Flail Mowers
/ Flail Mowers #21
I've had both behind an 18HP tractor. They both did what they were supposed to, but the rotary mower ended up being better suited to my needs. One thing to consider if you're starting and stopping often, depending upon the type of transmission your tractor and PTO have, they may be a delayed "start up" for the mower itself. You may have to drive forward ten or so feet before the flail mower has spun up to cutting speed. If you transmission is arranged as such, it's not possible to do the first bit of cutting away from being stopped. It was for this reason I changed to rotary, it cut as the tractor rolled forward.
/ Flail Mowers #22
Where do you think it shines the best?
It will depend on the blade type first off.
I think in general a flail is better for lower grasses and brush, viney types of vegetation. I find it tends to lay over small saplings and stiff, hard stalk grasses so a few passes needed in areas.
My large John Deere flail has the scoop or duck foot type blades and does a nice job mowing an open field. But make sure there is no debris and especially rock or the like.
My small one with side slicer blades does good on just grass but even small sticks can mess the blades up.
I am still fighting with my one with hammers as it broke hammers on its first outing. Hope to have it going this week to test on a field that is heavy, clumpy type grasses and thorn bushes.
/ Flail Mowers #23
I won't pretend to be an "expert" but... I have a 55hp tractor (others have larger, others have smaller- if you're looking for information that's more close to what your configuration is then I'm close)
I've run a 5' RC from a B7800 for many years. A light-duty RC; I put it through pure heck and other than a couple of shear pins and a tail wheel it just did whatever I needed.
More and more clearing, as well as the need for some more lift capacity, led me to buy my Kioti NX5510. I bought a used 6' Bush Hog RC for it: it had been used commercially and was insanely hammered, but still functional (I've replaced the PTO shaft with a new/heavier-duty one and have had to repair the tail wheel and do some work to keep the stump jumper on the darn thing). I researched flails as I was wanting to increase mowing width (due to increasing amounts of grass areas) and didn't want a longer tail sticking out behind me (6' is enough; 7' RC isn't what I'd want). I have two other factors to consider: 1) Ditches- I needed a better way to mow out over the edges; 2) LOTS of trees (not a forest, but lots of navigation) which requires lots of turning and such. Last year I bought a 7' hydraulic-offset flail with hammers. After a couple of shake-out issues (new equipment issues- loose bolts etc.) it settled down and worked very well. I won't get rid of my 6' RC (or the 5' RC [now a different one] that's used on my B7800), but my go-to grass (and lighter brush - supposed to handle up to 3" [or 2"?] dia material) is/will be the flail. It's better at the tasks I need to perform. Yes, flails require more maintenance. Weigh it all up. Oh, I will look to use my 6' RC first mowing (spot-mowing) to hit really nasty woody debris: I also look to do a bit more clearing, though outright clearing is really starting to come to an end as I have less clear-able areas.
The hydraulic side-shift makes it easier to work around my fence posts. Not uncommon to find that you're pinched a little too close to something and the hydraulic-side shift allows you to adjust w/o having to make big navigational adjustments on the tractor (with RCs it wasn't uncommon to have to actually back up and get swung further away to keep from getting hung up on something).
If I had wide-open hay/grass fields then perhaps a multi-spindle RC. But, all is not created equal- there's no such thing as a one-size-fits-all. I was amply familiar with my property (and had spent MANY hours running RCs) by the time I made the big leap to my flail.
Flails generally don't like tall grass, but for a test I did find that I could mow upwards of 5': I once did 9'+ with my B7800 and that light-duty RC- can you say S-L-O-W-going? Not sure if this is/was possible because of hammers instead of knives.
I've put my flail through enough in the first year to confidently say that I have no worries about breaking a hammer: despite all that I put it through I didn't break a single one (vendor gave me a few spares for free). Might have killed a few knives if I'd had them. I do not have really rocky land (mostly just smaller rocks- some areas have fill with larger rocks but these aren't an issue).
