Can a propane tank be repurposed?
/ Can a propane tank be repurposed? #21
How about, put a valve stem on your tank of choice and recharge it with a small hand held air compressor. Most of those have a built in gage and are battery operated.
/ Can a propane tank be repurposed? #22
According to the national standards publication NFPA58, a propane tank with 20 pounds (5 Gal) of gas at 70°F would have a pressure of 145 psi; at 90°F
Actually doesn't matter the size. Any time any quantity of liquid propane is present at 90°F the pressure will be about 145 PSI. Increase the pressure and some of the gas will go back into liquid dropping the pressure. Decrease the pressure and some of the liquid will boil into gas restoring the pressure.
/ Can a propane tank be repurposed? #23
All this worry yet how many put 120 PSI in a 50 year old portable air tank? Who changes their air compressor tank every 10 years? The stresses are same, just air is not flammable.
The 12 year (not 10) inspection regulation originates with DOT. "A propane tank which is transported." It can be reinspected for another 5 years. Many places that fill 20# propane bottles will not inspect, Costco for example. When 20# bottles cost $20 it used to cost $10 for an inspection. Haven't found a propane shop that will inspect since the COVID insanity.
Stationary propane tanks are supposed to be checked when filled, but the buried tanks are pretty hard to check for anything but leaks.
/ Can a propane tank be repurposed? #24
Point was that folks are worried about leaks and inspections. Well we are talking AIR not propane. I understand those requirements for transporting propane but a flushed propane tank with air under pressure is not the same. Same folk that worry will dump 120 PSI+ into a tank older than they are with out a thought. I have one older than me, works great no reason to retire it after 60+ years.
/ Can a propane tank be repurposed? #25
I will admit to my total ignorance when it comes to pressurized storage containers and could use some help. I have had no luck trying to find answers to most of my questions on the net.
Here is an idea I have had for years and wondering if it can be safely pulled off. The goal would be to have a pressurized utility sprayer that I can carry around with me for spraying roundup etc. I am tired of pumping my 2-3 gallon sprayer every several minutes. I have a 5-gallon backpack model but once full I have a hard time getting it on/off by myself and it hurts my lower back as I walk around my 6 acres. I like the idea of a smaller, pressurized, hand held 2-3 gallon sprayer. I know they make battery powered units but I like to experiment & was wondering if an empty propane tank be repurposed (refilled with air) to provide the 10 PSI that I need? I do not think the high pressure paint-ball tanks is what I want as they are thousands of PSI and expensive.
I have long wanted to take an empty (small torch sized) 1-pound propane tank and refill it with air via my shop air compressor and try out my idea. I would attach a regulator to knock down the high pressure air down to ~10 PSI.
My 1st & most important question is what PSI can these small 1-pound propane tanks hold safely? The last thing I would want is to set my shop compressor too high & have a catastrophic failure due to too much pressure while refilling it. The next question would be where can I get a low-pressure regulator with a gauge so I can dial in the PSI into my 2-3 gallon sprayer.
Be safe and buy one of these. Strap it to your bucket, pallet forks, or 3ph mounted carryall. Buy a deep cycle battery and you’re good to go.
/ Can a propane tank be repurposed? #27
Doubt that it's a recommended use, but last week I used a DeWalt 20V pressure washer to spray Liquid Sevin where I couldn't reach the height needed with the regular sprayers. Made up a short hose with the strainer on the end to drop into a 2-1/2 gallon jug. The blue sleeve is part of an old broom handle to keep the strainer from floating up. Used the 0 degree tip from my real pressure washer.
Real long story about the Japanese beetles and our linden tree, but the systemic pesticides weren't working. One time I did fab a long extension for the regular garden sprayer. Another time I made up a pressurized tank from an empty R22 tank. Once I borrowed a bucket truck. This is by far the easiest method. A good still morning and you're in business.
I bought the little DeWalt "pressure washer" (quotes because 550# doesn't qualify as a real one) to do the Kubota in Winter after travelling on the salted roads. Much easier to fill a 5 gallon bucket and use it than to drag frozen hoses around. A local hardware store had the complete kit for $99. That's like buying a battery and getting the rest for free.
/ Can a propane tank be repurposed? #29
Battery powered hand sprayer
I wonder how well these types of rechargeable speakers work and how much extra weight is involved compared to a pump tank sprayer?
