I'm going to buy a rotary pump
/ I'm going to buy a rotary pump #1
Raul-02
the armpit of the entire universe New Jersey
kioti DK4710 SE HST CAB
/ I'm going to buy a rotary pump #2
I have a Kubota but it also has the ability to dump the hydraulic fluid during filter change. However, if I put my shop vac on the filler port and pull a partial vacuum it overcomes the atmospheric pressure and I lose very little beyond what's in the filter. I've also read that if you plug the hydraulic vent line you will dribble out very little fluid. Have the new filter ready and move fast to help reduce loss, too.
/ I'm going to buy a rotary pump #3
For my next hydro filter change. I lost over 5 gallons. Stuff is too damned expensive to treat like that.
Good thing I have a dust collection system in my woodshop because I needed all that sawdust in a hurry
Got any recommendations?
This one looks like a contender
Get a larger drain pan. I always change the fluid when I change the filters anyway and each of my tractors take almost 15 gallons. In my view, changing the filters and not the fluid is an exercise in worthless.
  • Good Post
Reactions: JJT
That would do the trick. and any atmosphere entrained in the oil will outgas as soon as it gets hot.
more than one tractor and 15 gallons @. It would be well worth it to send a sample to a lab to see if it is breaking down. Why change good oil?
/ I'm going to buy a rotary pump #8
The shop vac thing is ideal. I use it when situations suggest.
Recreational fluid changes are a real thing. Feels good sort of deal.
Remember when car engine oil was changed every 3K miles, and filters every other oil change?
My how time flys.
/ I'm going to buy a rotary pump #10
I've never used a shop vac to pull a vacuum on a gearbox because, it you have a weak seal, you'll suck the seal lips in and it will leak. Both my M's are older. I cannot take that chance.
/ I'm going to buy a rotary pump #11
Technology is the answer!
What was the question?.....
You can reduce both the CFM flow and the inches of mercury of a vacuum hose by using a little piece of tubing with a hole in it on the vac hose.
About those seals ,,,,,,, Aren't they all O rings? No amount of vacuum can dislodge them. You can't get more than 15 PSI of differential pressure.
2012 MACK CHU (PINNACLE) (A60736)
2012 MACK CHU...
30 INCH TOOTHLESS BUCKET FOR MINI EXCAVATOR (A58214)
30 INCH TOOTHLESS...
2004 FORD F-350 SUPER DUTY (INOPERABLE) (A58214)
2004 FORD F-350...
2014 International WorkStar 7300 4x4 Altec A55F 55ft. Material Handling Bucket Truck (A60460)
2014 International...
CAT 336E (A58214)
CAT 336E (A58214)
EZ loader trailer (A56857)
EZ loader trailer...
