First time buying a tractor tips?
/ First time buying a tractor tips? #1
Rbp_280z
None Yet
Hi everyone,
My family and I bought our first property on 10 acres. We need to get our first tractor for to do a few various tasks: drilling holes for fence posts, creating a fire break, plowing, mowing the lawn, moving soil, etc. the tractor will stay at our property and will be used maybe 2-3 a week.
I’ve never shopped for a tractor before so I wanted to get some advice before going to the dealerships. We wanted to buy a brand new one so we can finance it. We are in Dixon California.
  • What brands do you recommend?
  • What size tractor would you recommend?
  • Are you able to negotiate on pricing for tractors or ask for attachments? Do dealerships have tractors ready to be taken home or are they built to order?
  • Are there any other tips you recommend on buying and owning a tractor?
/ First time buying a tractor tips? #2
My family and I bought 10 acres in California.
Is this ten acres flat and smooth, or sloped? Rough land and sloped land requires a wider, heavier tractor for stability.
Will all ten acres be worked with the tractor, or only part?
The design of the Three Point Hitch tractor has been marketed in the USA since 1939 -- 83 years in 2022.
The basic design is generic.
Kubota and Deere have most of the market through 6,000 pound bare weight tractors. But this Kubota/Deere predominance is regional.
The up and coming tractor brands are Korean: Kioti, LS and Branson. There are other Korean brands. You have to critically assess dealer stability while shopping minor brands.
Korean manufacturing labor is paid ~50% of what Deere pays its union work force. Japanese manufacturing labor is paid ~70% of what Deere pays its union work force. Labor costs strongly influence tractor prices.
We have the following brands within an hour of us.
  • Kubota
  • LS
  • TYM
  • KIOTI
  • Massey Ferguson
  • John Deere
I know that a lot depends on the dealer and their willingness to help, but should I stay away from any of these brands?
Start with the nearest dealer and work out.
Transporting a tractor for service is expensive and inconvenient, whether you trailer the tractor or the dealer trailers it.
CREDIT: 'FELIXEDO'
"It has been touched on a couple of times, but not directly as a buying factor.
Every major make has a machine that will do the job(s) you want. Check out your nearby dealers, and go with one you have confidence in.
A great machine with no support nearby is a hassle to repair and maintain.
And a good machine can't make a lousy dealer into a good dealer."
Do you have any tractor operating experience?
What about a kitchen garden? Game food plots? Moving feed?
Will you plow dirt, snow, or both?
At present factory output is limited and demand is strong. Most new tractors sell at MSRP during 2022. Tractors are available with a huge number of confusing options. We can couch you through pros and cons of options. Tractor are mostly ordered then delivered after three to six months.
You should be able to test ergonomics of various tractor models at the dealers. You will spend many hours in the tractor seat operating over rough ground. Be comfortable.
The fundamental importance of TRACTOR WEIGHT eludes many tractor shoppers. Tractor capability is more closely correlated to tractor weight than any other single specification.
The most efficient way to shop for tractors is to first identify potential tractor applications, then, through consulataton, establish bare tractor weight necessary to safely accomplish your applications. Tractor dealers, experienced tractor owners and TractorByNet.com are sources for weight recommendations.
Sufficient tractor weight is more important for most tractor applications than increased tractor horsepower. Bare tractor weight is a tractor specification easily found in sales brochures and web sites, readily comparable across tractor brands and tractor models, new and used.
Within subcompact and compact tractor categories, a significant tractor capability increase requires a bare tractor weight increase of 50%. It takes a 100% increase in bare tractor weight to elicit MY-OH-MY!
Shop your weight range within tractor brands. Budget will eliminate some choices. Collect a dealer brochure for each tractor model in your weight range. I spreadsheet tractor and implement specs, often a revealing exercise. I have a column for cost per pound.
Most tractors under 3,000 pounds bare weight operate in residential or hobby farm applications on one to ten flat acres.
Selling a used tractor is easy. Selling multiple light implements in order to buy heavier, wider implements for a new, heavier tractor requires a lot of time. Depreciation on implements is worse than depreciation on a tractor.
When considering a tractor purchase bare tractor weight first, tractor horsepower second, rear axle width third, rear wheel/tire ballast fourth.
A quality dealer, reasonably close, available for coaching, is important for tractor neophytes. Most new tractors are delivered with a glitch or two requiring correction. My Kubota dealer is six miles away. I feel my local dealer continues to add value to my equipment after eight years. Dealer proximity is less important for those experienced with tractors and qualified to perform their own maintenance.
BUY ENOUGH TRACTOR​
/ First time buying a tractor tips? #4
Welcome to TBN!
You can search TBN and read for hours on advice for buying first tractors. Look under buying pricing by brand too.
That said, Dixon CA appears fairly flat if that's where your land is located? Or is it more hilly terrain, woods vs grass acreage?
