etpm
- Joined
- Jun 30, 2021
- Messages
- 2,397
- Location
- Whidbey Island, WA
- Tractor
- Yanmar YM2310, Honda H5013, Case 580 CK, Ford 9N
My YM2310 starts fairly fast even in cold weather and the Thermostart is broken. In warm weather it starts almost instantly. I recently got my tiller connected and when tilling at about 2000 RPM I can see some black smoke coming out of the exhaust. Not tons but I can see it. If I raise the RPM a little, to maybe 2100 RPM, the smoke decreases. If I let the RPM drop to about 1800 RPM when engaging the tiller fully in the ground and tilling the smoking will increase. It looks to me like a big increase. But what do I know? This is my first diesel machine. And the machine is 42 years old after all.
When doing other chores with the tractor which put less load on the tractor it really doesn't smoke much. And I know this is also a subjective thing. So, is there any thing I should be concerned about?
Before I bought it late last summer the seller said it had been sitting for two years without being started. The vegetation that had grown around it and the rodent nesting activity around the gas tank were also indicators that it had been sitting idle for some time. The seller told me he put the battery on a charger but that it wouldn't turn over and that I was welcome to figure out why. If I could get it to turn over he would sell it to me for the agreed price. I figured out the electrical problem and the thing started up almost instantly. It was hot that day, probably about 90 degrees. I used the directions in the manual and was so surprised by the quick start that it took me longer than it should have to back the throttle off to 1000 RPM.
So the upshot is that the tractor starts and runs well and is owned and operated by someone who is pretty ignorant when it comes to practical diesel engine operation. I do use some sort of additive that is supposed to clean the injectors and increase the cetane. Maybe that's why it starts in cold weather here, about 30 miles north of Seattle. Since I bought the tractor near the end of last summer I have only put about 35 hours on the tractor, so maybe the moose pee I have been adding to clean the injectors needs a little more time to work. Or maybe everything is OK and I'm concerned about nothing.
Anyway,
Thanks,
Eric
Anyway,
Thanks,
Eric
