Advice required please pto problem
/ Advice required please pto problem #1
Martin Barrow
New holland 5635
Hi all I have a new holland 5635 75hp aprox 35 years old only done 1900 hours
The problem I have is when using the pto the gear selector keeps sipping out knocking pto off
This happens when using small tedder,sprayer etc
Thanks for any advice
Martin
/ Advice required please pto problem #2
Do you mean the pro is turning off, or that the pro shaft from the implement is physically becoming detached from the tractor?
/ Advice required please pto problem #3
Is the gear selector a manual selector? Could be the linkage if it is. I'm no pro but thought I'd ask.
The pto keeps disengageing so you have to stop clutch put back in gear and start over again
/ Advice required please pto problem #5
You're not giving us a lot to go on.
If a lever is physically moving, there may be some part of the linkage that's worn or out of adjustment and tying it off with a shock cord or strap could help diagnose that.
If a lever is not physically moving, you may have issues inside the transmission.
4 Shelf Rolling Cart 6ft x 3ft (A61166)
4 Shelf Rolling...
UNUSED KUBOTA M3860 BRUSH GUARD (A62130)
UNUSED KUBOTA...
John Deere Decorative Metal Sign (A61569)
John Deere...
UNUSED RAYTREE RMA42 HYD AUGER (A62131)
UNUSED RAYTREE...
LOAD OUT AND SHIPPING (A61165)
LOAD OUT AND...
New/Unused 2 Post Car Lift (A61166)
New/Unused 2 Post...