Good choices are probably a tractor 25HP range, suggest HST, all major brands are good - Kubota,(L2501) Deere (2205) Kioti (2610), LS (MT225), Massey, Yanmar, and more - each brand have different features so go sit on some and figure out what fits you. You would be better off with a separate mower depending on how much grass you have.
Also it used to be normal to buy tractors off the lot, but in the market today, supply is limited so you may need to order one - they are not built to order, they are built and the dealer does the install of the tires, loader and other bits. Yes, you can negotiate a "package deal" with all your implements too - it gives the dealer a but more flexibility.
Welcome to TBN!
I appreciate the replies so far! Our property is completely flat. 90% of the property is grassy.
/ First time buying a tractor tips? #7
Answer all seven (7) questions, please.
No need to be fancy with the format.
/ First time buying a tractor tips? #8
Figure out what needs to be done and then go shopping for the equipment that meets your needs!
And do have patience.
/ First time buying a tractor tips? #9
Only thing I would add to what’s already been said is probably wouldn’t recommend mowing with the tractor unless you’re taking about brush hogging. Tractors are very slow to mow with and aggravating if you’re trying to maintain a high quality lawn. Just get a ZT for lawn mowing.
/ First time buying a tractor tips? #11
If most of your property/task will eventually be mowing, I'd get a Zero Turn Mower with a 52" - 72" inch deck...and a weedwacker. Save the money on a tractor mowing deck. You'll probably use the tractor often at first, then it'd be mostly mowing unless you intend to do some farming, hay, crops, etc. Once property is sorted out...if you're mostly mowing...you are going to want to get it done and a tractor is very slow, can not trim mow that well and no matter what type of tires are on the tractor...they will dig and leave marks. Regarding implements, determine if you're only going to use an implement once or a few times - once you get the property in "maintenance condition" you might not use these attachments any longer. See if you can rent them...like the fence post digger. I have purchased many implements (fun and exciting at first) then after a few times...I don't need them and either sell them at a lost or they sit around taking up space.
/ First time buying a tractor tips? #12
Hi everyone,
My thoughts are: Jeff knows infinitely more about tractors that I do ! So, all of his questions are relative to the discussion. Among them ,and dear to me, would be finding the closest dealer / repair. Parts and service will be very important ! I have zero recommendation on the "manufacturer", there is just too many issues to consider. As long as it's a "name brand".
" drilling holes for fence posts, creating a fire break, plowing, mowing the lawn, moving soil, etc. the tractor will stay at our property and will be used maybe 2-3 a week"
One thing I would strongly recommend once you think you have a tractor / size picked out: I think many/most will include quick / easy connects for the various implements. At a minimum, have them demonstrate on the lot. Preferably, do a test ride and hook up yourself ! Don't just let them tell you how easy it is to change / hookup.
You mentioned "plowing".... for me, in my soils, that would be the major consideration on HP / Size ?
My 2cents...
/ First time buying a tractor tips? #13
/ First time buying a tractor tips? #14
Tractor Time with Tim, is doing a series on you tube on buying your first tractor:
Tractor Mike, did a couple of videos recently on how big, and what options you want.
Good Works Tractors, who sells used tractors and implements, has a playlist on buying your first tractor: https://youtube.com/playlist?list=PLyRjhkX_ZAmZGGN3Z-NmR51GmMxs98i4i
My advice is to figure out what implements you will need to have to do what you need done, and figure out what you need to operate them, and then go backwards to what the tractor needs, for hydraulics, PTO horsepower, how big of three point hitch, etc.. Before thinking about the tractor.
“Options”, on a new tractor which you will find impossible to add later are: A mid PTO, a front end loader, a backhoe, and a cab with heat and air conditioning.
The cab makes life much nicer, if you need to do a lot of work which stirs up dust.
A used tractor with a loader is much easier to sell later, and thus holds its value better.
Depending on how much use you will have for the backhoe determines whether it is worth the investment and maintenance costs. My property is pretty much fully developed, so I don’t need to dig footings for walls, install new utility lines, or dig a hole for a septic tank, and build a drain field. So, for me it makes much more sense, to rent a mini excavator, when I need to trench, than to have a small backhoe.
If you get a front end loader, be sure it has a readily available quick attach system. Skid Steer Quick Attach, is most universal. But nearly all attachments can be found with the John Deer mounting system. And, get a forklift attachment as your first implement when you get the tractor.
The forks are probably the most used attachment out there. Nearly all the implements you buy will come on a pallet, being able to get them unloaded when you get home is really handy. And, fertilizer, fire retardent, lumber for the sheds, barn, chicken coop, etc. is lots easier to offload, and move around with a set of forks.
And, I’m serious about fire retardent. Your in California, and things are going to burn there. You’re moving rural, so the fire department will have a response time of an hour. Home desperate, and Lowes both sell the same fire retardant that CalFire, and the. Forest Service, use. A good weed sprayer to spread it with, and you. An make your place much more fire resistant. And, you might want to look at a good fire pump trailer.
