PTO 3 point hitch Forestry mulcher
/ PTO 3 point hitch Forestry mulcher #1
Michelle K linnane
Gold Member
Esperance NY
JD 4103
I have 25 acres that has been allow to grow from pasture a brush lot for about 30 years. Not adult enough to timber and want shade trees a brush hog really struggles and I do not want a dozer to come in and make more of mess. What I see the forestry mulcher
would do the job. I am not going to use it on anything bigger then 3 1/2 inches we will cut with chain saw. I have gotten a quote for a 8 hour day and they want over $2000 for say with skid steer and forestry head and that was the cheapest. I upgrading my tractor to a
JD 4066m heavy duty. So I am looking at the 3 point hitch ones and when I am done with implement I will sell. What I like about these the land is ready for planting once these things are done. I know that Baumalight makes on
/ PTO 3 point hitch Forestry mulcher #2
Have you looked into renting what you need?
/ PTO 3 point hitch Forestry mulcher #4
When I looked a couple years ago the price I found for the smallest Baumalight was $12k. It's pretty limited as far as the size of tree that it will take down. They rate it for larger trees if your tractor is HST since you can inch into the tree slowly.
You'll also be operating in reverse. That will be a pain in the neck, literally.
For a one time deal I'd go with a rental tracked skid steer. It will compress the ground a lot less than the tractor, will be able to safely go on slopes and soft ground the tractor can't handle, and will have lot more capacity for chewing up trees. And you can operate it looking forwards.
Another option is a heavy duty rotary designed for cutting down and chopping up trees. Baumalight makes one of those as do a few other companies. It should cost less and be more capable on the tractor than the drum type mulcher, though tossing material might be a problem. Someone on this site has one and posted pics and a review in the last couple years.
/ PTO 3 point hitch Forestry mulcher #5
One can quickly rack up a $2k repair bill. Heavy equipment is used because it's heavy duty. CUTS are NOT heavy duty (and even larger tractor are no match for actual construction grade equipment). If you are OK with going slow then making a lesser-tool do the job is OK, though, again, always keep in mind that they break a lot easier than heavy duty equipment.
And there's also the issue of breaking the operator. Medical costs aren't cheap either. Rent the appropriate equipment or hire the job out.
/ PTO 3 point hitch Forestry mulcher #6
One other thing... I've run through some pretty big stuff with my 6' RC (it's a beast) and even with a cabbed tractor the noise is nasty. Usually it's only a little here and there. NO way would want to be operating long periods of time like this.
Id say he already did.
Yes I did looking into renting and when they asked what the limit on my credit card was I hung up the phone!!! And I am a she not a he!! Smile :)
My plan is using my new 4066M which is 16 HP more then my JD 5103. new place is wet and I needed 4WD I will cut with 5 foot brush hog. I only paid $500 for JD brush hog so I will beat the piss out that, but the I Really like how the forestry mulcher gets rid of stumps. I have Amish across the street I will offer them the bigger wood they are not to proud especially when close I will just ask them to pile brush. I do not want this clear cut I have plans for wasting time on trees just the brush. The tractor is zero percent interest rates if I can do that with the mulcher and then sell when done. This brush is just a hair bigger then you want to use a brush hog. Like i said I do not want it clear I might want to leave a few bushes and trees as I retriever training and will place ponds in the future.
/ PTO 3 point hitch Forestry mulcher #8
Bush hog and then rent the stump grinder??
When I had to go after thick(er) brush I found that it worked much better to back into it with the bush hog raised and the top link pulled in; then lower it into the material to chop it up. I'd work up a couple of acres with the bush hog before I bought anything. It might surprise you how much you can get done with it.
/ PTO 3 point hitch Forestry mulcher #9
Not sure on the hp needed but there are rough cut mowers that will handle 4 inch trees.
/ PTO 3 point hitch Forestry mulcher #10
My 8' landpride is rated for 4" wood. It's a heavy duty chopper. Sure makes a racket when it chops them up too.
I apologize for referring to you as a he. Not too many 'she's' on here. Should have looked closer at your name, again I meant no harm or disrespect.
none taken
/ PTO 3 point hitch Forestry mulcher #12
I work with forestry contractors who do mastication in the woods with these hydraulic heads on skid steers, excavators, and loaders. These are heavy duty hydraulic units, yet seldom does a week go by without seeing them broke down and being repaired. I can’t imagine that a pto unit would be more durable. Hire the work done and save a lot of frustration and expense. The reason those units cost so much to rent is because of the repair costs associated with their use.
