new Doo Little
/ new Doo Little #1
ArlyA
Super Star Member
Houghton MI (the Lake Superior snow belt) USA
Outlander1000 6x6, Ego lawn mower and shopping for tractor
We picked up a new utility trailer yesterday! Its 84 wide by 14ft long. I already noted a few things to change.
/ new Doo Little
Doolittle didn't put any holes along the sides to add ratchet ties to. When we haul debris* we use light straps to retain it. Its the law here you must have a covering to keep your load.
* tree branches.
/ new Doo Little
I threw some deck preservative on the wood today before it rained. Doolittle has four tie-down points inside the box located at each corner. Personally I'd like 3 or 4 per side. One can be seen in the lower photo.
/ new Doo Little #7
Good choice. Doolittle trailers are built near here, in Holts Summit Missouri. They are well built and have a great reputation for good trailers.
If someone can wait for delivery, they accept custom orders (hope they still do). I have one of their ezloader tilt bed equipment trailers. Best I have ever owned.
That is a nice looking trailer.
What kind of fasteners are you thinking about. D rings, rub rail or ?
congratulations on a good trailer.
/ new Doo Little #8
My little 4x8 is so narrow that have a hard time seeing it when backing up. Even going down the road sometimes have to wonder if its still following me. So I'm wondering with a 84" wide that must be close to 9' overall width?
Does that present a problem when going around drive thru eating establishments? :)
/ new Doo Little
I like D rings but at this point I'm not sure what to do... On the steel sides top flabges, I was thinking I'd drill 1/2 holes along them for ratchet strap mounting. Those would be for coverings, not heavy loads like our 6x6. D rings added need to be near the floor.
/ new Doo Little #10
It may be stronger if you could add tie-downs or rings to the sides down near the bottom of the trailer. Closer to the bottom where you might be able to fasten into the frame angle iron of steel. That would require longer tiedowns, but maybe much more solid. ALSO. my wife and I have done a lot of white water canoeing on Southwest whitewater rivers. For the canoe trailer, we use straps for tie-down. We use them for everything. Might check them out for light hauling like lumber, brush, trash, etc.
Go to nrs.com and search STRAPS. We use only the 1" strap. You might find them handy. We use them for everything we put into our small trailer.
/ new Doo Little #14
Nice trailer. Did you have a hard time finding it, or are they getting back in stock?
About your D rings; my little dump trailer is made from similar material and came with them mounted on 4 corners. You might want to reinforce where they are going with angle; otherwise when you try to cinch something down it will just suck the sides of the trailer in as you are going down the road, causing your straps to loosen. I found that out the hard way one night with a full load of cedar logs.
/ new Doo Little
The side material is about .100 thick or 12 gauge. Suppose I could caliper it!
/ new Doo Little
We found some trailers to look at but I'm not sure I can ascertain that stocks are getting better or not. We just started to look for a replacement this spring. :unsure:
/ new Doo Little #19
I pour reflectors on mine, they were stick on. I hate to sound cheap but the reflective tape at the local farm store was stupid expensive.
/ new Doo Little #20
Here is a pic of mine, you can see a pic of the reflector I added, a yellow one under the power washer wand. There is another one further back just out of the picture. The tape you added is much better.
2002 STERLING L7500 SINGLE AXLE BEVERAGE BODY TRUCK (A69167)
2002 STERLING...
2011 BRENNER TANK PUP TRAILER (A67714)
2011 BRENNER TANK...
Unused 2022 Ideal BB4LD 48in. Box Blade Tractor Attachment (A66734)
Unused 2022 Ideal...
2020 ISUZU NRR 4X2 S/A 22FT BOX TRUCK (A59912)
2020 ISUZU NRR 4X2...
Unused 2022 Hustler Lift Max LE110 SS Bale Forks and Frame Tractor Loader Attachment (A66734)
Unused 2022...
2004 Mack 613 Concrete Mixing Truck (A64194)
2004 Mack 613...
