SmallChange
- Joined
- Apr 19, 2019
- Messages
- 765
- Tractor
- New Holland WM25 with 200LC front end loader, filled R4 tires 43X16.00-20 and 25X8.50-14 (had a Kubota B6200D with dozer and R1 tires)
It's been kind of a pain keeping my tractor plus bucket plus pallet forks in the barn where they're protected. How do I fit it all? Which one do I leave on the tractor? How much going back and forth does it take to swap attachments? How hard is it to shift things around to make them accessible to the skid type mount?
I just hit on a solution. My pallet forks also have three round mount points, for bale spears I think. Two of them are down low on the frame and accept 1-1/4" attachments. I just bought two 1-1/4" round bars 24" long, and slip them into the holes so they stick out the same way the tines do. With the bucket on the tractor, I approach the pallet forks from the fork side (the opposite of like I'm mounting them). I put the bucket under the round bars, and then can lift the fork assembly, with the tines reaching back toward my front wheels (though they don't get all the way there). Now my tractor plus both attachments is a compact enough unit to fit into the barn bay. It's very easy to pull out of the bay and place the forks someplace out of the way before working with the bucket. And, it's pretty easy to pull out, lay the forks down, place the bucket someplace out of the way, drive around and attach the forks, and work with the forks.
Solved!
Solved!
