Can a propane tank be repurposed?
/ Can a propane tank be repurposed? #121
I will admit to my total ignorance when it comes to pressurized storage containers and could use some help. I have had no luck trying to find answers to most of my questions on the net.
Here is an idea I have had for years and wondering if it can be safely pulled off. The goal would be to have a pressurized utility sprayer that I can carry around with me for spraying roundup etc. I am tired of pumping my 2-3 gallon sprayer every several minutes. I have a 5-gallon backpack model but once full I have a hard time getting it on/off by myself and it hurts my lower back as I walk around my 6 acres. I like the idea of a smaller, pressurized, hand held 2-3 gallon sprayer. I know they make battery powered units but I like to experiment & was wondering if an empty propane tank be repurposed (refilled with air) to provide the 10 PSI that I need? I do not think the high pressure paint-ball tanks is what I want as they are thousands of PSI and expensive.
I have long wanted to take an empty (small torch sized) 1-pound propane tank and refill it with air via my shop air compressor and try out my idea. I would attach a regulator to knock down the high pressure air down to ~10 PSI.
My 1st & most important question is what PSI can these small 1-pound propane tanks hold safely? The last thing I would want is to set my shop compressor too high & have a catastrophic failure due to too much pressure while refilling it. The next question would be where can I get a low-pressure regulator with a gauge so I can dial in the PSI into my 2-3 gallon sprayer.
/ Can a propane tank be repurposed? #122
I had a small fimco. Replaced tank. Broke again. Then the pump went. Reused the trailer and hose, got two 5 gallon buckets and got a cheap pump on amazon. I'm happy.
Neat. Reminds me of a system I made up about 20 years ago when I had a traditional garden tractor with steering wheel. I pulled a small garden utility trailer behind it and put a 55-gallon drum inside it up towards the front to keep the weight forward. I then dropped a garden hose down the drum and connected the other end to a sure-flo pump. The output of the pump went to a 8' long garden hose where I connected a hand spray nozzle. The kind you have to grip ur hand to pull the trigger on the spray nozzle. If you released hand pressure no water would come out the nozzle. Anyway, connected up the sureflo to the tractor battery, would dump a full package of Miracle Grow into the 55-gal of water and I could ride all over my 6 acres spraying fertilizer or water onto baby fruit trees or flower beds etc. Still got the system.....made it for the cost of the pump alone.
/ Can a propane tank be repurposed? #124
Does that guy down in Bluffton with the lawn tractor graveyard sell complete, running tractors?
You got me there. Been there a few times but never about that so I would not know. Can be hard to get a hold of and meet up at times from what I rem.
/ Can a propane tank be repurposed? #126
That’s what I’ve been reading as well. I’d like to get ahold of a round single blade deck from a Snapper or similar type riding mower to convert to a tow-behind leaf pickup unit. It’s a bit of a drive for me, but we’d make a day of it in Ft. Wayne, or take a walk at Chain O Lakes SP.
/ Can a propane tank be repurposed? #127
yah no problem. HOWEVER the flammable hydrocarbons will have embedded themselves in the first mole layer of the steel inside the tank. And of course, the O2 in the pressurized air would serve as a marvelous accelerant.
So you will have created a very good potential explosive device.
BUT there is a way.
Yank the valve, Fill it with water. Let it set a while, drain it and lay an unlit fire, put the tank in the wood pile for the fire with the port un blocked and light the fire and walk away.
Come back in an hour and feed the fire. You want to burn the paint off the cylinder getting the whole thing damn hot.
The fire will burn off the remnant hydrocarbons. And you can repaint it and use it however you please.
/ Can a propane tank be repurposed? #128
Won't the heat weaken the steel?
So here is an update......the Scotts, 3-gallon battery powered sprayer with it's own little dolly is garbage and is being returned.
The small pump operates off of a small integrated internal 9 V battery. When I filled the tank with water to try it out the pressure was piss-poor and barely shot the spray very far. Anemic would be a good analogy. The 3 adjustable nozzle settings is a great idea and the stream setting allowed the water to hit 10' feet away but the head had an internal leak and had a strong drip 100% of the time. This would be disastrous walking with it across the lawn etc with roundup. The fan spray and cone spray settings were too little volume spraying out.
In short the concept was nice, it was built well but the pump could have been made much stronger and the DC power system changed to a beefier 12 VDC or 18 VDC system.
I am not in the process of trying out my own pump idea....fingers crossed.
