with spare 15amp locations plus also another fuse panel to the left side of the seat. Not sure what the best location is or even how to go about running wires into fuse panels. I think I’ll use the OEM harness in behind the seat to run the LED lights.
