New Welder
/ New Welder #1
RancherGuy
Gold Member
Rosenberg, TX
Kubota L3710; JD 5425, 6105R, 7130-P; IH 1086
I hope this is an acceptable topic for a tractor forum. I'm not a welder by profession, but I have needs. Did I say that wrong?
I have owned and used a Millermatic 210 MIG welder for more than a decade. Flawless machine and it seems like a month does not go by without using it. I now have an itch to learn and do TIG on some projects. Sometimes I would like to do stick for dirty situations, but don't want to pull my stick machine out of the dark corner of stuff.
I have noted some new machines that have multiple personalities - MIG, TIG, Stick, even Plasma. If something had all 4, I'd be keenly interested. I already know I want AC/DC and Pulsed. HTP, Everlast, ESAB, Hobart, Lincoln, Miller are some names that I am aware of.
I would like to keep the purchase under $2500, but if $1600 will do, then the CFO (as in Female) would be happier. If I assume that MIG is included, I'd be willing to sell my MIG and Lincoln tombstone units to soften the blow. Is there some advice you have?
/ New Welder #2
Edit somehow I wiped out half of my response
Storm 215C has Got great reviews as well as a LONG warranty.
Very Happy with my HTP Pro Pulse 220 MTS and my old Lincoln TIG 300 300
7 year old LOTOS takes care of my plasma cutting,
AC TIG with a Plasma ... Not sure anyone has that Yet?
Maybe mistaken but If you want Plasma and AC/DC TIG and a MIG looking at at least 2 machines.
Decisions Decisions- Good Luck- Lots of Great choices out there,
ps. The Mods should probably move this to the welding section of Tractorbynet I just noticed this is in general section Unless the OP wants it in General Buying section?
/ New Welder
Move = fine by me. I didn't notice that section.
Thanks for your experiences and notes.
/ New Welder #4
My Grandson is a Certified Welder. Has done a lot of TIG. I'll ask him this weekend for opinions about TIG machines and combination machines.
I have a Lincoln Tombstone and a Miller 250 MIG. I've never tried TIG.
/ New Welder
After re re re reading OPs 1st post if it were me I would keep the Miller Mig....
Keeping the Miller is a strong consideration. I've seen some videos touting Pulsed MIG, so began to think that maybe I should look for Pulsed MIG and Pulsed TIG in one unit. Might even be able to finance a significant portion of a new unit with the old.
I'm not heading for the cheapest I can find, and figure that I may spend another $500 on things like accessories, supplies, and a #20 water torch. I am often one of those 'pro-sumer' types, in that I'll spend for features and quality if it means flexibility and reliability. If it looks and feels right, I can make the case and get approval. Spend once instead of upgrading/replacing later. So I think I'm looking for something in the 200-250 amp range for features and abilities. I talked with an Everlast sales guy today, who mentioned that their MTS 225 has a strong discount this month. A discount is very nice, but it isn't the highest priority. That unit is missing Pulsed MIG - don't know if it is a deal breaker. In contrast, HTP Pro Pulse 225 MTS is missing AC TIG - don't know if it is a deal breaker.
Lots to ponder. Still looking and considering.
/ New Welder #7
AC TIG is Necessary to TIG Aluminum unless you can afford bottles of Helium which are very pricy and hard to get from what I have heard.
I can confirm the HTP 220MTS can MIG aluminum without a spool Gun. Really like mine. But am somewhat of a newbee with it. It has quite a few programs and does take some learning to get the most out of it. That means I am still learning with mine. But it welds Much better than my 1980's MIG even without really dialing it in.
/ New Welder #8
I have a very nice Miller MIG machine that does pulsed MIG. Though I've had the machine for a couple or three years I have yet to use the pulsed MIG feature. I guess I really haven't seen the need for it yet. I bought the machine because I wanted more power than my little Lincoln SP125 Plus 120 volt MIG welder. I got a fantastic deal ($1000.00) for the used Miller and it has way more power and features than I can use, 300 amps at 60% duty cycle. But if I had been buying new the pulse feature wouldn't have featured very big in my decision. I would have looked for a good MIG welder with high reliability.
I think there are big advantages in multi-process machines if space and/or portability are concerns. Convenience too I suppose. But if your one multi-process welder breaks and is out for service or waiting for parts then you can't weld anything. I have acquired 4 welders and one plasma cutter over the years. These machines were used in my business so I wanted machines that I could rely on. Since I had and have the room (barely) the several machines have not been a problem.
TIG and MIG welders work differently. TIG welders are constant current machines and MIG welders are constant voltage machines. This means the electronic architecture of the machines are quite different and this is why it took so long for machines that would act as both TIG and MIG welders took so long to be combined into one machine. I think part of the reason why they are finally on the market has to do with inverter technology.
