4 Wheel Drive Lawn Tractor
/ 4 Wheel Drive Lawn Tractor #1
gaschleimer
Troy Built
Hey Ya'll,
I just purchased 37 acres - measuring up. I have about two acres of flat land to mow - easily handled with a big box troy built, but I wanted something to take up the mountain trail hall trees back down, hall lumber to build a deer stand etc... essentially, does an all-in-one, mower / 4 wheeler exist? If so, what's the best?
Thanks
/ 4 Wheel Drive Lawn Tractor #2
It's a little crude, but you might just want to get a side by side and tow one of these things around.
I know they make belly mowers for ATV's, but it sounds like a Side by side with the tow behind is more your speed for hauling stuff etc.
/ 4 Wheel Drive Lawn Tractor #3
I just purchased 37 acres in the mountains.
I want something to take up the mountain trail, haul trees back down, haul lumber to build a deer stand etc. What is the best?
Kubota's rough-terrain-vehicles (RTVs) have Kubota (tractor) two-range hydrostatic transmissions, (tractor) limited slip differentials and 4-WD standard. RTVs are work vehicles. $12,000 and up.
MUTS trailers are the best. $2,300 and up.
Ventrac or Steiner tractors are the heavier, more expensive, more versatile choice for mowing hilly land. Ventrac is a division of Toro.
VIDEOS:
/ 4 Wheel Drive Lawn Tractor #5
/ 4 Wheel Drive Lawn Tractor #7
IMO for the jobs mentioned you need several pieces of equipment. For the size of the property I'd suggest an ATV or side by side for light hauling and 37 acres of work use. The other would be a compact tractor with a loader and mower. Otherwise for a single piece of equipment you'd need a commercial Bob cat 4wd or the like and they are expensive and then you are stuck with a single vehicle if it breaks down or gets stuck. Multiple pieces of equipment have purpose if not for just towing when one's dead on the trail (which happens) or gets stuck (which happens).
gaschleimer:​
Adding your LOCATION to your T-B-N PROFILE will get you much better tailored replies to your opening post.
Sorry for the inconvenience, the property is in SW VA. Konerach VA if you're familiar. 10 miles west of Damascus
Because there aren't hills in 50 states. :unsure:
gaschleimer:​
/ 4 Wheel Drive Lawn Tractor #11
What about a small tractor with a MMM
Also when I was looking for a lawn tractor for the house yard both Kubota and JD had 4x4 lawn tractors in their lineup. I ended up with a zero turn and purchasing a JDM mini truck for the tasks you are describing. Lots of ways to solve this problem. I like the mini because I can get a plate in my state to drive on roads. If I lived in one of the states that does not allow this I would have purchased an RTV/UTV.
If you really just want 1 vehicle to do it all I would say get a small tractor around 20-25hp that can use a mid mount mower.
You are not that far from Powertrac so you could go check out their offerings. They have some neat stuff
/ 4 Wheel Drive Lawn Tractor #12
Our yard is nearly all hillside and the 1st lawn garden tractor mower we had got was stuck, stuck and stuck again. The 2nd one was a 4wd Husky center-actuating version which we still have and its never spun its tires or got stuck. Love it! But thats a moot point since no-one makes them anymore........:(
/ 4 Wheel Drive Lawn Tractor #13
Welcome! As stated above, there are lots of ways to skin this cat. For a true one-stop machine, I'd look at the small John Deere (1025 or 2025) or Kubota (BX series) tractors with mower, loader and possibly brush cutter. Or myriad of other brand's sub-compact tractors. My best advice, when you buy, make sure to buy the attachment and options that you want in the future. I cheaped out and regret it.
A tractor and attachments will give you a swiss army knife approach. Not always the best choice for every application, but can do a lot of stuff. It's often the stepping stone to further refine your equipment needs and wants.
/ 4 Wheel Drive Lawn Tractor #14
If I were you, I'd look into a subcompact or compact tractor in the 25Hp category with a mower deck, it will do most everything of your needs. Once you get a tractor, you wonder how the heck you did so long without one. That front loader with a set of pallet forks and or a grapple...........it will blow your mind. Listen I mow for clients as a side jobs, some of them have large properties. Once they see my setup, I can see sprockets working in their eyes..............bing. Suddenly they own a tractor.
/ 4 Wheel Drive Lawn Tractor #15
Yeh, I concur at the very least, the o/p is in scut territory if they want one machine to do it all.
/ 4 Wheel Drive Lawn Tractor #16
Have you looked at Power Trac? They are a little over an hour from you. They are local and might be worth looking at. There are some folks own here that have them that could tell you more.
/ 4 Wheel Drive Lawn Tractor #17
I would favor a 1984-1988 Ford Bronco II 4x4 with manual hubs, manual transfer case, and manual transmission. I had 30 acres in central Maine and use to take it down ATV trails on the property, pretty much stock with the exception of 235/75r15 tires. You can make a small firewood cage out of 2x4s, secure it so you do not get squished in an accident, and load it to the roof with firewood such as birch, as I used to do. Oak only go <1/2 way, it can handle 1,000# or so okay driving slow off road, not 2000# of oak to the roof.
It has almost a 50/50 front to back weight distribution and for pulling stuff in the wood, the 110 HP and 150 FT PD of torque with 4LO (2:68 ratio) multiplying that provides more then enough power to pull trailers and implements. I like to put a good bumper front and back with pintle hooks/2" ball combos, along with D rings. Add a HF 5000# winch front and back, not only would help when stuck, but, you can skid logs with the winch to where you can grab them with an Arch or to put on a trailer. A light duty 4x8 trailer is the perfect size for the vehicle. A locker in the rear axle would not hurt, I would not put one in the front if you need to steer around trees a lot.
There is the bonus of having good heat and A/C and room for spare parts and equipment such as saws, PLUS, a place to lie down and take a nap if you have to or when it is pouring rain too hard to work. I have been running aggressive retreads for 10+ years and recently upgraded to 16" rims so I could run the retread chevron tires in the link below because tread wright no longer does the 15" tires.
( I get the crushed acorns for the winter traction)
I forgot about those! I used to drive a Bronco II. Awesome little SUV. That thing went anywhere.
As for the original poster, when you look at the price of 4WD garden tractors you are better off to spend a bit more and get a SCUT. Opens the door to a lot more implements and loaders and backhoes if you ever want to add them.
/ 4 Wheel Drive Lawn Tractor #18
/ 4 Wheel Drive Lawn Tractor #19
Those Ventracs are cool and all, but Jesus those prices! Also, they used to have loaders (with less lift capacity than a scut) but now just have a front scoop type thing.
/ 4 Wheel Drive Lawn Tractor #20
He never mentioned cost, and he never mentions a loader in his original post, but Ventrac still makes a loader.
New/Unused Landhonor 6ft x 8ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
KMC 3pt 12 Row Rip Strip Till (A64126)
KMC 3pt 12 Row Rip...
PAN (A62613)
PAN (A62613)
2008 PROGRESSIVE 20' X 7' BUMPER PULL TRAILER (A65643)
2008 PROGRESSIVE...
2001 INTERNATIONAL 4700 4X2 S/A UTILITY BODY TRUCK (A66091)
2001 INTERNATIONAL...
LMC Ag 3pt 300 Gal 54' Boom Sprayer (A64126)
LMC Ag 3pt 300 Gal...
