helping a neighbor repair his rotary cutter
/ helping a neighbor repair his rotary cutter #1
epistememe
Tucson, AZ
Case 450
My neighbor hit a rock and damaged his rotary cutter. The sheer pin sheered but it also took out a tooth on the input bevel gear and messed up the output bevel gear in the gearbox. There are no tags/markings on either the rotary shear or the gearbox and he has no idea the manufacturer of the attachment. This makes finding replacement parts very difficult. I am asking for help in IDing the rotary cutter and gearbox and any sources for replacement bevel gears.
/ helping a neighbor repair his rotary cutter #2
If nobody is able to provide the info, a suggestion would be to take the broken section to a farm/tractor dealer near you to see if they would be able to match it generically.
/ helping a neighbor repair his rotary cutter #3
There are generic gearboxes available (if in stock).
Example:
Bruce
/ helping a neighbor repair his rotary cutter #5
Measure for a replacement and replace the entire gear box. If you can find the parts they will be more expensive than a generic box. Been down this road before. Install a slip clutch when you replace the box.
2001 INTERNATIONAL 4900 WATER TRUCK (A58214)
2001 INTERNATIONAL...
Freightliner Columbia (A61306)
Freightliner...
2014 Timpte Hopper Bottom (A61307)
2014 Timpte Hopper...
2017 Ford Explorer AWD SUV (A59231)
2017 Ford Explorer...
2015 LOAD TRAIL 24+6 GOOSENECK TRAILER (A58214)
2015 LOAD TRAIL...
2019 Jeep Grand Cherokee SUV (A59231)
2019 Jeep Grand...