/ PTO 3 point hitch Forestry mulcher #13
Both scenarios would work. I think it comes down to your ability to handle risk. I do this exact work all the time and I do not charge $2000/day. More like $1500. His price sounds high.
Pay $2000/day-you sit and watch. Basically zero risk.
Purchase mower- you take all the risk. That includes buying/selling mower and damage to your tractor & tires, driveline and your body.
Theres a 3rd option you should pursue and that is renting a skiddy with a mulcher.
Theres a reason when we chip brush that we use a skiddy with a mulcher head and not a tractor with a 3 point cutter. It’s faster and safer.
Rent from a rental agency on the cheap side of town. I have done this with great success for decades.
/ PTO 3 point hitch Forestry mulcher #14
Not to mention what it's going to do to the life of a little tractors pto drive line!
SR
/ PTO 3 point hitch Forestry mulcher #15
SR
The best option is to have the initial work done with the appropriate equipment, then do maintenance work with a tractor.
/ PTO 3 point hitch Forestry mulcher #16
I just accepted a quote for brush clearing and taking out trees up to 5”. A mini-ex with a mower head to clean around the two acre pond & dam, $1650 for one 8 hour day. Then two days @ $1600/day for a tracked SS mulcher for general cleanup along access roads, fence lines, and edges of wood lines. I identified the top priority areas then will direct the operators if any remaining time permits. Afterwards I’ll try to do a better job of maintaining these areas with the bush hog or herbicides.
/ PTO 3 point hitch Forestry mulcher #17
A bit of free advice from a forester: get the bid on a per acre basis, not per day or per hour. That way your final cost is set and you won’t be concerned about their production rates. In my agency, all forestry service work is bid on a per acre basis, never otherwise.
/ PTO 3 point hitch Forestry mulcher #18
Good to know. Thanks. The fellow that toured the scattered about areas with me & then quoted said they offered per acre rates on larger tracts such as my planted pines and older pine stands. Said they would bring in their big Hydro Axe (?) for them. That would probably be to rich for my blood ($) The state forestry service is to burn those areas for me soon. Way overdue, about 80 acres.
/ PTO 3 point hitch Forestry mulcher #19
Brown Tree Cutter, Look for used. Had one years ago on a 135MF, if you are careful they will down cut 8 in, I almost cut a power pole down before I could stop.
/ PTO 3 point hitch Forestry mulcher #20
I'm having to deal with this same problem, but only with a pasture that's been allowed to grow up only maybe 5 years. Some of the trees are too big to cut with a brush cutter without risking a lot of damage to my equipment.
A friend who has a heavy duty skid steer with heavy brush cutter has it tied up on a job for probably a few months. His small dozer is also tied upon the same job.
Meanwhile, I've been selectively cutting what I can and digging out the larger trees with a Terramite.
The cutter will shred smaller trees that haven't gotten too big, but it leaves behind a nasty 4 or 6" stub that could go through a tire. That means cutting it off with a brush blade in a gas handheld trimmer or digging them out. Then there's the hole that has to be filled.
The larger trees have to be moved to a pile or burned or whatever.
The forestry mulching may be expensive, but think about the cost and risk of damage to your equipment, as well as the time involved in clearing.
If there's a place to push the debris, I suspect a dozer is the least expensive option, and might be the only realistic option if trees have been allowed to grow for 30 years.
Gleaner Variable Speed Header Drive forS96-97-98 Gleaner Combine (A63117)
Gleaner Variable...
2015 JLG G12-55A 12,000lb 4x4 Rough Terrain Telehandler (A61572)
2015 JLG G12-55A...
2015 Audi A4 AWD Sedan (A61574)
2015 Audi A4 AWD...
UNUSED 1RANCH 1RET13 ELECTRIC TRICYCLE (A64280)
UNUSED 1RANCH...
2020 Water-Land Dba Continental Trailers Trailer, VIN # 1ZJBU1415LC037150 (A61569)
2020 Water-Land...
2016 Eager Beaver 20XPT 27ft 24 Ton T/A Tag Trailer (A61573)
2016 Eager Beaver...