A high school budddies parents retired to a rural location with a high fire potential. First thing they built was a large swimming pool on a hill above where the house was going to be. He installed a 4-inch drain line from the pool to near where the house was going to be built, and installled a fire hydrant with two two inch outlets on the end of his drain line.
The fact that he had a large water tank, and a fire hydrant was critical in his getting a construction loan to build the house, and insurance on it.
/ First time buying a tractor tips? #15
One debate is if a tractor should be used for mowing or not. I’m in the camp that uses his tractor for mowing. I also don’t think you can get a “good” zero turn for the cost of a mowing deck for a tractor. I would agree if you have the storage room and funds, a zero turn makes a better mowing machine, especially in your case where your land is flat.
/ First time buying a tractor tips? #16
Hi everyone,
1st off, congrats on the land purchase! My dad retired out of Travis, so I knew a little about Dixon. It used to be very rural and agricultural. Of course that was nearly 50 years ago.
Brands - this is a great big 'it depends'. Your local dealer will be more of a deciding factor than the paint itself. Personally, I shop for value, not price. They do go hand in hand.
Size-see Jeff's questions. Don't confuse HP for size.
Negotiations- yes and no. The market is tough right now so less wiggle room. Prices are high and inventory is low. Definitely a sellers' market. My best suggestion is to not fall in love with a particular brand or model and be willing to walk away if the price is not right.
Build to order- both situations can be true. Check your local dealer inventory. My local Kubota only has about 7 new tractors on the lot. The Branson guy probably has 3 times that. If you want what they have in stock, bonus. Otherwise you can order and wait.
Buying advice - remember that many people will shout out the brand they bought. It is your money. When you compare similar tractors there can be thousands of dollars difference. Imho, the price difference is not giving much, if any, advantage. In the size range I am shopping it is over 10k from top to bottom.
/ First time buying a tractor tips? #17
I would agree with @jigs_n_fixtures except about good works tractors. That dealer has so much green paint in his eyes he cannot see the benefits in other brands. His videos are also all about shilling some part he is selling. Save your time. The other two are great. Sure, they still advertise but seem less stuck on one tractor brand.
/ First time buying a tractor tips? #18
^^^ This... It also depends on what you mean by "mowing". I mow ~ 20 acres with a rotary cutter. It does not look like someone's manicured lawn but it looks kept and maintained. If you have a smaller area and want it to look manicured then certainly you need a zero turn.
/ First time buying a tractor tips? #19
/ First time buying a tractor tips? #20
You have gotten a lot of good responses, but you really need to do your homework. You need to get some clarity on all of the tasks you need your machine(s) to do.
You said drilling holes for fence posts. That is typically a one-time thing and isn't particularly demanding if you only have a few to make (less than 10). If you have 50 or more to make, you want something with some down pressure, so probably a loader mounted one.
You said mowing. You need to define that more clearly. Is this field mowing you do a few times a year at most, or lawn mowing you do at least weekly when the grass is growing and you have an expectation the lawn looks nice?
Don't get me wrong, tractors are great, but it is the implements that actually do the work. The tractor just gives them the power to do it. While there is a lot of overlap in capabilities of the various sizes there are jobs and properties that are much better suited for particular size tractors and other size tractors would be unable to handle and/or unsafe to use. It sounds like your property is pretty flat and open, so a much bigger tractor might be just fine.
You might consider renting one to get some experience with actually using one. I didn't do that, but I did rent a Dingo for a project that I had and I learned a lot that was helpful later when I was looking. Most people here say go big or go home. That might be good advice for you, but definitely not if your primary purpose for the machine is lawn mowing. Many years ago I bought a Kubota B2620. It had an available mid-mount mower. It was not cheap, so I didn't buy it. That was the smartest choice ever. I would not have been able to sell my existing garden tractor/mower for the price of just the deck for the new one. I also would not have been able to use the B2620 to mow many parts of my property and it would have been a horrible job and unsafe (due to unavoidable slopes) if I had tried.
It is unlikely that there is one machine that can do all the jobs that you will discover that you need. So, spend some time now to figure out what is most important now and is likely to remain important for a decade or more.
10 ft bed. 14 ft trailer (A61567)
10 ft bed. 14 ft...
New/Unused IRMC Massage Chair (A61166)
New/Unused IRMC...
2015 Freightliner M2 106 AWD Altec DM478BTR Insulated Digger Derrick Truck (A60460)
2015 Freightliner...
17309SFL (A61569)
17309SFL (A61569)
2017 New Holland T4.110 Cab 4WD w/ 655TL Loader – 1,619 hrs – Excellent Condition
2017 New Holland...
New/Unused 2in Ratchet Strap (A61166)
New/Unused 2in...
