Quality drill bits for metal.
/ Quality drill bits for metal. #1
N80
Super Member
SC
Kubota L4400 4wd w/LA 703 FEL
I don't work with metal much but from time to time I do and seem to be doing more than usual lately. My Harbor Freight drill bits and the pile of drill bits I inherited from my Dad are not getting the job done. Lots of work. Holes not pretty. I know they can be sharpened but even when sharp they only last a minute or two and even then don't cut all that well.
I recently came across a 'good' drill bit in the pile of old bits from Dad. All the markings were worn off of it so I couldn't tell what it was. It was old and well used but did a far better job and for a lot longer than anything else I have.
So the assumption on my part is that some bits are better than others both in cut quality and ability to hold an edge. My question is, is there a specific brand of bits that would be worth the money for a part timer like me for general drill press and hand held drill work? I do not need a wide variety of sizes. I'd be willing to pay for quality.
/ Quality drill bits for metal. #2
Over the years buying and collecting drill bits I've found the DeWalt pilot point bits tend to hold up well for me. I several common sizes that I bought in bulk packs. I stopped buying 1/8" bits for common pilot holes and switched to 3/16" dia. that hold up a lot longer.
/ Quality drill bits for metal. #4
Bits made with Cobalt work great for metal work. They are however more brittle imo.
two rules
1. half the speed double the feed
2. keep cutting edge cool
figure these out and even "junk" bits will drill through steel
Agree. My junk bits make it through. But it is a lot of work compared to a 'proper' bit. Having said that, some of these junk bits after a few minutes work will not cut at all. You can sharpen it and go again...but that's a process that gets old and tiresome too.
/ Quality drill bits for metal. #6
M2 is quality high-speed steel and is commonly found in machine shops.
Titanium-coated cheap steel is what HF sells, it is crap, and you can't sharpen them.
For small bits (under 3/16) I run them pretty fast and with little pressure and some oil. If you have to push hard at all, you have a dull bit.
Go to MSC, Grainger and buy a dozen greenfield or the other USA-made bits. Get a bit sharpener or learn to sharpen them by hand on a snag grinder. You can make them last years if you get them so hot that you temper the hardness out of them.
/ Quality drill bits for metal. #7
When I need a bit to last and stay sharp, I get kobalt ones. Its a fancy version of HHS but its worth the extra cost in my book (still a amateur). Sharp bits are your friend.
/ Quality drill bits for metal. #8
I just recently bought Drill Doctor 750X and have used it couple of times to resharpen older US or European made drill bits with pretty good success!
Sharpening drill bits manually used to be pretty easy for me but it's gotten harder since my eyesight is not improving.
Aren't the small kit Milwaukee, Bosch and DeWalt bits all made in China nowadays?
I bought this $150 Taiwanese drill press over 30 years ago and it has worked alright, I just wish it had a variable speed drive.
/ Quality drill bits for metal. #9
Precision Twist Drill is a good brand. More expensive but well worth it are Guhring brand drill. Drill bits come in all sorts of lengths but the two most common lengths are Jobber length (long) and Stub length (short) (duh). Stub length is also called Screw Machine length. It is best to use split point drill bits. Split points are very common in Stub length but can also be had in Jobber length.
Cobalt HSS drill bits will last longer than regular HSS drill bits. The gold colored coating found on some is titanium nitride. If done properly this coating is very wear resistant, but the cheap drills with it have such a thin coating that is is really no help at all.
The split point helps to center the bit so that it doesn't tend to wander and it also requires less pressure. In my machine shop I use almost exclusively split point cobalt stub length bits. I only use the longer Jobber length bits when needed.
When drilling steels you should use cutting oil, NOT regular lubricating oil. That means don't use motor oil, ATF, 3 in 1, etc. A half way decent hardware store will have threading oil. It may be clear or brown. It really won't matter much which you use. They will both contain sulfur, which is a high pressure lubricant.
