Is a power rake the same thing as a Harley rake and is this better than a root grapple + landscape rake?
/ Is a power rake the same thing as a Harley rake and is this better than a root grapple + landscape rake? #1
future_vision
Gold Member
New England
DK6010SE HSA
I've been looking at implements for clearing and working some land. A grapple is a must since I have a lot of brush and logs to move but after that I was looking the next implements to prep for grass. Originally I was thinking if I got the right grapple then all i would really need is a landscape rake to out the rest of the debris and rocks but then I came across the Harley rake. Looking at it reminded me of a power rake which I never really considered. Are these both the same implement? If they aren't which would be better and are they better than going the root grapple plus landscape rake route? If the harley or pwoer rake is the better way to go then that that changes up the parameters for my choice of a grapple. I might move towards more of a rock grapple. Any recommendations would be greatly appreciated as I get started out with my first tractor and implements.
Thanks!
/ Is a power rake the same thing as a Harley rake and is this better than a root grapple + landscape rake? #2
Power rake is the generic term. Harley rake is a brand name. Both being the same thing.
Power rake beats a landscape rake by far.
Power rakes are pricey but worth it if you can swing it.
Here's mine smoothing out a lateral field install.
Excellent! Is there a particular brand to look at? I've got maybe 5-7 acres to clear, a 60 hp tractor and won't be using this much after that unless I get some crazy idea to do this as a side hustle. In fact, given the cost, I might even just rent one. 72" for under $1000 for a month in my area. That might be the more financially responsibly way to go.
/ Is a power rake the same thing as a Harley rake and is this better than a root grapple + landscape rake? #4
Do u mind saying what brand power rake u have and how has it performed as far has durability?
/ Is a power rake the same thing as a Harley rake and is this better than a root grapple + landscape rake? #5
Absolutely try to find a power rake, harley rake or preseeder. If you're only using it for a final grade on your own property it'd be worthwhile to rent if one is available locally. They're pretty hard to find for a reasonable price unless you're willing to buy a used one and then resell it once you're finished. I personally have been using ATI preseeders to finish grade for around 17 years. The trick to getting a very nice finished product is to start with the teeth digging in to break up the ground and decrease the depth of the teeth so in the final passes you arent really pulling much dirt but just combing the top. That'll pull any remaining debris and eliminate leaving windrows. With a little practice there is no need for any handwork except close to obstacles and you'll have a grade thats literally as smooth as a parking lot. Preseeders leave a little different finish than a power rake because they use a full width roller instead of gauge wheels.
Wow! That looks great. I've got ta fair amount of rocks and roots in our dirt up here in New England so I will definitely need a tool that is going to take care of both and with only 5-7 acres to do it really doesn't make sense to buy one unless I plan on spreading all the work out over several months which I prefer not too. I should be able to get it done in a month as a weekend warrior.
/ Is a power rake the same thing as a Harley rake and is this better than a root grapple + landscape rake? #7
I had the same situation 10 years ago we cleared/stumped 2 acres here on the coast of NH, and have ledge and lots of rocks/roots/debris to deal with after the stumping. I had a friend come in with his 6' harley rake and there were just too many large rocks (2-3' size every 30'-40') embedded at ground level for the harley rake to work effectively.
We ended up with a York rake (with gauge wheels) and angled/windrowed the rocks/roots into small piles, used the FEL to clean up. We had 3 8-10 yard debris piles that I let sit over the winter then burned it.
I would look at a grapple with a close bottom splines (like a rock bucket) to get the majority of the big pieces, then a york rake for the smaller debris. We ended up getting a deal on decent sandy fill dirt, so spread that and then about 100 yds topsoil.
Once you get topsoil down you can rent a harley rake from Mear's Tractor $185/day but may not need it at that point.
/ Is a power rake the same thing as a Harley rake and is this better than a root grapple + landscape rake? #8
Your video is the first time I have seen a Power Rake operating with gauge wheels. In your video the gauge wheel tracks are nearly continuous.
Gauge wheels are an expensive option.
Have you found the optional gauge wheels worth the expense?
Thanks for the input. While I was clearing with the excavator I got a little overzealous clearing out those size rocks so the area done so far might be fine. I expect I'll find more along the way and pull those out with the backhoe. But your idea about the rock grapple is certainly the direction I am leaning. You can do some root with it and lifting logs and dealing with brush should still be fine but the ability to sift all those smallish rocks saves a lot of bending over and gathering them by hand for sure. I've seen some rock grapples I like but they are a bit on the heavy side. I'll likely be running a Kioti DK6010SE and the loader has the following specs. Just need to find something that comfortably works with those specs. My understanding is the grapple should be no more than half the lift weight of the loader at the pins which feels like it might be pushing it if I am lifting 14-16 pine and oak logs. Granted, they aren't that round but I do get some up in the 14-16 inch range. Not sure what those weight but I'm guessing I'll be near my limit.
