Ditching job
/ Ditching job #121
I have 2 of those. They are trenchers, not ditchers. Used around here to get water off of crops. The Sidewinder version is really nice because the blade runs in the right tire track.
Maybe semantics, I've always heard them called ditchers- maybe its a Tennessee Valley thing. Regardless though, they do have a 5 footer, maybe larger. Seems that for something 3' deep or less that it could work. Just wouldn't have the fill for berm unless you go back through and pick it up. Does seem faster than using an excavator though.
Again, maybe I'm thinking too far outside the box - I've been accused of that in the past.
/ Ditching job #122
I think a 6k mini is way under powered. I have a 12k and sometimes I wish I had more.
Your going to be at it for a while with that machine.
I have a 9000 lb machine with a 24" and wouldn't attempt more than digging up a stump.
CT
/ Ditching job #123
Thanks!
I start every day out right Root Cause! I thank the Lord for another day, and keep fighting the good fight best I can! :)
Great post. (y)
/ Ditching job
An 8x16 GN dump with folding sides and an optional super single tire would be great, but probably $20,000.
/ Ditching job #126
It sounds like you should invest in a Hurricane Ditcher to do this the simple way.
You will make more money and not have a rental expense as you will be using your own mule.
It can be equipped with a laser GPS system to maintain the needed grade control for drainage.
www.hurricane-ditcher.com/equipment/
The 3 point hitch mounted 3PT-42
The DITCH ANGEL
model 24 Ditcher Terracer
The other option is the CRARY DITCHER with laser grade control
www.crary.com/crary-water-solutions/revolution-ditcher
The problem with a gradall is it is slow, they are prone to hydraulic leaks and grading after the ditching is done will require a small finish dozer and renting or leasing one is a year long contract expense.
The ditchers are faster and can make multiple passes with just time and fuel if needed.
/ Ditching job #127
Might as well add one more option to the discussion as it has even fewer
components and is as dumb as dirt:
The HEMOS ditching auger is simplicity and Archimedes would be proud
If you type in Hemos ditch auger in youtube it shows 2 videos of the two models
info@hemos.nl
/ Ditching job #128
You guys are talking Dude into a ditch. Unless I have skin in the game as a partner in this project, I wouldn't encourage him to walk off the ledge. I love him too much.
Now, why would Dude be invited to do this ditch job? If I were the property owner, I wouldn't let any contractor, let alone a hay farmer, bid on this work unless he has proven capability. This is a land drainage situation and the topography is involved. A surveyor is needed to determine the slope of the ditch. And even if the pegs are driven to guide the excavation, can the machine operator dig that ditch within tolerance? Imagine letting a hay farmer cut your hair. Only a fool would allow someone to learn on the job.
/ Ditching job #129
If you could rent a Gradall that would be perfect as they all have wrists
/ Ditching job #130
You've only known him since 14 January!!!!! 42 days!!!! Either you are very easy or you aren't who you claim to be? Your choice. :ROFLMAO:
Well,,,, after some thought,,,, several already know who are,,,, the rest will figure it out.... :sleep:
/ Ditching job #131
I believe the machine you are looking for or should be is called a GRADALL. Usually mounted on a tandem 6x6 truckframe. It has wrist action for the bucket. I don't know if they are still made.
It is the ultimate ditching machine unless you go the Euro route with a big flailing wheel.
/ Ditching job #133
One of my buddies has a couple of these. 2 chassis mount and one track mount. They can be chassis mount, wheel or track mounted. They are different to operate because the boom only goes in/out and up/down, but they are a beast with a 5 or 6 foot bucket and 30ish feet of reach. If youre used to running a typical excavator, you’ll scratch your head a bit trying to figure out why this doesnt do what you ask.
/ Ditching job #134
Hello Hay Dude, some food for thought.
1) How accurate is your eye to get the fall right? Water will quickly find all the hollows in your drain. Is laser guide practical?
2)In New Zealand we would use a tractor and trailer to haul the dirt to your berm and tip the loads tight togather. The tractors are in the 150 - 220hp range and tow large tandem axle trailers fitted with flotation tyres, and are european(see post 65, this example has road tyres not floatation tyres, which are about 2ft wide.) This gear is often hired to do a contract and returned to the hire centre. These generally are used where ADT's and other heavy gear will destroy the ground. Pay attention to the tare as some trailers are quite heavy for the payload.
3) Post 60, tracked tippers are in my experiance slow and thirsty. That said, they can work when everything else is parked up and have a light footprint. There are 2 types, tip over rear axle and slew (like digger) to tip, type.
