Can a propane tank be repurposed?
/ Can a propane tank be repurposed? #102
I bought a 2 G. sprayer from Ortho with a battery operated pump that looks identical to the Scotts sprayer. I bet it will work great for you.
I bungee corded mine to a home made 2 wheel cart. I really like it, AND
it is much easier to move around the yard.
/ Can a propane tank be repurposed? #103
I would expect that it is very similar as they are both filled with liquid propane and then we draw the vapors off with the valve at the top.
A few years ago it was common to refill the small tanks from a 20#, you had to invert the 20# to get liquid to transfer to the little tank.
Otherwise it had very little volume.
The pressure in a 1 lb. Propane tank is the same as a 20 lb. , or a 200 lb. Tank. The pressure of propane vapor is a function of the temperature only.
I would recommend against using any tank under pressure without a safety relief valve.
/ Can a propane tank be repurposed? #105
I will admit to my total ignorance when it comes to pressurized storage containers and could use some help. I have had no luck trying to find answers to most of my questions on the net.
Here is an idea I have had for years and wondering if it can be safely pulled off. The goal would be to have a pressurized utility sprayer that I can carry around with me for spraying roundup etc. I am tired of pumping my 2-3 gallon sprayer every several minutes. I have a 5-gallon backpack model but once full I have a hard time getting it on/off by myself and it hurts my lower back as I walk around my 6 acres. I like the idea of a smaller, pressurized, hand held 2-3 gallon sprayer. I know they make battery powered units but I like to experiment & was wondering if an empty propane tank be repurposed (refilled with air) to provide the 10 PSI that I need? I do not think the high pressure paint-ball tanks is what I want as they are thousands of PSI and expensive.
I have long wanted to take an empty (small torch sized) 1-pound propane tank and refill it with air via my shop air compressor and try out my idea. I would attach a regulator to knock down the high pressure air down to ~10 PSI.
My 1st & most important question is what PSI can these small 1-pound propane tanks hold safely? The last thing I would want is to set my shop compressor too high & have a catastrophic failure due to too much pressure while refilling it. The next question would be where can I get a low-pressure regulator with a gauge so I can dial in the PSI into my 2-3 gallon sprayer.
IMO just the weight of an empty steel tank would negate the trouble of pumping up a regular sprayer
/ Can a propane tank be repurposed? #106
Propane has an interesting temperature vs. pressure relationship. The pressure is not a function of tank size. At 110 deg F it's vapor pressure is 200psi.
Seems like a simpler solution would be to install a Schrader valve on your spray tank get something portable like this to carry along...
/ Can a propane tank be repurposed? #107
Purchased a 3 gallon 18 volt battery powered sprayer and have used it for 3 years and very [pleased with it Covers a decent range for spray pattern and this will accept Black & Decker replacement or back up batteries. Would purchase again. Has shoulder strap, but I normally just pack it around by the handle as I spray. Used on a acre plus with hills and a ditch thru the center. Rest of yard & ground is either mowed and baled. CDZ
The local branch of the Maine Forest Service has attached Dewalt power sprayers to their backpack Indian tanks for fighting fires. They say that the water atomizes better, so they can cover more ground with a tank. I believe that it's something they saw while helping fight fires out west.
/ Can a propane tank be repurposed? #108
Just make sure you get all the propane out or you have created a bomb to wear around.
This looks awesome........excellent idea. Even though I have a Scotts unit on the way I am going to get this just to play with (rem I like to experiment) I just need a regulator so it can stay on and not over charge the 2-3 gallon container to more than about 15 PSI. Thanks !
/ Can a propane tank be repurposed? #110
Not sure how it would be done, but have seen other propane tanks used for different purposes.
Experiment and set one up at a "safe" distance with a long pressure hose and see if your shop compressor can cause it to burst. I doubt you can burst it, but would be worth knowing that for sure.
2006 Dodge Ram Pickup (A56858)
2006 Dodge Ram...
2017 CAT 315F LCR EXCAVATOR (A58214)
2017 CAT 315F LCR...
207281 (A52708)
207281 (A52708)
UNKNOWN  20 FLATBED GOOSENECK (A58216)
UNKNOWN 20...
2020 FREIGHTLINER CASCADIA 126 6X4 T/A SLEEPER TRUCK TRACTOR (A59906)
2020 FREIGHTLINER...
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A60460)
2019 Freightliner...