/ Can a propane tank be repurposed? #131
Mentioning again, probably for the last time. Your initial concept of a small pressure vessel is good but choice of vessel would be vastly improved by using a 2 liter plastic pop bottle, light, durable, safe, free and would last forever at 60 or 70 psi and could be refilled many times to 100 psi and after a couple cycles, unscrew the cap and put a new bottle on in a few seconds.
Scrhader valve or other port of choice would be installed through the cap. Hot glue works great on the cap also.
/ Can a propane tank be repurposed? #132
no. Steel is made with heat; a very great deal more heat than a simple bonfire can generate.
As an aside, you know about young's modulus of elasticity - - yes? It's a mathematical way to represent the tendency of certain materials (esp steels) to accept nondeforming stress and then deforming stresses and nonrecoverable deformation; E.G. Bend it a little it springs back, bend it more it springs back some but can be straightened, Bend it a lot and it can't spring back and it is structurally compromised and cannot be re straightened without compromising the strength of the material further still.
If you heat the damaged steel (damaged from having bent it too much) to the critical temperature and soak it for a little at temp the crystalline structure can realign and be as good as new. And while at that temp you can reform it to any shape desired and it will be as good as new. If these things were not so blacksmithing could have never existed.
/ Can a propane tank be repurposed? #134
Witnessed deformed steel at two plant fires.
One at a machine shop where the mezzanine engineering office caught fire on a weekend and spread to the roof structure…
The fire melted all the aluminum covers including the aluminum on the Bridgeport’s and the steel gantry crane looked like spaghetti.
The second was at the Pacific Oxygen Plant where a leaking acetylene cylinder caught fire in the open yard…
The cylinders were launching like rockets and peeled like bananas…
I guess a third was at a ink plant where large drums on pallets shot hundreds of feet into the sky…
I needed to put a new ring gear on my car flywheel and heated it in the fireplace…
Years later the gear is going bad exactly where I heated it… all I can think of is the heating altered the steel?
/ Can a propane tank be repurposed? #135
02 ... close but no cigar.
Heat and temperature are related but different. Remember TTT tables? It is temperature, not heat that is critical in tempering steel.
/ Can a propane tank be repurposed? #136
I guess its time to wade back into this thread since Istillcare has made a point that I was going to but chose not to since I thought this thread had beaten the topic of turning used propane tanks into potential bombs long ago.
Besides the point Istillcare makes, the manufacture of steel is under strictly controlled conditions of time at temp, uniformity of temp, ramp up and ramp down time, and atmosphere ( gases, inert and others ).
Throwing a propane bottle into wood fire has the potential to non uniformly case harden some portions of the shell and weld seam due to contact with the charcoal in the fire and make those areas more brittle.
I imagine there is a seal or seals within the valve that would be heat damaged.
Empty propane propane bottles make good range targets and flotation devices for homemade rafts or can be upcycled into homemade scraper blades like Mazzbob's work.
/ Can a propane tank be repurposed? #139
I have made between a dozen and maybe 20 HOBO stoves out of 20# tanks.. I give them away to friends and family...
I got the tanks from the local propane dealer with the valve taken out.. The valves recycle metal for good money.. The steel, not so much.. Once the valve is out if they sit upside down in the sun for a day or 2, no problems with gas fumes... I cut the tops off with a saws all as I don't have a torch or cut off grinder set up...
/ Can a propane tank be repurposed? #140
Appreciate the idea......would be fine but this is not for spraying hundreds of feet of fence lines or tree lines etc.....way too much close in spraying that must be done on foot.
Why reinvent the wheel. This is just one option and there are many sizes, brands and designs to choose from and if needed you can install a longer hose. If you don.t want to install it on an atv or tractor you can use lawn cart for it or even a kids wagon. If you did manage to find a way to make the 1lb propane tank work, you wouldn't get much spraying done before losing pressure and would be constantly changing out cylinders. You would be better off staying with a handheld pump up sprayer
Or you could try one of these and install some sort of spray nozzle on it. They are simple to refill and are pressureised with a simple air chuck you would use for a tire
2020 CATERPILLAR 140 MOTORGRADER (A63276)
2020 CATERPILLAR...
Kubota V3300-T-E2BG Turbo Diesel Engine - 3.3L - Pump Takeout - Tier 2 (A63689)
Kubota...
2015 Polaris Slingshot Motorcycle, VIN # 57XAASFAXF5104933 (A65563)
2015 Polaris...
2019 ALLMAND LIGHT PLANT (A65643)
2019 ALLMAND LIGHT...
275 Gallon Cage Tanks, Koser Safe, with 2" outlet (A62679)
275 Gallon Cage...
2023 JOHN DEERE 550P LGP CRAWLER DOZER (A64279)
2023 JOHN DEERE...
