Quality drill bits for metal.
/ Quality drill bits for metal. #21
I agree with MossRoad. Learn how to sharpen a bit and most any brand of bit will cut just fine. Then the difference between bits is really in the metallurgy used to make the bit, and the speed and cooling that you use to determine how long they will stay sharp. There is an art to sharpening a bit, but it pretty easy to learn really isn't that difficult to do. I have a jig to sharpen bits but I usually just do it by hand.
/ Quality drill bits for metal. #22
Cheap bits cut better and last longer in a drill press than quility bits in a hand held drill. Quility bits will last a life time when used with oil and exclusivly in a press. Even quility bits are at risk of overheating if improperly used. Once overheated,it will no longer stay sharp. Buy a press before investing in expensive bits.
/ Quality drill bits for metal. #23
There is much difference in HHS alloy quality and its ability to stay sharp longer. Cheap bits are good for throwing into the recycling bin whereas good ones you can be resharpen and resharpen. All my kerf bits are kobalt because I can't resharpen them.
/ Quality drill bits for metal. #24
Learn to sharpen your bits and buy better quality cutting tools if you are serious about making holes in metal. Big box stores do not sell better quality anything. Go to an industrial hardware or cutting tool supplier for your jobber drills.
Try drilling out a broken bolt with a cheap drill bit if you want to learn the meaning of regret. Penny wise and pound foolish.
/ Quality drill bits for metal. #26
Hertel production grade drill bits. Mic drop.
Very pricy, but simply amazing to use.
They used to make Supertanium bits, not sure if that name is still used, but we used them at the machine shop here at work and they were fan-fricken-tastic. But even the black colored Hertel production grade are mind blowing.
/ Quality drill bits for metal. #28
Cleveland Twist or Hertel for me and knowing the correct method and being adept at off hand sharpening is a big plus. As a rule, I'll 'touch up my drills after use, before they go back into the drill index and when the get too short, I replace them. I never even consider 'Chineseum' drill bits at all.
/ Quality drill bits for metal. #29
I've had good luck with these. Champion Drill Bits
Another trick I learned when drilling on flat stock. Lay a large flat washer down over the spot you're going to drill and fill the center with oil. It acts as a dam and contains the oil while you drill.
/ Quality drill bits for metal. #30
Learn how to sharpen drill bits correctly and learn how to relieve the heel for easier cutting. Offhand sharpening is an acquired skill and it only comes with lots of practice. Get yourself a drill point gage as well. Even the cheapo Chineseum ones will drill fine in mild steel if sharpened correctly and the heels relived correctly.
My favorite set of drills are actually the solid tungsten carbide die reclaim drills but they are way too expensive for home shop use. I can drill glass with them and the only 'lubricant' required is water.
I use a Darex sharpener for the tiny ones that are hard to see when offhand sharpening. Not the box store one but the professional one that costs over a grand new.
/ Quality drill bits for metal. #31
I have a drill bit sharpener but IMO, it isn't worth the time it takes to get right.
There are good industrial quality bits out there but they're expensive. I don't do a lot of machining anymore so for bits under a half inch, I buy in bulk and toss them when they wear out.
I've had pretty good luck with these:
/ Quality drill bits for metal. #32
I also have an end mill sharpener that I make good use of. I quit sending them out to be sharpened a while ago and invested in one. I still send out my chucking reamers however.
Upon reflection and watching the videos posted earlier in this thread I disagree with this. I have had two of the junk sets he tested and in some cases they simply won’t do anything even when new. Just like in the video. And for me the whole point is saving time and physical effort. Struggling with and sharpening a junk bit every time you drill a hole does not meet either of those requirements.
/ Quality drill bits for metal. #34
You still should learn how to sharpen your quality bits (and your chainsaw chains, too :ROFLMAO: ). OK, that's getting old. I'll stop now.🙃
/ Quality drill bits for metal. #35
Proper cutting speed is the key to using drills.
The calculations are very complex and your drill does not tell you the cutting speed anyways.
If you are drilling at the correct cutting speed, your shavings should stay mostly in long spirals. (very hard to do with hand drill)
The following video is more entertainment than useful but will get you thinking!
/ Quality drill bits for metal. #36
See, some folks say spirals, some folks say chips. Which one is it and why?
/ Quality drill bits for metal. #37
I've been using a set of Mac Tools jobber length drill bits since I was 21 years old. The first thing on the first day they taught us at Dunwoody auto-tech school was how to sharpen drill bits.
/ Quality drill bits for metal. #38
I must have a good eye, or learned how early on, as I always sharpen all bits from about 3/16 on up.
I also frequently dress my fine grinder stone with a diamond dressing tool.
Basically I simply freehand do my grinding.
Also keep some water nearby to keep the bits cool.
Also not often mentioned is certain metals prefer different point angles for best performance and also different lubricants for different metals. (LOL, knowing that I often simply use WD40 as that is handiest)
All of my life's problems would be solved by learning to sharpen things. :cool:
The funny thing is that I've always been fanatical about sharp stuff. Cannot abide a dull knife, etc. As for drill bits its hard to say if I'm doing it right because most of the bits are junk bits. I'll get about as much drill time out of one after sharpening it as I did when it was new....which is not much. I think using the narrow belt sander is way easier than a grinder.
As mentioned, speed is critical and as shown in those videos pressure requirements vary with different metals and different bits. When hand drilling there is usually a sweet spot with both pressure and speed. I can't say if the shaving size or shape tells me much but I can usually feel the sweet spot. The issue is that keeping constant speed with a hand drill that doesn't lock at a set speed is hard. Constant even pressure is hard too when you're 58 years old, not exactly in tip top shape and lying in wet gravel.
/ Quality drill bits for metal. #40
Speed calculation is critical for the life of ANY cutter but it doesn't do much good if you can't tell the spindle speed of a hand drill or drill press. A simple "guestimation" for drill low carbon steel is to go up to the speed where the drill flutes just start to disappear. Faster than that will burn up and dull the drill. Also, if the chip/curl is turning yellow then you're going too fast. Always use a cutting fluid of some sort, even in aluminum. Even soapy water is better than none at all. Buy HSS drills, if it doesn't plainly state that they're HSS then they're just carbon steel and are cheap crap. The coated ones are also crap most of the time. Cobalt is my favorite but are more expensive. Carbide drills in a hand drill are subject to shattering in the hole and making a real problem to get the fragments out. Yes masonry drills can work but if they overheat the brazed tip can come loose and lodge in the hole. Carbide is best used in a rigid milling machine with a solid clamped workpiece and a certain procedure (ask me if you wish). Anything else is taking a risk of creating a larger problem. I have 40 years of shop experience and this is just my opinion.
5' X 8' SINGLE AXLE UTILITY TRAILER (A64280)
5' X 8' SINGLE...
More info coming soon (A61574)
More info coming...
Crate of Misc Parts (A64119)
Crate of Misc...
2000 Sterling L9513 Winch Truck (A63118)
2000 Sterling...
42" X 27" FIRE PIT RING/DISC (A64281)
42" X 27" FIRE PIT...
Kenworth T6 (A63688)