Lift Capacity to Full Height at Pivot Pins2,474 lbs. (1,122 kg)
Breakout Force at Pivot Pins3,895 lbs. (1,767 kg)
Bucket Rollback Force at Ground Line3,148 lbs. (1,428 kg)
/ Is a power rake the same thing as a Harley rake and is this better than a root grapple + landscape rake? #10
For Jeff's question about gauge wheels, I can't imagine using one without gauge wheels. Most units have a slotted top link, which allows the operator to feather the unit for deeper or shallower use. During the initial passes, yes, it can be a set and forget situation, but for a mound or cavity, you will want to move more or less dirt from those spots. The slotted top link allows the operator to finely adjust the cutting height to move more or less dirt.
/ Is a power rake the same thing as a Harley rake and is this better than a root grapple + landscape rake? #11
Power rake is generic harley. Rock hound does or did make a good variation as well.
Break the soil with a x, hoe, ripper, or disk. If the soil is loose the rake will have no trouble wind-rowing even large rocks. Get it loose and rock free-ish down 3 or 4 inches. Then make passes at an inch or two for finish.
As someone above said, not sure what I would do with a harley rake without gauge wheels.
If you just have one spot, rent for sure, they are (at least mine) the implement I have to work on the most. That said, they do "stuff" nothing else will do.
Best,
ed
/ Is a power rake the same thing as a Harley rake and is this better than a root grapple + landscape rake? #12
As listed in the video mine is made by Woods. While I really haven't had problems with mine, I'd stay with a known, major brand to insure parts availability if you buy one.
Renting could be a great option if you have limited use.
/ Is a power rake the same thing as a Harley rake and is this better than a root grapple + landscape rake? #13
I believe the gauge wheels to be well worth the expense. In some tight places I have ran with my gauge wheels up. The rake doesn't do nearly as good a job of leveling with the gauge wheels up. You have to slow down and be quick on the lift lever.
In this video I am digging in pretty good with the rake and pulling forward pretty hard to move a larger quantity of material further for the initial passes. With the slotted top link pin hole that does cause the gauge wheels to lift a bit.
On subsequent passes I lighten up on depth and increase ground speed to give a better, overall smooth surface.
/ Is a power rake the same thing as a Harley rake and is this better than a root grapple + landscape rake? #14
I use a 72" Everything Attachments Wicked Root grapple to pick up the rocks and sticks the power rake brings to the surface. EA's Wicked grapples are the best and very light.
/ Is a power rake the same thing as a Harley rake and is this better than a root grapple + landscape rake? #15
You can rent a forestry mulcher on a CTL for the land clearing and use it like a power rake for finishing up.
/ Is a power rake the same thing as a Harley rake and is this better than a root grapple + landscape rake? #16
Without sounding like a salesman, have you considered a TR3 instead of the Harley/power rake? (full disclosure, I work for the company that makes them, but have used them on my own property and they work great) It costs less and has fewer moving parts. It will prep the soil for seeding and help with land clearing (still need the graple). You could use it for gravel driveway work or other things instead of buying a one trick attachment.
Curse you! Lol! Just when I thought I was networking things down a new implement pops up. This looks interesting. Just don't see how it'll do a good job getting rocks and roots or of the ground but as a replacement for a box blade and landscape rake it's an option for sure
Looking at the rock/skeleton grapple I'm wondering if it makes sense to just get a skeleton bucket and a root grapple instead. I'll still need to rent a power rake for the 'fine tuning' of the soil but for the bigger debris I'm wondering if the two more specialized implements are better than a combo like a skeleton grapple and possibly cheaper?
/ Is a power rake the same thing as a Harley rake and is this better than a root grapple + landscape rake? #19
They do not call it the Granite State for nothing. Every piece of property I have ever seen there is bordered compleatly with granite bolder rock walls. Look for the walls.
If your property was never rocked, hard to believe, but possible, especially if it was discovered to have larger bolders than could be moved or broken up, then you could have a bigger problem than a tractor can solve.
I lived in NH for a couple of decades, graduated HS and college there. I have hunted and wandered that state from end to end and side to side. Built a house outside of Manchester, used blast mats to put in the foundation and water lines.
Good Luck.
Good Luck.
I believe you. I've rented an 18,000 lb excavator and dug up some seriously large boulders but the area is not riddled with them. At least not the acre or so I've already worked on clearing. I haven't hit any serious stuff yet but I know it is there but further back on the property. Mostly in the wetland area which is never going to be touched. But I would say most of what I've come across can be can probably be handled with a tractor or subframe backhoe one way or another. That and maybe one of those 12,000 lb winches from Harbor Freight. At least that is what I would like to believe. People have moved huge rocks for millennia without a tractor why can't I?
2009 FONTAINE TRAILER CO. 48 X 102 SPREAD AXLE FLATBED (A60736)
2009 FONTAINE...
John Deere 12in Channel Tooth Bucket Excavator Attachment (A60352)
John Deere 12in...
New/Unused AGT Quick Attach Auger with Three Bits (A61166)
New/Unused AGT...
2015 Freightliner M2 106 AWD Altec DM478BTR Insulated Digger Derrick Truck (A60460)
2015 Freightliner...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
RK25 PERFORMANCE SERIES TRACTOR (A62130)
RK25 PERFORMANCE...
