Smoke, rough running and no power above an idle
   / Smoke, rough running and no power above an idle #11
A filter is a maintenance item and never replaced until there’s a problem..
U can’t tell what’s going into the tank unless u filter it while it’s going in..
And there’s no telling how long it sat.. or the quality of it..
Parts cannon.. the filter is the least costly item on the machine.!!
jyoutz and thepumpguysc and Monster5601--
Forgive me for taking so long to respond. Busy with "stuff", all good.
jyoutz, you may well be correct. I haven't had a chance to touch it again after I stuck it in the garage.
thepumpguysc, I need more data! But, I agree that any time is a good time if the problem points one in that direction. So far, this problem hasn't done that for me, yet.
Monster5601, the previous time the problem happened I shut it down and the next day when I restarted it the problem was no longer present. That was about two years ago. (The dealer was not involved.) In that time, I've changed the oil and fuel and air filters.
To recap: When I cranked it up last night to put it up before the rain, it ran perfectly. When I get a chance--probably tomorrow--I will check the air filters before I crank it up. If I remember correctly, one of the air filters can be cleaned.
Thank all of you for your comments and help. I'll be baaack.
--Bill
   / Smoke, rough running and no power above an idle #13
I'm quite curious as to what the problem is, especially given that it seems to resolve itself... 😂
Seriously though, it seems like you've had solid luck with the machine, you've kept up on maintenance, and have had an overall positive experience with Mahindra- so this mystery is rather intriguing.
tacticalturnip--
Yes, I have had good luck with it. It is solid, no plastic; 5567lbs without an implement. But I am worried about parts supply. My former dealer--back in Kansas--dropped Mahindra because he said that dealing with Mahindra corporate was a nightmare. There may have been other reasons which I was not told. That happened almost three years ago. To date, I have not found another dealer.
My most used implement is the frame-mounted backhoe. We have 80 acres which was completely undeveloped when we built the house here, deep in the Ozarks. It is rocky. What a vast understatement! Only about 30 of our 80 acres is level, the remainder is composed of beautiful bluffs and cliffs with a very nice, very rough canyon in which there are many springs. The house sits on top of a cliff and a bluff that runs the full half-mile length of the property.
I used--and still use--the backhoe to thin the forest out on the cliff side of the driveway where the view is magnificent. I discovered very early on in my backhoe self-ed that a large stump and root ball are much easier to take out if the tree is still attached! I've also dug almost a thousand feet of ditches for water, power and sewer for neighbors.
I have a heavy-duty brush hog, which sees very little use . . . again, other than for neighbors. Next to the backhoe, my 7' box blade is also used extensively on the mile and a half long driveway, which was originally a logging "road."
Thank you for thinking about my problem, which I think may turn out to be trivial; probably filter-based.
--Bill
   / Smoke, rough running and no power above an idle #15
Bill, I don't believe in firing the "parts cannon" at a problem either, but inspecting (and replacing) filters should be part of diagnosis/troubleshooting process. If you have to remove your fuel filter to inspect it, you might as well put a new one on; it's no more work than putting a used one back on, and who knows what lurks in the pleats of the used one, unless you cut it open.
Checking the air filter(s) should also be part of your diagnosing, since a rodent could have built a nest, restricting air-flow to your engine, which is bad (for the engine) fuel/air mixture, and that could become a problem for the injectors.
If the fuel tank has a draincock, I would drain some fuel into a clear container, and have a close look. Bad fuel, algae, water contamination? How do you know unless you inspect.
Will S--
Good suggestions all. Thank you.
I would never remove a fuel or oil filter and put the old one back on.
We definitely have those rodents you mentioned! Draining some fuel is a good idea, thanks again.
--Bill
   / Smoke, rough running and no power above an idle #17
All--
I have a Mahindra 5545, 4wd. Today, it ran very well earlier, but when I started it to do a little backhoe work it began smoking from the exhaust and running very rough and would not produce any power. This happened a couple of years ago, as well. Back then, I had made up my mind to haul it to the dealer for repair. The next day when I started it up to load it on the trailer, it ran perfectly and has ever since . . . until today.
