Need rivet gun recommendations
   / Need rivet gun recommendations #1
coloradotrout
Gold Member
Eastern KS
JD 4100 HST CUT w/Yanmar 3TNE74 | JD 300 Lawn
Looking for all-around non powered rivet gun. I'm going to install gutters on my barn. Then who knows what all uses I may have. Automotive, around the house, etc.
   / Need rivet gun recommendations #2
They are a very simple tool and for your described use anything should be fine that HD or Lowes has.
   / Need rivet gun recommendations #3
Marson HP-2 is a real good one. After 30 years of use at the dealership, the pulling jaws on mine finally broke. Just have to order a new set.
And now after searching, I might consider air powered. Some suggest harbor freight is even ok
   / Need rivet gun recommendations #6
As cheap as they are....
For my use it's not worth fooling with an air hose and I can see it just not fitting the riveting position in many situations.
   / Need rivet gun recommendations #7
For 1/8" aluminum i find hand powered is fine unless there are grip strength issues with user. I recomend one of the swivel head types. I use pneumatic on the 3/16 and up stainless that i use on trailer and tool box hasps and latches. The SS are a bit harder to set.
If running gutters, i suggest a punch for the holes instead of a drill.
   / Need rivet gun recommendations #8
While the HF air powered rivet gun works fine although the hose is always in the way, I went with the Milwaukee M12 rivet gun, the thing is amazing! I can't tell you how many rivets it will do on a charge but it's a lot. I know it's a bit of money but if you are going to any larger rivets or a lot of smaller ones then I highly recommend it.
Leaning towards a quality hand one. 3/16 seems to be max, but that surely is plenty
   / Need rivet gun recommendations #10
For installing gutters, why not use self drilling/tapping screws?
2013 Chevrolet Traverse AWD SUV (A56859)
2013 Chevrolet...
Galvanized Livestock Wire Gate - 4FT x 11.5FT (A55315)
Galvanized...
1998 Homemade S/A 12x6.5ft Trailer (A56859)
1998 Homemade S/A...
2023 PJ Dump Trailer (A55973)
2023 PJ Dump...
2014 Ford Fusion Sedan (A56859)
2014 Ford Fusion...
2017 FREIGHTLINER CORONADO SD122 DAY CAB (A56138)
2017 FREIGHTLINER...