Hammers don't do too bad of a job on grass (this is in the homestead area, which I want to look a bit less wild; RCs and flail both produce good enough results for me; far less clumping with the flail, which I like):
Another benefit of the flail is that it's great for ballast (mine's 1,200#). Off-season I need to shuttle firewood crates to my deck.
/ Flail Mowers #24
What brand and model of flails do you have wirly?
/ Flail Mowers #25
I am sure this question has been asked a million times but when I did a search I did not see any discussions on it, but, can a flail mower on a compact (50hp) tractor do the same job as a rotary mower. I would like something in the 6' size. The main advantage I see is the safety (less thrown objects and weight closer to the tractor). I don't necessarily have to have a nicer looking cut as it will be in a pasture. I have seen some that will cut 2-3" woody plants so it looks like they are certainly stout enough to handle most things the rotary mower will cut. I have looked for videos and the verdict is not really clear to me. I can find just as many people that prefer rotary as I can that prefer flail. Thanks for any help. If anyone has a link to another discussion, please post it. I will be cutting on some hilly areas and anything that may make the tractor a little safer is worth investigating.
I have a 6ft brush hog and a 6ft flail mower. The flail mower leaves a nicer cut but takes twice as long per pasture since I can only go 1/2 as fast without it bogging down. I use the flail mower in the areas my wife can see from the patio, and the brush hog everywhere else so I can get done before dark.
/ Flail Mowers #26
We have very little to go on about your overall circumstance and what might be best for you. The simple direct answer is YES, you can certainly run a 6ft flail mower with a 50 hp compact or lower medium sized tractor. BY FAR the larger question is "Should you?"
I have both flail and rotary mowers. With a 50 hp tractor your best universal bet is a good solid 6ft bush hog. I own Bush Hog brand and have owned John Deere MX6. They are all very good. Some details make one more likeable than another of course. But I think you are much better off sticking with a rotary mower. It is way more universal, much less sensitive to the occasional accidental rock hit, more durable for larger diameter material, etc. With a flail configured for routine pasture cutting you will end up hitting a hidden post or 2 or 3 inch thick limb or a brush covered rock etc. and you will be doing flail knife replacements more than you would like. Bush Hogs are so much more durable in random consistency pasture cutting than a flail will ever be. Flails are VERY nice when you have open fields with not much chance of obstacles and mainly grass and weeds that have been cut over many times. Otherwise go with the rotary cutter.
/ Flail Mowers #27
I used this on my cattle pastures under fences and it does an amazing job. It side shifts to the left or right 2 feet!
How is this adjustment done? Could you please provide a picture of it? thank you, and thanks for all the other photos you posted.
/ Flail Mowers #28
It has arms that hydraulically pivot 2’ to the left, back to center and then 2’ to the right. It is infinitely adjustable. It pulls exactly and cuts exactly like a fixed, 8 foot bush hog. Liked it a lot when I owned it, but became too small for my needs about 10 years ago.
/ Flail Mowers #29
I have a 6' ditch bank flail. It is the only thing I have to cut my ditches with or some of the banks. I also use it to mow under some of my trees with low limbs.(my wife does not want cut) I still have my 5' RC and use it most of the time. I find the flail mows slower. That may be to what I am cutting.
/ Flail Mowers #30
40hp L4060hstc, 1,500lbs 7.2' wide Peruzzo Brush Bull 2200 (green).
It's a bit big for my machine & I wish I had more HP. But it does the job fine, if a bit slowly in heavier grass or brush. The weight is as big of an issue as the width. If you lack HP you just do half width cuts or go slower.
32hp on the old L3200 with a much lighter old Ford 917 (beat up yellow). Slow but got the job done as well. Better than a skinny flail & driving fast over rough ground to cover the same acres per hour.
/ Flail Mowers #31
32hp on the old L3200 with a much lighter old Ford 917 (beat up yellow). Slow but got the job done as well. Better than a skinny flail & driving fast over rough ground to cover the same acres per hour.View attachment 740834View attachment 740835View attachment 740836
What blades are you running on the 917?