When drilling aluminum you can use kerosene, or lamp oil (which works just as well and doesn't stink), or most any light oil. It is usually best if the lamp oil is mixed with a little of regular cutting oil because it will stick the the drill bit better.
There are all sorts of drill speed charts on the internet. Use the right speed. Running the bit too fast makes it get too hot and this ruins the cutting edge fast. It is way better to run the bit too slow rather than too fast. Make sure that the drill is always making a chip. If it stops making a chip it is being ruined. When drilling stainless slow speed and high pressure is the method that will make the bits last longer and also will let the drill go all the way through the part being drilled.
Eric
/ Quality drill bits for metal. #10
When I was pretty young, someone showed me how to sharpen bits on a bench grinder. I still do that to this day. If I need a new bit, I try and buy name-brand. I've had my share of Harbor Freight bits... the best thing I can say about them is I like the organizer they come in. 😬
/ Quality drill bits for metal. #11
I have used McMaster Carr for good quality drill bits. Fast shipping and large selection. If you don’t have one a drill bit speed chart is a nice addition. In my 30 years of working with metal most drilling problems were too fast speed and lack of cutting fluid use.
/ Quality drill bits for metal. #12
two rules
This is indeed the answer. I dip the tips in thread cutting oil as I go. And I’ve been impressed with both DeWalt and Milwaukee drill bits.
/ Quality drill bits for metal. #13
I have a set if Irwin cobalt bits that cut and hold an edge well.
/ Quality drill bits for metal. #14
McMaster-Carr is good and they can get you stuff about as fast as Amazon Prime. Another good place for tooling is Victor Machinery. They typically have better prices than McMaster for the same quality tooling. VM used to sell new-old stock from many of the best US tool makers. I have drawers full. I didn't see any the last time I was there though. They still sell made in USA stuff but I didn't see any brands mentioned.
/ Quality drill bits for metal. #15
Thanks for the victor machinery heads up. I had not heard of them.
/ Quality drill bits for metal. #17
I have a few of them myself as the local Ace Hardware was closing after 40 years and there was a huge 70% off sale.
I've used McMaster-Carr for other stuff. They are amazing. Stuff gets here before I knew I wanted it. ;-) I'll look at their bits.
I do use cutting oil when doing any significant drilling.
A stubb set would be very handy even for starting a hole for a jobber bit. It seems to me that any bit with any length on it can wander.
I sharpen bits on a narrow belt sander. It works okay in a pinch. Hardly precise though.
There are two Irwin sets on Amazon. The M35 set is 5% cobalt and is $122. The M42 set is presumably 8% cobalt and is $168. I don't think I need the 8% cobalt and I understand they are more brittle.
Irwin set.
Quick edit: Reviews are terrible on these bits. Pass.
/ Quality drill bits for metal. #19
I buy sets of milwakees for my work trucks. The do pretty good for the price point. Usually watch for good sales and buy a couple sets. Unfortunately cheaper to buy whole sets then replace the broken ones.
Have a sets of Irwin that i use in the shop, cobalt and hhs. They hold up great and sharpen well. Use a drill doctor 750
/ Quality drill bits for metal. #20
I quit buying anything made by Irwin. They charge the same price for Chinese stuff as American makers do. I am especially peeved about Vise Grips. Premium price made with cheap Chinese labor. The quality has gone down too. Irwin takes advantage of both Chinese labor and American buyers.
Eric
2022 Greenworks CU400W Commercial Work Utility Vehicle DEMO UNIT (A63118)
2022 Greenworks...
2016 FREIGHTLINER M2 106 4X2 S/A SERVICE BODY (A59909)
2016 FREIGHTLINER...
2019 KUBOTA KX033-4 EXCAVATOR (A60429)
2019 KUBOTA...
New/Unused Solid Backing Plate (A61166)
New/Unused Solid...
2018 Subaru Outback AWD SUV (A61569)
2018 Subaru...
2007 Honda Accord Sedan (A61569)
2007 Honda Accord...
