Buying advice - How big do I need?
/ Buying advice - How big do I need? #1
SgtSluggo
Middle TN
John Deere 4105, Ford 1700
So, we have moved onto the new land finally and it is time to upgrade the little Ford 1700 I have been using to cut the field. I feel like I have read so much and looked at so many tractors, but I am getting a bit overwhelmed with what I should be looking for.
Here is what I think I want:
Run a bigger than 5ft cutter. I just want to be able to cut our 5ish acres around the house and 10 acres total more quickly. I am not sure if want something like a 7ft rotary or if I want to go with a lighter duty 6ft flail to go with my 5ft brush hog. Mostly I want it to be outside the edge of the tires to make it easier to cut up against our tree line.
I have a big ZTR that I plan to use eventually, but currently the land is still too rough for it to work well. So I want the tractor to be able to help me smooth the land (disc, blade, etc). It doesn't have to do it in a hurry.
We have plans for a medium sized garden but no plans to have a big farm or even cut hay right now. Maybe a small apple and pecan orchard down the line.
I want a loader so that we can do some dirt work (burying culverts in some ditches, etc) and keep up with the 800ft long gravel driveway.
I think I want a hydro transmission to make loader work easier. I also like the look of the glide shift kubotas but it doesn't seem like anyone else makes something similar. I am pretty sure I am sticking with open station just because being up under trees here. I think I want 4x4 just because we have some wet spots.
John Deere is the most common thing around here with Kubota a close second. I have been looking at both the 35-45hp range and the 50ish hp range, but there is nearly a 10k difference in those two machines.
There is a 2005 JD 4520 nearby with 2k hours for about 32k, but it comes with a box blade, tiller, forks, and a trailer. Not sure I need everything in that package though.
There is also a 2016 4105 for about 24k, but I would need to buy a blade at least. It only has about 700hrs on it.
I don't want to overspend, but I also don't want to underbuy either.
Any advice on what I should be targeting, if I am missing anything, or what else I should consider?
Thanks for all your advice.
/ Buying advice - How big do I need? #3
The 4520 with its 53HP and 3855lb is a very good size tractor and all these implements are very useful and fit within your scope of work ... if you don't want the trailer or other implements just sell it afterwards. But the forks are very usefully, the tiller you will need and the box blade also although you might prefer a blade instead.
Obviously the 4105 is smaller (41) hp and 2987lb might be better suited for finish mowing and still a good size for what you want to accomplish although with only 32hp on the PTO it will be slower then the 4520 with its 40hp on the PTO while brush hogging ... both have little hours in the grand scheme of things but the year, hours and price goes to the 4105 but the 4520 has a edge on HP and implements. Its weight will be both a negative or a positive depending on the task at hand...
From what you want to accomplish you are better with the smaller 4105 I think, the year, hours and price makes it very appealing.
Personally I would choose the 4520 but since you want to mow around the house I think it might be bit big for that that why I recommend the 4105 I think the 4520 HP and implements is very tempting the rest of the work you want to accomplish but that's me... you only can make that decision.
/ Buying advice - How big do I need? #4
I have 80 acres and a mile long gravel driveway. I bought a brand new Ford 1700 4WD in 1982. Traded it in 2009 for a brand new Kubota M6040 4WD. The M6040 has proven to be just the right size. Now that I'm into larger projects.
I've heard told AND repeated - "as long as you can still turn the new tractor and stay within the bounds of your property - it's not too big". I think I heard that from a tractor salesperson.
/ Buying advice - How big do I need? #5
If the only reason I wasn't going with a cab tractor was that I needed to mow around and under some trees, I would invest in a good pole saw and I would get to work lifting the tree canopy where I could get up under it, not sure where you live but down here in the deep south summertime can be miserable and a cab tractor with A/C is real nice for long days on the tractor, and lastly I have never heard anyone say I just have to much horsepower, try to get what you want to start with, strike while the iron is hot.
/ Buying advice - How big do I need? #6
Cut your "lawn mowing" down to what you can handle with the ZTR in an hour at the most. Pay someone to level that much of the lot and get your lawn in now.
40HP and up tractors are not good for lawn mowing, especially if you have a ZTR in the shed.
/ Buying advice - How big do I need? #7
I mowed 25 acres of pasture and maintained 15 acres of trails with a 34HP MF1250 for 27 years before moving to a new, bigger tractor. The 7' rotary cutter gets the job done a lot quicker but it really wasn't that bad with the 5' Bush Hog Squealer. It all depends on what else you will be doing with the tractor and the budget that you have to work with. I definitely agree with the ZT suggestions, sooner the better.
/ Buying advice - How big do I need? #9
John Deere 4520​
John Deere 4520 tractor photo
2005 - 2014
John Deere 4520 Weight
ROPS Operating:3855 lbs
1748 kg
Cab Operating:4345 lbs
1970 kg
Max capacity:8820 lbs
4000 kg
Max Drawbar:1103 lbs
500 kg
John Deere 4520 Power
Engine:53.1 hp
39.6 kW
PTO (claimed):40 hp
29.8 kW
PTO (tested):46.58 hp
34.7 kW
This tractor engine will NOT be encumbered with Tier IV emission control paraphernalia.
Ample PTO horsepower for any of the mowers you have specified.
Sufficient tractor weight to pull a Disc Harrow with 22" diameter pans at speed, which will have enough pan pressure to smooth your five (5) acre field.
/ Buying advice - How big do I need? #10
I have read so much and looked at so many tractors I am overwhelmed..... what I should be looking for?
The fundamental importance of TRACTOR WEIGHT eludes many tractor shoppers. Tractor capability is more closely correlated to tractor weight than any other single specification.
The most efficient way to shop for tractors is to first identify potential tractor applications, then, through consulataton, establish bare tractor weight necessary to safely accomplish your applications. Tractor dealers, experienced tractor owners and TractorByNet.com are sources for weight recommendations.
Bare tractor weight is a tractor specification easily found in sales brochures and web sites, readily comparable across tractor brands and tractor models, new and used.
- How < big > much weight do I need?​
You will need a tractor of at least 3,700 pounds bare weight in order to smooth five (5) acres with a Disc Harrow. All ground engagement applications require at least moderate tractor weight.
/ Buying advice - How big do I need? #11
The JD 4520 doesn’t sound like a bad deal if it’s in good shape. If you have a zero turn you can keep the tractor away from the house once you get everything smoothed out. I also agree, it sound lije you need those implements, if the trailer is decent it’s worth $4k alone.
2004 Winnebago Adventurer 38G 38ft. Class A Motorhome (A59231)
2004 Winnebago...
UNUSED WOLVERINE QUICK COUPLER 8 (A64281)
UNUSED WOLVERINE...
2015 GMC Sierra 1500 Crew Cab Pickup Truck (A61573)
2015 GMC Sierra...
30ft Highway Trailer Co. Lowboy (A63118)
30ft Highway...
JLG 8ft Boom Lift Man Basket Attachment (A61572)
JLG 8ft Boom Lift...
Year: 2015 Make: Chevrolet Model: Silverado Vehicle Type: Pickup Truck Mileage: 83,704 Plate: Body (A61573)
Year: 2015 Make...