I am not a diesel mechanic. The limit of my abilities with the engine are changing oil, oil filter, fuel filter and air filters. I attributed the "self healing" to crud in the fuel filter. That's a guess.
Here is a short video demonstrating the problem. Will you please give me your diagnosis?
Thanks!
--Bill
This happened a couple of years ago, as well. Back then, I had made up my mind to haul it to the dealer for repair. The next day when I started it up to load it on the trailer, it ran perfectly and has ever since . . . until today.'
Reading that has me thinking shut off/fuel solenoid not opening all the way. An easy check would be to see if you are getting the needed amps to the solenoid.
That said another poster questioned the EGR valve and that is a real possibility too.
   / Smoke, rough running and no power above an idle #18
Sounds like bad fuel, water or contamination. Change filters and fuel and see what happens.
   / Smoke, rough running and no power above an idle #19
We run a Massey - not a Mahindra... last spring, I dumped 5 gal of diesel into the machine and it started doing exactly what is described here. It was bad fuel - it had been given to us because the guy who had it no longer had a diesel generator and he didn't know what to do with the 5 gal of fuel.
I flushed all the fuel, drained all the fuel from the filters and bowl, changed the filter, and put in fresh fuel. Once the bad stuff cleared the injection pump, my white smoke and all that was gone. Or so I thought.
Couple hours later, the smoke and loss of power happened again. Seems I left a small amount of the bad stuff in the tank. Once that blew out, I have put near a 100 hours on her with no more issues.
Used the bad diesel as fire starter.. amazing how the fire starts easy like one would expect with diesel and then all of a sudden a huge big Whoosh. I wonder if the guy who gave us the diesel dumped some gas in that diesel.
Lesson learned: get your own diesel! Don't take donations!
(Guy denies he mixed anything in that can but his face tells me he is not telling the truth, the whole truth, and nothing but the truth...)
   / Smoke, rough running and no power above an idle #20
When I have a rough running diesel or one that does not do full rpm or power, every time it has turned out to be a fuel issue. Based on my experiences, this is a list of quick points I go through.
1) How long since the fuel filter was replaced? More frequent change is required if there is algae or dirt/debris in the tank. You'd be surprised how much contamination occurs if a fill cap is missing for a short while or if it is windy and dusty when filling. I also ran into an algae problem from older fuel in my storage tank, then my supplier started adding more algaecide/algicide to their product.
2) Is there water in the fuel filter? Most have a drain to test without removal. Drain into glass jar to see what comes out. Water is normally introduced from tank condensation, but could be from the fuel source. Sometimes if the excess water quantity is limited, water will be burned as white vapor (steam) then the engine may return to running well for a while, only putting off the problem.
3) Are fuel lines and clamps/fittings healthy? I have seen OEM flexible/rubber fuel lines deteriorate to the point where the lines start to be "wet" where they are under some pressure. But what about killed my patience was when all of the bad lines were replaced and I threw up my hands in disappointment and confusion - then I realized that some lines were under vacuum and were allowing air to be circulated in the lines and through the injector.
4) Is there a fuel pump that circulates fuel to make filtered fuel available to the injector? Most diesels may be this way. If so, test the output from that electric pump by letting the output line flow into a jug. Once I had one what worked when I turned the key, then didn't work when I turned the key, then was sporadic when I turned the key -- replacement solved that problem.
LIMA MAC 60KW GENERATOR (A58214)
LIMA MAC 60KW...
1449 (A57192)
1449 (A57192)
Sedan (A59231)
Sedan (A59231)
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A59228)
2006 iDrive...
Unused 2025 CFG Industrial XZ20R Mini Excavator (A59228)
Unused 2025 CFG...
1999 WEST WIND 30FT PINDLE FLATBED DOVETAIL TRAILER (A58214)
1999 WEST WIND...
