I'm going to buy a rotary pump
   / I'm going to buy a rotary pump #11
Technology is the answer!
What was the question?.....
I've never used a shop vac to pull a vacuum on a gearbox because,
You can reduce both the CFM flow and the inches of mercury of a vacuum hose by using a little piece of tubing with a hole in it on the vac hose.
About those seals ,,,,,,, Aren't they all O rings? No amount of vacuum can dislodge them. You can't get more than 15 PSI of differential pressure.
2011 DOOSAN G25KW GENERATOR (A55745)
2011 DOOSAN G25KW...
RoGator RG1100C (A56435)
RoGator RG1100C...
2007 Amkus Rescue System (A56857)
2007 Amkus Rescue...
402 (A52706)
402 (A52706)
2017 Bobcat T450 Compact Track Loader Skid Steer (A56857)
2017 Bobcat T450...
2016 JOHN DEERE 135G (A58214)
2016 JOHN DEERE...
