Starlink
/ Starlink #2,582
To me the good news is that there aren't a bunch of errors in your log, the ping flood didn't lose many (21 packets), and the ping times look ok, but not great. I would have expected ping times closer to 1-2ms, or below, rather than 4.3ms. And it doesn't seem to be a Starlink issue.
Questions:
Have you tried reseating, unplugging and plugging back in, all the Ethernet cables, checking for dirt/debris with a bright light, or some compressed air? I would double check your crimps, just in case. as I am sure you know a single intermittent contact can cause all sorts of issues.
On your particular network, under Networks, usually Default, is the purpose corporate and the network group LAN, I.e. default?
The network range should be 192.168.10.1/24, that should generate 254 addresses. You might try clicking the update DHCP range button. I am a bit puzzled as to why DHCP should start at .6; what is the netmask set to? (e.g.255.255.?.?) I think that it should be 255.255.255.0 Can you test DHCP Server to on DHCP name server to auto, and DHCP gateway IP to auto? Do you have the advanced options off, including IPV6 to off?
Sorry not to have the answer. I will noodle some more on this.
All the best,
Peter
/ Starlink #2,583
Questions:
I ran the cable out to Dishy through a 3/4" length of PVC and it was a tight squeeze. The connector on the cable was covered in tape to keep it clean, but I had to pull pretty hard to get it through. That could very well have damaged the cable. I'm scheduled to have a trencher on site sometime soon, and plan to trench and run a larger conduit for a longer, 175' Dishy cable. Maybe that'll make a difference, but since the bottleneck seems to be between the Unify system and the SL router, I'm not expecting much improvement.
The Ethernet connectors Ubiquity sells are clear plastic, and I check each crimp under high magnification to make sure the wires are fully seated and there are no stray "hairs" shorting out adjacent connections. Yeah, been burned by bad connectors before...
Didn't have a corporate option until I switched back to the Legacy Network interface, but once there, both corporate and network group LAN were there. Another instance where the new interface just can't get the job done, yet Unifi keeps pushing it on their users.
The Gateway IP/subnet is 192.168.10.1/24, network range is 192.168.10.1 - 192.168.10.254, and network IP count is 254.
I can't find it in the legacy interface Network -> Networks. Don't see it in the new interface, either. Where is that button?
That's something I picked up from a CrossTalk Solutions video. Forget the reason he sets his up that way, though.
Confirmed: netmask is 255.255.255.0.
DHCP Name Server and DHCP Gateway IP are both set to auto.
No advanced options are enabled, no IPV6.
I've been wanting to try putting the SL router into bypass mode, but couldn't get past the login in the SL app. I tried one more time today, this time punching in my username/password instead of using a password manager. And I got in. WTF?
Anyway, with the SL router in bypass mode, I used Ookla Speedtest on the MBPro to run another set of tests.
Down Up
50.8 13.2
38.4 6.58
53.1 6.07
52.4 7.16
38.6 7.48
___________
46.7 8.10
Since the SL router is in bypass mode, there's no SL WiFi network, but I can still use the SL app on the iPhone ti speed test through the Unifi WiFi:
Down Up
34 7
44 5
63 14
43 12
63 10
___________
49.4 10
Pretty much the same.
I also notice that now on the Unifi Network -> Dashboard, WAN1 reports an external IP of 100.101.101.194. Before, I was getting an IP in the 192.168.X.X range.
Another oddity is that the StarLink app on the phone is reporting obstructions, but none are visible in the VISIBILITY page of the app.
Again, thanks for the help. If you come up with any other ideas, lemme know.
Until then, maybe we should return this thread to the regularly scheduled programming...
/ Starlink #2,584
you may want to check you unifi bandwidth (20/40/80) etc... and the band. sounds like you might be on 2.4/20
my unifi pro, can do 600mbit on 80/5.8 via lan transfer etc...
/ Starlink #2,585
Dishy runs on the 100. network, so that's why the address shifted. No worries.
Ethernet isn't fiber, but yes, it doesn't respond well to being pulled hard.
Have you tried using your other WAN port to see if the behavior is any different?
It is to the right of the network address in the old interface IIRC. But your network addressing seems ok.
Can you plug your MBP into the bypassed Starlink router at the Ethernet adapter and run a speed test? (I.e. Cut out your beautifully made Ethernet cable and the whole UDM-PRO?
All the best,
Peter
/ Starlink #2,586
Somewhere in this mess is the WiFi network in use. I think it's the first Gunsmoke listed. That's the only one that lists a Transmit Rate...
