Bentrim
Gold Member
- Joined
- Apr 22, 2020
- Messages
- 363
- Location
- York County, Pennsylvania
- Tractor
- Massey Ferguson 245, Massey Ferguson 14 Allis Chalmers G
Many years ago had a customer that complained his combine started pouring black smoke, out the pipe, from under the hood, had no power and would barely idle. He wanted a fuel lift pump installed as he knew that was the problem. Went to him and changed the pump restated the engine with the same issue. As I started and restarted the engine no change, until one time after shutting off the engine I heard a POP. Then I knew what was wrong. The air intake was a vertical pipe that stuck up above the hood, on top of it was a plastic air intake that it appeared someone either sat on it or a bale fell on it. As the sun heated the intake it got weak and as the clearance was reduced when the engine was in the need of more air it would collapse and shut off the air to the engine. I crawled on top of the hood and pulled the top as high as it would go. when I left the owner was back cutting grain.
