Shop Lift
/ Shop Lift #1
woody
Central Alabama
Kubota B26, Kubota ZG222, Kubota L45, 1980 Ford 1700
After changing the oil in the wife's car and rotating the tires the other day I was so sore from getting up off the ground and just a week or so before that I changed the oil in my TriGlide and hurt for a few days, I decided on getting a shop lift for all my equipment. I have not received it yet should be about three weeks or so. I have talked about it for years but would not spend the money and the other day I ran across a Wildfire four post lift. The more I looked at it the better I liked it and my sweet wife said get it if you want it so I ordered it before she found out how much it cost :giggle: What do you guys have and what kind of accessories?
/ Shop Lift #3
I have a Challenger 2 post 9K lift, Sice tire machine, Coats computerized balancer, 80 gallon Air Compressor, motorcycle lift, and too many more tools, scanners, radiator pressure testers to mention. Good luck with your 4 post. A friend of mine has one and likes it a lot.
/ Shop Lift #4
I have a Bendpak 14K 4 post lift I use for storing implements:
When I ran out of floor space, it was cheaper than a new pole barn.
I also have two Bendpak 8K 4 post lifts in one of my other buildings:
I use one for storage and the other for working on vehicles:
No more laying on my back under a jacked up vehicle. My creeper hasn't been used in years.
Size & weight were a problem for local delivery. I had them shipped to a local freight yard and picked them up with my 10K trailer.
/ Shop Lift #5
I personally have a 10k bendpak 2post and a 10k mohawk 2post lift. Used a lot of other brands and styles as I worked in the auto repair industry for years, even did installs for a few lift companies for about a year.
Only accessories I have is various adaptors for the lift arms.
I've installed a few of the portable style 4 post, did you get sliding lift jacks or at least the trays that you can put a jack in?
Sent from my SM-G715U1 using TractorByNet mobile app
/ Shop Lift #6
Depends on what you need to lift up. 10k is fine for me. I'm going to have a Rotary 2 post put in my shop.
/ Shop Lift #7
I have an old Forward 12K four post with 2 air jacks. I fell into this hoist for $400 without jacks. Then fell into two air jacks for $400. Fortunately both my Sons have 2 post hoists I can use if needed. I prefer the four post.
/ Shop Lift #8
My neighbor has a lift due to space constraints to park 2 classic muscles cars in his tall 2 car garage. The life works nicely for that.
I do like reading about the lift used for tractor implements. That's a new way to look at things.
/ Shop Lift
Thanks for all the replies and ideas I am really looking forward to getting the lift. I decided to get a four post so I don't have to get down on the ground to line up the lift every time I need to put something on the lift.
/ Shop Lift #10
ovrsd -
How tall is that ceiling?
/ Shop Lift #11
With a four post, you may be limited by the various track width of the vehicles you wish to lift, and obviously - brake/suspension and tire work will be more of a hassle.
/ Shop Lift
I didn't order the air jacks and I don't know how much I may need them, but I like the idea of raising the equipment up to working height before trying to jack it up if needed.
/ Shop Lift
I did get the sliding jack tray, is that more for holding like a bottle jack and tools?
/ Shop Lift #14
Yes, I didn't look at the Wildfire version, but if it's called a jack tray it's for putting a jack (typically bottle) in to lift the vehicle up to remove the wheels etc. They aren't as nice/safe as the rolling air jacks but will typically get the job done.
/ Shop Lift #15
I bought a 9000# 4 post Bendpak about 10 years ago. I should have bought it sooner. I'm thinking about adding a 2 post lift this summer. No regrets and no accessories other than a 20 gallon drain pan on rollers.
/ Shop Lift #16
I have the jack mount tray and occasionally use a bottle jack but the rolling jack was half the cost of the lift. I don't do transmission work anymore so I didn't think it was worth the $$
/ Shop Lift
That's what I thinking to much money for how much I would use it. I may shop around and see if a different one will fit.
/ Shop Lift #19
With air jacks a four post is better than a two post for brake/suspension/tire rotation, etc. work. Biggest bonus is a parts/tool tray.
/ Shop Lift #20
If the hoist comes with the rails for the jacks you can fab a simple C channel to span the rails, then use a bottle jack. I used this method for about six months until I scored my air jacks.
2017 ISUZU NPR 18 FT  BOX TRUCK (A59905)
2017 ISUZU NPR 18...
2021 Peterbilt 389 Sleeper Truck (A62613)
2021 Peterbilt 389...
New/Unused AGT Industrial SDA-140W Mini Wheel Loader (A65579)
New/Unused AGT...
New/Unused Landhonor Hand Chain Lever Hoist (A65583)
New/Unused...
2017 Bobcat MT85 (A64126)
2017 Bobcat MT85...
2007 Ford F-750 Water Truck w 2,000 Gallon Tank (A63689)
2007 Ford F-750...
