B7610 quick connect subframe
/ B7610 quick connect subframe #1
dholly
Fingerlakes Region, Upstate NY
B7610HST
Well, now that winter's over I'm thinking about starting my snowplow DIY. /forums/images/graemlins/tongue.gif Since there is a good possibility I will put a front blower on my B7610 at some point, I would like to make my DIY plow compatible with the oem QT subframe. Can anybody share or point me to an ESM-like exploded diagram.pdf with part #'s for the B7610 quick connect subframe used for the oem front pusher blades and snowblowers? Similar diagrams for the plow mainframe and blade would be helpful too. Thanks.
I have found the exploded drawings for part #B2761 Subframe Assembly with Male Quick Hitch Assembly and part #B2765 Front Blade with Female Hitch and the optional Hyd Angling Kit. Next questions...
- do the front and rear attach points for the subframe assembly simply bolt directly to the frame rails?
- can the subframe assembly be left on the B7610HSD w/ LA352 FEL and RCK60 MMM without effecting their operation?
- if yes, must the male quick hitch be removed from the subframe for normal FEL operation, or can it just be left on?
- approx cost of B2761 subframe assembly, male and female quick hitches and hyd angle kit, individually if possible?
Thanks
Went and picked up the plow today, it's little bigger than I remembered. 7-1/2' and looks like an old Fisher?
Was most recently used on a skid steer, therefore there were a few frame mods done that will have to be undone.
Another shot of the frame, all the piston mounts, springs etc., are ok. A bit of sandblasting and paint, hope it's not too big for my 7610. Open to frame or subframe design suggestions if you have an opinion...
/ B7610 quick connect subframe #6
Thanks
Did anyone ever answer these questions? I find this very pertinant as I am considering the same thing.
No, No, N/A, $$$$
The proper subframe kit for the B7610 HSD is #B2733. Search up a thread titled 'B7610 HSD Snowplow Retrofit' for pictures and prices. It was a fun project and the plow works great. Hope that helps.
Mobark Beever M12RX Wood Chipper (A65579)
Mobark Beever...
4 Bottom Plow (A65640)
Hedge Posts (A65640)
UWS TBS-69 Truck Bed Tool Box (A64556)
UWS TBS-69 Truck...
2017 Chevrolet Tahoe SUV (A64194)
2017 Chevrolet...
Hydraulic Auger Mini Skid Steer Attachment (A64553)
Hydraulic Auger...