I also find backpack speakers too heavy. Went back to normal pump sprayer. Would never pressurize with air compressor. Not just safety. Would seem impractical in terms of run time even if you used an air tank designed for holding pressurized air and then it would be too heavy to carry for long.
I suspect that leads to a discussion whether a rechargeable sprsyer is really that better than a pump sorayer when it comes to run time and weight?
/ Can a propane tank be repurposed? #30
Awesome that you referenced a standard. Thank you. Do you by chance know the PSI for a standard 1-pound tank?
We made bead cheaters that pop tires on the rim. Old propane bottles. 150 psi all day long.
The little bottles have a relief on them. When you fill them, it sprays out when full. So how can you over pressure that?
/ Can a propane tank be repurposed? #31
Kinda like battery grease guns. Alls fine until the battery goes dead.
/ Can a propane tank be repurposed? #32
Just made my day, have toying with ideas for while. Mostly free and functional.....
Another project on the list.
/ Can a propane tank be repurposed? #33
You won't have to worry about that. Most single stage shop compressors won't go past 180psi, and that won't pop any of the common types of metal tanks.. that are in good condition.
But that's the thing about tanks.. you never know what they look like on the inside (unless you look). When you pressurize air, you condense the moisture that was suspended in the air back into a liquid, which settles at the bottom of the tank. This is why actual air tanks (made for air) have a drain on bottom. That part of the tank will tend to rust, which means getting thinner and thinner, unevenly (which causes stress risers, or places a crack is likely to form), until it eventually splits.
You can't easily tell from the outside how damaged a tank might be on the inside. That's why people use date codes as a shorthand for tank safety even though it MIGHT not mean a darn thing about actual tank condition. It's just less likely that a newer tank has had time to develop a serious problem.
Back in the day, Mythbusters taught me that a 3 liter soda bottle will hold ~75 psi! I remember being really surprised to learn that.
Another use for LARGE old tanks.. DIY round back tractor buckets! But cutting on an old propane tank will rouse up a new mob of concerned internet citizens with safety advice. :LOL:
/ Can a propane tank be repurposed? #34
I use backpack a lot.
I modified the padded shoulder straps to lock in size for me...
Used pop-rivet with washers.
Also have the perfect retaining wall height to put it on and in a pinch the large Waste Management tote height work for me.
Also give it a few pumps before putting on to pressurize seating the check valve
/ Can a propane tank be repurposed? #35
Hence my comment about air tanks. Nobody looks but are willing to dump air into them, yet we panic about the reuse of propane tanks. My oxy and acetylene tanks get inspected and tested due content and pressure, my air tanks will most likely leak before massive failure occurs. I drain my tanks a few times a year to remove moisture but I'm sure it is not enough.
/ Can a propane tank be repurposed? #36
W8BYA,
All pressure vessels have a rated lifetime for a reason, to keep people safe from Rapid Unscheduled Disassembly ( thank you Elon Musk ). There is a date stamped on the side of the 20+ Lb propane cylinders and pressurized air storage tanks to prevent it from being refilled after that date and the 1 Lb bottles are built for single use/ single fill only. That is also why the connection on 20+ Lb bottles has been periodically changed to prevent the continued use of older cylinders.
HF does make a connection that would allow you to fill a 1 Lb bottle but you are playing with a hand grenade that may or may not go off. Air pressure tanks have a valve to remove ( blow off ) water that accumulates so as not to compromise the tank by causing internal pitting/ rusting. 1 Lb cylinders have no means of getting rid of water.
Here is propane vapor pressure graph ( log scale ) but I have no idea what the schrader pressure relief valve on top of the 1 Lb bottle is rated for.
Here is a possible non exploding solution
/ Can a propane tank be repurposed? #37
The psi of the propane is not dependent on the tank size. The psi is function of the contained liquid and its vapor pressure. See graph I just posted.
/ Can a propane tank be repurposed? #38
If you are trying to make a small, lightweight, tank to carry you can use PVC pipe. Keep the pressure below 150 psi and you will not have any issues with failure. The one caveat to PVC is it gets brittle with age and can fail. I'd replace the tank every few years to prevent that.
/ Can a propane tank be repurposed? #39
The battery used for the sprayer is pretty light. It’s the same battery I use for my HF hedge trimmer.
