Kioti RX7320 No Tailights
   / Kioti RX7320 No Tailights
Sure. Only problem might be the flashers dont flash at the correct speed. Depends on if your flasher is electronic or old school bi-metal. Easy enough fix though.
I bought these to replace the BA15S (1156) bulbs. Haven't replaced the others yet.
Well the 2 pack of BAU15S ambers arrived today and sure enough the flashers blink same speed as if a bulb is burnt out. So what options does that leave, back to incandescent again ?? Surely they has to be one type of LED that will work in this application
   / Kioti RX7320 No Tailights #22
Track down your flasher and see what it is. If it isn't an 'Electronic', swap it out for one.
Why the LEDs hyper flash
This one is a 2-pin just for an example, but they have other versions if needed.
You can also use a 'load resistor' but easier to swap the flasher, unless you dont actually have a flasher.
I’ll finish reading your post soon as I have time to sit down but what a spot they had the flasher buried in. Is this what you or is called an electronic flasher ??
Not sure what the letters represent or why anything more than 2 pins are required for blinkers…hmmmm plus this OEM flasher has a metal lug where it bolts up underneath the dash
   / Kioti RX7320 No Tailights #25
Yep. Replace that with an electronic one made for leds.
B is Pos+, E is Neg- and L is the output to the leds..
Well hopefully this will do the trick because I just ordered it. Has a potentiometer on it to adjust speed.
   / Kioti RX7320 No Tailights #27
That should do. If the pinouts are different you can use the wire pigtails to solve that.
Can’t Thank you enough for all your help. Flasher is supposed to be here Saturday so fingers crossed it’ll solve things. I’ll let you know. Tnx again. Ernie
   / Kioti RX7320 No Tailights #30
No problem. Glad to help. At least no one will be able to say they didnt see your lights :)
2006 TRANSCRAFT 48X102 SPREAD AXLE FLATBED (A58214)
2006 TRANSCRAFT...
MILWAUKEE & DEWALT SAWZALL (A58374)
MILWAUKEE & DEWALT...
2020 Ford F-250 4X4 Crew Cab Pickup Truck (A55973)
2020 Ford F-250...
2002 Frieghtliner Pressure Digger Truck (A55973)
2002 Frieghtliner...
GRID SHAPED BUCKET FOR MINI EXCAVATOR (A58214)
GRID SHAPED BUCKET...
JOHN DEERE 12' BOX SCRAPE (A52708)
JOHN DEERE 12' BOX...
