B7610 quick connect subframe
/ B7610 quick connect subframe #1
dholly
Fingerlakes Region, Upstate NY
B7610HST
Well, now that winter's over I'm thinking about starting my snowplow DIY. /forums/images/graemlins/tongue.gif Since there is a good possibility I will put a front blower on my B7610 at some point, I would like to make my DIY plow compatible with the oem QT subframe. Can anybody share or point me to an ESM-like exploded diagram.pdf with part #'s for the B7610 quick connect subframe used for the oem front pusher blades and snowblowers? Similar diagrams for the plow mainframe and blade would be helpful too. Thanks.
I have found the exploded drawings for part #B2761 Subframe Assembly with Male Quick Hitch Assembly and part #B2765 Front Blade with Female Hitch and the optional Hyd Angling Kit. Next questions...
- do the front and rear attach points for the subframe assembly simply bolt directly to the frame rails?
- can the subframe assembly be left on the B7610HSD w/ LA352 FEL and RCK60 MMM without effecting their operation?
- if yes, must the male quick hitch be removed from the subframe for normal FEL operation, or can it just be left on?
- approx cost of B2761 subframe assembly, male and female quick hitches and hyd angle kit, individually if possible?
Thanks
Went and picked up the plow today, it's little bigger than I remembered. 7-1/2' and looks like an old Fisher?
Was most recently used on a skid steer, therefore there were a few frame mods done that will have to be undone.
Another shot of the frame, all the piston mounts, springs etc., are ok. A bit of sandblasting and paint, hope it's not too big for my 7610. Open to frame or subframe design suggestions if you have an opinion...
/ B7610 quick connect subframe #6
Thanks
Did anyone ever answer these questions? I find this very pertinant as I am considering the same thing.
No, No, N/A, $$$$
The proper subframe kit for the B7610 HSD is #B2733. Search up a thread titled 'B7610 HSD Snowplow Retrofit' for pictures and prices. It was a fun project and the plow works great. Hope that helps.
2022 JOHN DEERE 350G LC EXCAVATOR (A65053)
2022 JOHN DEERE...
2022 EZ-GO ELITE...
Mini Universal Root Rake (A65640)
Mini Universal...
2015 Ford Taurus Sedan (A64557)
2015 Ford Taurus...
2006 Chevrolet Silverado 1500 Ext. Cab Pickup Truck (A64194)
2006 Chevrolet...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A65643)
2020 TROXELL...