Software Versions:
CoreWLAN: 13.0 (1375.2)
CoreWLANKit: 13.0 (1375.2)
Menu Extra: 13.0 (1380.2)
System Information: 12.0 (1300.2)
IO80211 Family: 12.0 (1200.12.2)
Diagnostics: 1.0 (805)
AirPort Utility: 6.3.9 (639.9)
Interfaces:
en0:
Card Type: AirPort Extreme (0x14E4, 0x7BF)
Firmware Version: wl0: Oct 23 2019 08:32:36 version 9.137.11.0.32.6.36 FWID 01-671ec60c
MAC Address: f0:18:98:99:68:56
Locale: FCC
Country Code: X0
Supported PHY Modes: 802.11 a/b/g/n/ac
Supported Channels: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 36, 40, 44, 48, 52, 56, 60, 64, 100, 104, 108, 112, 116, 120, 124, 128, 132, 136, 140, 144, 149, 153, 157, 161, 165
Wake On Wireless: Supported
AirDrop: Supported
AirDrop Channel: 0
Auto Unlock: Supported
Status: Connected
Current Network Information:
Gunsmoke:
PHY Mode: 802.11ac
BSSID: e0:63:da:78:5d:47
Channel: 36,1
Country Code: X0
Network Type: Infrastructure
Security: WPA2 Personal
Signal / Noise: -65 dBm / -95 dBm
Transmit Rate: 180
MCS Index: 0
Other Local Wi-Fi Networks:
Gunsmoke:
PHY Mode: 802.11n
BSSID: e0:63:da:77:5b:d7
Channel: 6
Signal / Noise: -77 dBm / -95 dBm
Gunsmoke:
PHY Mode: 802.11n
BSSID: e0:63:da:77:5d:47
Channel: 6
Signal / Noise: -58 dBm / -95 dBm
Gunsmoke2.4:
PHY Mode: 802.11n
BSSID: ee:63:da:77:5b:d7
Channel: 6
Gunsmoke2.4:
PHY Mode: 802.11n
BSSID: ee:63:da:77:5d:47
Channel: 6
Signal / Noise: -59 dBm / -95 dBm
GunsmokeGuest:
PHY Mode: 802.11n
BSSID: e6:63:da:78:5d:47
Channel: 36,+1
Gunsmoke_IoT:
PHY Mode: 802.11n
BSSID: ea:63:da:77:5b:d7
Channel: 6
Signal / Noise: -76 dBm / -95 dBm
Gunsmoke_IoT:
PHY Mode: 802.11n
BSSID: ea:63:da:77:5d:47
Channel: 6
Signal / Noise: -56 dBm / -95 dBm
/ Starlink #2,588
First one says current, then there are the others.
/ Starlink #2,589
The BSSID looks like MAC addresses, from same brand of equipment.
/ Starlink #2,590
@RedNeckGeek You might want to check that your access points aren't putting you on your presumably bandwidth throttled guest network. I.e. try deleting all of the WiFi authorizations except for Gunsmoke 5GHz on a single device, e.g. a tablet, and rerunning the speed test.
All the best,
Peter
/ Starlink #2,591
Status: Connected
Gunsmoke:
PHY Mode: 802.11ac
Channel: 36,1
Country Code: X0
Transmit Rate: 180
MCS Index: 0
/ Starlink #2,592
Status: Connected
Gunsmoke:
PHY Mode: 802.11ac
Channel: 36,1
Country Code: X0
Transmit Rate: 180
MCS Index: 0
a rate of 180 is garbage for ac, cut it in half, should still see around 90mbit, -65 is pretty good though, sounds like the bandwidth needs to be increased for ac
are you running the unifi controller to adjust this?
/ Starlink #2,593
Status: Connected
Gunsmoke:
PHY Mode: 802.11ac
Channel: 36,1
Country Code: X0
Transmit Rate: 180
MCS Index: 0
What are the units on the transmit rate?
Thanks!
All the best,
Peter
/ Starlink #2,594
Received the email today saying to confirm my order. I did that so it looks like I may get Starlink after all. Lol Now if I can make it work around my trees. :D
I do have a question for the folks that have received their kit. How long is the cable that comes in the kit? Trying to decide if I need to order the longer one.
/ Starlink #2,595
75'
/ Starlink #2,596
Thanks. That will be close. For some reason I thought it was 100’ but was not sure. 100’ definitely would make the run so I will see what I can do when it comes.
/ Starlink #2,597
Your memory is fine. The beta test models came with a 100'; the new ones come with 75', and there is a 150' cable available to order if you need it. (You can browse the shop page on your Starlink account.)
All the best,
Peter
/ Starlink #2,598
All the best,
Peter
Not really beta test models. It was the first and second generations of the dish system that were round and came with a 100' cable that could not be disconnected from the dish end. The 3rd generation rectangular dish has a fully removable cable which, as noted, comes stock at 75' but has an optional 150' version that can be purchased.
/ Starlink #2,600
I’ve had good success putting the SLs in bypass mode and using Meraki MX firewalls handling the DHCP. I let the Meraki MX do DHCP for the regular network and then also do a separate DHCP server on the site to site VPN side. I use their APs to get the smooth handoff between APs throughout the property. I’ve been pretty pleased with these setups thus far. And having the Meraki MX handle two providers in the event of a failover has also been very smooth.
2018 Chevrolet Tahoe SUV (A64194)
2018 Chevrolet...
International Harvester (IH) 18' Cultivator (A66408)
International...
2016 Volvo VNL Truck, VIN # 4V4NC9TH4GN955551 (A65563)
2016 Volvo VNL...
Skeleton Backing Plate (A62679)
Skeleton Backing...
New Landhonor Skid Steer Utility Hitch Adapter (A62679)
New Landhonor Skid...
2015 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A64194)
2015 Peterbilt 567...