DC TIG is much easier to implement than AC TIG, which is why there are many multi-process machines that only offer DC TIG. AC TIG is pretty similar, electronically, to plasma cutting. Especially the high frequency and variable frequency. I think this is why once a company offers a machine that does AC TIG they start to offer machines that add plasma cutting to their AC TIG capable machines.
If I was in your position, with an already adequate for your uses high quality Miller MIG welder, and wanted TIG capability and a multi-process machine, I would look for a machine that does DC TIG, AC TIG, and plasma cutting. Keep the MIG machine.
Plasma cutting can be really handy. Not only will it cut any type of metal it can also be used to cut other materials. For example, I had to cut some 1 1/4 inch thick rubber. I tried band sawing with an aggressive blade and even with lube it was a slow process. And I had a lot to cut. So I tried laying some .062 steel sheet over the rubber to see if the plasma cutter would work. And it did. Fast. Smelly too. But fast and clean cuts.
Anyway, the above is my 2 cents and I hope it helps.
Cheers,
Eric
/ New Welder
AC TIG is Necessary to TIG Aluminum unless ...
Yep, kind of what I understand - makes a better pool.
My understanding is that the Pulsed MIG reduces splatter. This Old Tony (TOT) has a video that demonstrates his testing.
Hmm. You have me thinking hard. I appreciate the content and technical detail you wrote, and yes, I think the inverter technology has initiated quite a few changes, including a weight diet.
My Miller is currently bolted down on a 3-point custom flat platform (4' x 5') so I can take it and a generator anywhere my tractor can go. At times I also put the whole platform and generator in my pickup to transport to another property, again for 'mobile' welding.
What I miss with the MIG is refinement/control of penetration and material (wire) feed for small tasks, something where TIG seems to shine.
Lots to ponder. Still looking and considering. Certainly appreciate the thoughtful points brought out by all.
/ New Welder #11
I think it was worth getting the Pulsed MIG The pulse I use more on aluminum but have used it on steel as well and it does reduce spatter.
A feature less mentioned of the HTP Pro Pulse is the ST-arc.
I definitely noticed this MIGS ability to get deep into a corner (extended stick out) and make a really nice weld with Good penetration
from HTP website description:
The ST-arc function reads welding parameters back to the welding machine live (while welding), and monitors and keeps the arc length constant, while allowing the stick-out (contact tip to work distance) to vary. ST-arc, essentially, allows the new welder to focus on the location of the weld, as well as the travel speed, and also allows the experienced welder to keep a perfectly uniform bead and uniform heat input, which enables the welder to achieve good welds in tight corners—a feat that couldn't be reached previously with conventional welding equipment.
Here is some aluminum MIG in" double pulse In 4T" Zila welding.
If you plan on Migging aluminum I would get Pulse.
Later he switches to the HTP TIG to finish the tank
Welders definitely remind me of muscle cars, Speed costs money... How Fast do you want to Go?
Would really like to have a more "advanced" TIG in the Future.
My ancient sine wave IdealArc TIG does have plenty of current available though with a max of 375 amps.
No problem welding pretty thick metal, A new smart TIG would really make welding thinner materials easier with much better control.
/ New Welder #12
I guess I should try out the pulse feature on my Miller Mig. When I bought it it was configured for aluminum welding and had a 25 foot Python push-pull whip connected. It also came with another 25 foot Python whip for steel. I bought a 12 foot regular whip because I was welding steel mostly. But since folks here laud the pulse feature I should at least try it. And the guy I bought it from will certainly help me with the pulse feature if I ask.
Eric
/ New Welder #13
Eric
Yeah, I was surprised in just how "different" the arc sounds when doing any single or double pulse welding .
Process Sounds totally different.
Actually noticed myself laughing the first time I used it. (Made me giddy:)
The MIGs can Go into spray mode during the pulse phase. Gets more expensive on the gasses needed to.
To really do it right I need to get some 90+% Argon
I would definitely try out the pulse mode on your Miller. I think you will like it.
2020INTERNATIONAL MV607 4X2 S/A 26FT NON CDL BOX TRUCK (A59914)
2020INTERNATIONAL...
UNVERFERTH HT25 HEADER CART (A63291)
UNVERFERTH HT25...
2022 EZ-GO ELITE...
Case 1150G Dozer (A66285)
Case 1150G Dozer...
1995 Jeep Wrangle 4x4 Soft Top (A62613)
1995 Jeep Wrangle...
Kubota V3600-T-E2 Turbo Diesel Engine - 3.6L - 84 HP - 2018 - Tier 2 - Pump Takeout (A63689)
Kubota V3600-T-E2...
