Need rivet gun recommendations
/ Need rivet gun recommendations #1
coloradotrout
Gold Member
Eastern KS
JD 4100 HST CUT w/Yanmar 3TNE74 | JD 300 Lawn
Looking for all-around non powered rivet gun. I'm going to install gutters on my barn. Then who knows what all uses I may have. Automotive, around the house, etc.
/ Need rivet gun recommendations #2
They are a very simple tool and for your described use anything should be fine that HD or Lowes has.
/ Need rivet gun recommendations #3
Marson HP-2 is a real good one. After 30 years of use at the dealership, the pulling jaws on mine finally broke. Just have to order a new set.
And now after searching, I might consider air powered. Some suggest harbor freight is even ok
/ Need rivet gun recommendations #6
As cheap as they are....
For my use it's not worth fooling with an air hose and I can see it just not fitting the riveting position in many situations.
/ Need rivet gun recommendations #7
For 1/8" aluminum i find hand powered is fine unless there are grip strength issues with user. I recomend one of the swivel head types. I use pneumatic on the 3/16 and up stainless that i use on trailer and tool box hasps and latches. The SS are a bit harder to set.
If running gutters, i suggest a punch for the holes instead of a drill.
/ Need rivet gun recommendations #8
While the HF air powered rivet gun works fine although the hose is always in the way, I went with the Milwaukee M12 rivet gun, the thing is amazing! I can't tell you how many rivets it will do on a charge but it's a lot. I know it's a bit of money but if you are going to any larger rivets or a lot of smaller ones then I highly recommend it.
Leaning towards a quality hand one. 3/16 seems to be max, but that surely is plenty
/ Need rivet gun recommendations #10
For installing gutters, why not use self drilling/tapping screws?
I couldn't justify buying a new toy ;)
/ Need rivet gun recommendations #13
Hand model is easier to use, no compressor to drag out, no drop cords and no hose. Air maybe faster but the time you drag all that out to use it then store it. Then if you are where working near no power, then you got to get the generator out.
/ Need rivet gun recommendations #14
The usual mechanical pop rivet guns are good for common aluminum rivets.
I use a small hand Huck hydraulic for SS, steel and large aluminum/steel mandrel pop rivets. Also have same that uses air over hydraulic. Surplus aircraft manufacturing eBay finds.
/ Need rivet gun recommendations #15
When I built my ice fishing shack, I used a lot of rivets. The stainless ones were a tad tough for a hand unit. Purchased an air powered one from Princess Auto. Great investment.
/ Need rivet gun recommendations #16
Buy pneumatic. Hand units get tougher as you age.
/ Need rivet gun recommendations #17
These I've had good luck with, and what gutter installers just used on the horse stable.
/ Need rivet gun recommendations #20
The drill powered unit I purchased has been useless. Also, I have given up trying to work with the short-handled units. By far the best are the log-handled riveters.
They come with either 2 or 3 collets and they all jam sooner or later, so you will find the 2-collet version much easier to reassemble because these drop nicely unto place, whereas the 3 collet models invariably don't and it may take several attempts to get to align correctly
Any reputable brand will do
Unused 2023 Land Pride RCF2060 5ft. Rotary Brush Cutter Tractor Attachment (A66734)
Unused 2023 Land...
AIR OPERATED OIL PUMP APROX 200 GALLON TANK (A67714)
AIR OPERATED OIL...
2018 HINO 338 4X2 S/A 26FT FLATBED (A59912)
2018 HINO 338 4X2...
2012 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A67714)
2012 DRAGON 150...
2011 CHANDLER TRI AXLE SPD-18 WATER HEATING TRAILER (A67714)
2011 CHANDLER TRI...
FUEL TANK (A68842)
FUEL TANK (A68842)
