I'm going to buy a rotary pump
   / I'm going to buy a rotary pump #11
Technology is the answer!
What was the question?.....
I've never used a shop vac to pull a vacuum on a gearbox because,
You can reduce both the CFM flow and the inches of mercury of a vacuum hose by using a little piece of tubing with a hole in it on the vac hose.
About those seals ,,,,,,, Aren't they all O rings? No amount of vacuum can dislodge them. You can't get more than 15 PSI of differential pressure.
1980 Gleaner F2 with heads (A56436)
1980 Gleaner F2...
2012 COMPTANK ACID TRANSPORT TRAILER (A55745)
2012 COMPTANK ACID...
2021 Caterpillar 308CR Midi Excavator (A55973)
2021 Caterpillar...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2013 Ford F-150...
2017 Komatsu PC490-11 Hydraulic Excavator, S/N A41596, PIN# KMTPC251JHWA41596, Turbo Diesel Engine, (A59076)
2017 Komatsu...
Club Car Electric Cart (A55758)
Club Car Electric...
