helping a neighbor repair his rotary cutter
   / helping a neighbor repair his rotary cutter #1
epistememe
Tucson, AZ
Case 450
My neighbor hit a rock and damaged his rotary cutter. The sheer pin sheered but it also took out a tooth on the input bevel gear and messed up the output bevel gear in the gearbox. There are no tags/markings on either the rotary shear or the gearbox and he has no idea the manufacturer of the attachment. This makes finding replacement parts very difficult. I am asking for help in IDing the rotary cutter and gearbox and any sources for replacement bevel gears.
   / helping a neighbor repair his rotary cutter #2
If nobody is able to provide the info, a suggestion would be to take the broken section to a farm/tractor dealer near you to see if they would be able to match it generically.
   / helping a neighbor repair his rotary cutter #3
There are generic gearboxes available (if in stock).
Example:
Bruce
   / helping a neighbor repair his rotary cutter #5
Measure for a replacement and replace the entire gear box. If you can find the parts they will be more expensive than a generic box. Been down this road before. Install a slip clutch when you replace the box.
UNUSED CFG INDUSTRIAL EXCAVATOR ATTACHMENT SET (A51248)
UNUSED CFG...
1995 Chevrolet K2500 Pickup Truck, VIN # 1GCGK29F2SE237154 (A51573)
1995 Chevrolet...
JOHN DEERE XUV835M LOT NUMBER 26 (A53084)
JOHN DEERE XUV835M...
2017 Wanco WSDT Towable Compact Radar-Speed Trailer (A52377)
2017 Wanco WSDT...
2013 Great Dane 53ft T/A Reefer Trailer (A51694)
2013 Great Dane...