/ Flail Mowers #32
Y side slicers. Mostly replacements from flailmaster. They cut well, but struggle with brush thicker than your fingers.
The old beat to hell (bought it for $100) 719 still works but has been parked for a few years. Replaced it with the much heavier & new Peruzzo a few years back.
/ Flail Mowers #33
I wouldn't have my flail if it took me twice as long to mow as with my RC. I suspect that it's grass type and blades where people have struggles. I have hammer flails, so maybe that's why I can mow faster? Cut quality is about as good as the RC, and better overall without clumping. And when mowing along ditches there's no comparison- RC sucks, flail with side-shift makes this easy and fast.
Summary:
Tractor: Kioti NX5510 - 55hp, PTO 43hp
Fail: Nova Tractor MXZ220 - 7', 1,200 lbs
RC: 6' Bush Hog 286(? escapes memory right now- it's an older one) approx 1,000 lbs
/ Flail Mowers #34
Please explain why.
Good Morning Cahaba Valley Farm,
A 48 inch finish cut flail mower is no different than a 72 inch finish cut flail mower because they use a high centrifugal speed of 2,200 RPM +- to mow and recut brush, grass or when recutting grass clippings.
A finish cut flail will have 4 rows of side slicer knives to finely clip the grass/brush and recut the brush/grass as it passes over it by creating the pressure gradient/suction to lift up the grass and brush as it passes over it.
A 72 inch rotary mower will only being using 36 inches of cutting edge at any time to tear the grass blade off.
A finish flail mower with 4 rows of side slicer knives will make use of 48+- inches of cutting edge per foot to clip the grass blade to accomplish the same job. A 2 edge side slicer knife will give you 96 inches of cutting edge per foot.
/ Flail Mowers #35
Hey Fallon -- what's with the big hole cut across your yellow flail cutter? Is there a story that goes with it ?
/ Flail Mowers #36
Summary:
It probably varies with what you are cutting (obstructions, having to go slow in awkward places, etc.) as to speed.
I use an 88 inch flail part of the year over the same pasture fields that I cut with an 84 inch Bush Hog. Pretty much apples and apples comparison, especially in the grassy non-brush areas. I find the flail noticeably faster (maybe 20% faster?) out of proportion to the extra few inches of width. I'm using a MF2660 81 horse tractor which handles either one with equal ease. I find the flail faster with the same tractor and same grass/weeds. This may be in part because it seems more comfortable to run a little faster ground speed with the flail than the hog ?
/ Flail Mowers #37
I paid $100 for it... the back of the hood was dented pretty badly & it was missing some knives. Pretty sure they had been removed intentionally due to hitting the hood. I cut out the bad parts in back then welded a patch over the hole.
Hood is still cracked along the braces on one side & I never bothered repairing that. Roller height adjustment had been welded in place years before I got it.
Rotor bearings failed a year or 2 before I replaced the unit. Gearbox was leaky & I put pourable grease in it rather than replace the seals. Probably $500 into it total for 5 years of light commercial use. I upgraded to a MUCH more expensive & beefy Peruzzo a few years ago. The old beatup Ford flail was a great start but I've upgraded. Still keep it around as a backup.View attachment 742072
  • Good Post
Reactions: JWR
2025 Swict 78in. Bucket Skid Steer Attachment (A61572)
2025 Swict 78in...
2025 Fabrique 12' x 6' Dump Trailer (A62613)
2025 Fabrique 12'...
2019 Ford F-250 Ext. Cab Pickup Truck (A61573)
2019 Ford F-250...
2013 Bomag BM-211D Single Drum Vibratory Soil Compactor (A61572)
2013 Bomag BM-211D...
2007 FREIGHTLINER M2 4X2 S/A STAKE BED TRUCK (A59912)
2007 FREIGHTLINER...
2010 Doyle 32ft Tender Trailer - Kubota Diesel - Stainless Steel Augers - Recently Refurbished (A61307)
2010 Doyle 32ft...
