Max 26 Diff lock stuck
/ Max 26 Diff lock stuck #1
Tim in MN
Floodwood, MN
Allis Chalmers WD, Mahindra Max26
I've got a 2019 Max 26KL with the diff lock stuck in the engaged position. It happened yesterday when putting up driveway markers. I've tried moving the shaft with a pair of pliers, no luck. Sprayed the shaft and housing with penetrating oil in case it's rusted, still no luck. Anybody got any ideas on how to get this thing freed up? Of course it had to happen when the weather is in the teens now.
/ Max 26 Diff lock stuck #2
Hi Tim, I would make sure it is out of 4wd then drive forward and back a few times in a straight line. Maybe try forward/reverse quickly....may release the tension. Don't need tension 'ya know ;)
Thanks Jo, I'll give it a try.
/ Max 26 Diff lock stuck #4
If you can get the rear wheels off the ground it should completely alleviate any tension in the rear end. You could independently spin the wheels to help if needed.
/ Max 26 Diff lock stuck #5
go up and down some hills, push in clutch a couple times, do some turns forward and reverse. you should be proud you got it in, what a pain in the ass.
OK, tried all your suggestions, it's still stuck in the engaged position. When I had it jacked up I had a pair of pliers on the locking shaft and tried to move it while I was moving the rear tires back and forth, still locked. Probably going to have to take it in to get fixed, still under warranty, I'm assuming this will be covered under the powertrain, I hope.
/ Max 26 Diff lock stuck #8
The diff lock stuck on my 2615 also. Had to use a pry bar under the pedal to raise it up and 2 cans of penetrating oil where the linkage goes thru the case. Had to do this many times raising the pedal and pushing it down to get it freed up. My main cause was lack of use and had never lubed that linkage before.
Haven't talked to the service guys yet, calling them in the morning. But if it's the case like George2615 I'll keep up with the penetrating oil and see what happens. I hate working in the cold.
/ Max 26 Diff lock stuck #10
so the shaft doesn't move at all? or it moves but stays engaged?
Nope, will not move at all. Was just thinking about using a heat gun on the housing and tapping the shaft with a hammer to see if it will break loose. I don't use the diff lock that often, and like George said probably just rusted in the housing.
/ Max 26 Diff lock stuck #12
yea i think you have something else going on, my tractor was 5 years old when i got it, the diff lock lever didn't even have a scratch on it, meaning it was never used, it had 0 trouble moving. do you see high levels of corrosion?
Nope, no corrosion. The diff lock shaft runs through a piece of octagon sleeve about 2 1/2 inches long, the sleeve screws into the main trans case, that's where I think it's rusted. The sleeve takes a 22mm wrench, of course it won't move either. Heated the sleeve with a torch and sprayed with penetrating oil, did this 3 times to get the oil to wick into the sleeve. Calling one of the bigger dealers, mine just sells Mahindra as a side business.
/ Max 26 Diff lock stuck #14
I had that happen to my 3016, I got mine to move with pliers and I sprayed it a few times, I also put a spring on it to keep it disengaged cuz it seems they always get stuck in the engaged position. I also learned that when I helped my uncle split his 3215 Gear that the diff lock was seized as well, we got it out and used emery cloth to clean it up. its just a hole through the axle housing, no seals or anything to prevent moisture from entering just tightly machined just enough to slightly rotate.
/ Max 26 Diff lock stuck #15
We have a 90 HP NH at work and the same thing happens all the time no matter how much you lubricate it
Well, it's working correctly again. Evidently the penetrating oil did it's job. Took it out 2 weeks to blow snow, the lever was up again and just one rear wheel spun when it started to get stuck. I'm thinking that if I can get a drill in there I'll drill a hole in the shaft housing just enough to get to the diff lock shaft and put a zerk fitting in. Keeping grease in there will keep it from rusting up again. Thanks for all the advice you guys have offered, it was really appreciated.
/ Max 26 Diff lock stuck #17
Hope the differential lock doesn't stick anymore! And thanks for the update.
/ Max 26 Diff lock stuck #18
Yea Tim, thanks for the update! Spring is just around the corner... :unsure: . Still lotsa snow in the woods here!
2015 Ford Fusion Sedan (A64557)
2015 Ford Fusion...
1978 Fruehaue Chipper Trailer (A62613)
1978 Fruehaue...
Hyster 50 5,000lb Propane Forklift (A64553)
Hyster 50 5,000lb...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A63569)
2020 TROXELL...
2017 Ford F-150 Pickup Truck (A64556)
2017 Ford F-150...
2016 Dodge Grand Caravan Van (A64557)
2016 Dodge Grand...