4) I think you are trying to use to small a machine. I think a machine with a 20' reach (better control in 1st 80% of reach) to give a smoother/easier final grade. It also means less manuvuring/ ground damage.
5) Crunch your numbers carefully.
Good luck
/ Ditching job #135
There is no need to dig this swale out.
The simplest least costly way to do this is just burn the ditch out with
a propane fired weed burner to kill the brush in it to improve the drainage
at the very instant that is done.
This kills the weeds and eliminates the brush build up.
The existing shallow swale for drainage will be maintained and the drainage
will continue unabated as the brush and top growth will be gone.
A double barrel propane fired hand held roofing torch can do this quickly and
leave no dirt will be disturbed to be washed away.
/ Ditching job
Leonz
We had 2 of the 3 worst floods recorded in my area since the last time the ditches were cleaned.
There’s road gravel and mud washed 800 feet into them, so it’s time to remove it completely.
The first hundred feet on one trench alone is 90% filled. Other areas are holding ponds of stagnant water.
No, burning the weeds out will have little impact on cleaning the ditches.
/ Ditching job #138
I guess the only low cost option for you would be to import and invest a HEMOS 450 ditch auger and spend extra time scooping the cuttings.
Unless the property owner would be amenable to having a much wider 5 foot wide flat bottom drainage ditch
created by the Crary Revolution Ditcher.
The material would be torn to shreds and you could go back over it with a landscape rake to pull any
oversize material done to one end to scoop up later and dump it at the desired point.
All the existing fill would be shredded and thrown to one or both sides and the dirt and sod cuttings
would dissolve back into the soil quickly after you go over it with a landscape rake to pull the oversize
material to one end.
The Crary Revolution Ditcher has GPS and laser grade control and would maintain the proper slope at the
same time the ditch is being opened.
Even renting a Degelman Rock Picker for a day or two or a week would save you a lot of money and work as you
would skim the sod to pick up any large rocks and sod clumps on the first pass that were cut with the
I guess I would contact the Crary people and ask about renting a demo unit as the Revolution Ditcher is $68,000+frieght.
They are leasing these ditchers but using it for one job leaves you in the lurch for whatever the lease period balance is.
The other option would be to use the HEMOS 350 or 450 ditching auger and a Degelman hydraulic rock picker to pick up windrows of the cut material and any rocks it would bring up when cutting the slope of the ditch.
The larger HEMOS 450 unit would allow you to cut a more gradual slope on both sides and then you could collect the material with a Degelman rock picker and cart it way to dump it. The other issue is the center of the ditch and its actual depth as it would be shallower in any case UNLESS you employ the Revolution Ditcher to take it down ten inches per pass.
Back to the HEMOS auger ditcher you would have to make several passes on each side of the ditch to bring the material out and make it wide enough and have wide windrows of material to be picked up with a Degelman rock picker and you would collect it all and then dump it where they want it and go from there.
Even renting a revolution ditcher from another farmer would be possible for such a small job and buying a small hydraulic rock picker to skim the sod would be worth considering.
Renting conventional excavating equipment is a very expensive proposition at a day or month rate and leases of that equipment are for a year period that are typically not renewed. Any maintenance is paid for by the leasee so any problems that occur you would have to pay for. The other issue is laser grade control and an excavator would have to be equipped with laser grade controls to follow such a small trench.
One of many other things to consider is silt control where you would need to have silt curtains installed along the excavation on both sides as well as silt control bags filled with straw to stop the silt.
They may need to apply for a department of the environment permit in this state for the excavation as this drains into a waterway.
Leasing the Crary Revolution Ditcher for a week or month to make several cuts wide and several cuts deep to 10 plus inches deep and renting a Degelman rock picker to skim the sod free of clumps and rocks and buying a hundred bales of straw to catch the silt would probably be the least costly way FOR YOU to do this. Whether you will make any money to cover the ditcher lease and rock picker rental is another thing.
/ Ditching job #139
Sounds like they need to reconsider and put a three or four foot pipeline in place instead of a fifteen x four ft ditch that's going to erode that hayfield like no tomorrow, what are they going to do with all that dirt they excavate, berm the ditch? Should make bailing hay a real task.
2002 Ford F-250 Service Truck, VIN # 1FTNF21L52EB33349 (A65563)
2002 Ford F-250...
2017 Ram 5500 Bucket Truck (A63689)
2017 Ram 5500...
2023 Kubota U48-5 Compact Excavator with Angle Blade and Hydraulic Thumb (A63689)
2023 Kubota U48-5...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2019 DODGE RAM 1500 (A65643)
2019 DODGE RAM...
Great Dane Van Trailer 1989 (A63689)
Great Dane Van...
