Best grapple for a cutover?
/ Best grapple for a cutover? #21
Two items here to consider. Collect & burn the slash - - type of grapple.
I had my property selectively logged about 15 years ago. Ended up with around eight slash piles. Two years later - went back out to burn these piles. So many of the local animals had already established homes in these piles - I didn't burn. Now - 15 years later these piles are about 1/4 of their original size.
I bought my Land Pride - Rock and Root grapple - eight years ago. It works great for what I do. Move large chunks of Ponderosa pine trunk and large rocks. Whatever type/style grapple you choose - DO NOT forget to modify your grill guard.
I have 80 acres here in NE WA state.
/ Best grapple for a cutover? #22
BTW - what is a cutover???
I have the same problem . The deer seem to love all the Slash so I'm keeping most of it but as soon as I clear a path through it. The deer follow the path 70% of the time .
That's one reason I want to keep some of the debris out there. I want to keep the deer coming in.
For best management practices for soil nutrients and your new forest, you should concentrate the heavy fuels into smaller piles and burn them. Have them well distributed throughout your block. Then just leave the smaller material and light accumulations scattered where they are. You can accelerate decomposition by either crushing the woody debris into the soil with equipment or just buck the longer sections into shorter lengths with a chainsaw to get full soil contact. That will speed decomposition. The key is you want some of the slash to melt into the soil and dispose of heavier concentrations by either burning or removal. You can also skid them into decks away from your tree seedlings if you’re ok with letting them sit until they rot. Burning a large pile just bakes that area into concrete and destroys soil properties.
Thank you for the advice! I will look at getting rid of the bigger logs left and maybe let the rest rot.
/ Best grapple for a cutover? #28
As I mentioned there are things you can do to speed up the rotting process. The material needs to be in contact with or incorporated into the soil.
/ Best grapple for a cutover? #29
We don’t clear cut much but collect a significant amount of trees just to maintain cleared areas. Like my dad, use to collect in piles and burn. Times change. Now push and pile into the woods to make habitat and rot. Also have a large gully off the the driveway that receives several house size debris piles per year. Given the favorable conditions of moderate weather, shade, water and starter decay I’m always amazed how quickly trees rot. The gully drains 1/4 mile to a paddock that always lush with the added nutrients. The gully has gone from a nuisance to a valuable part of the farm. Good gully.
/ Best grapple for a cutover? #30
Why burn them at all? They make good wildlife habitat. When I take trees from my forest, I limb them, then remove the trunk. The branches and stumps rot down eventually. I have a great abundance of wildlife now.
I agree! If you want it cleaned up a bit, push the piles together some but they are great for wild birds and rabbits. I have a couple piles I end up just adding to them year round and like MossRoad says, they just decay and go into the ground. They just stay the same size as they rot as fast as I add to them.
/ Best grapple for a cutover? #32
It depends on the
It depends on the location and environment. In the mesic eastern US and Pacific coast, large piles rot fast. In the interior western US where the climate is drier, large piles can stand for decades as wildfire hazards.
/ Best grapple for a cutover? #33
Looking at your pictures, you have pine seedlings planted in that mix.... They must have been planted with a transplanter judging by the lines of soil with trees sticking out from them.
You have a built in forest in the making if the whole acreage is like the pics...
/ Best grapple for a cutover? #34
I have a MTL RK-3 Rock Root & Demolition Grapple. It has done good by me for several years. Made in the USA. I move a lot of rough cut firewood with it also. A friend of mine owns a tree service we load what ever lengths the tree comes down in and cut it up to size later at home. Mover it all with the grapple.
/ Best grapple for a cutover? #36
you could also have a forestry mulcher come in and clean it up. Pretty fast since there are no huge logs. Things like this eat that stuff up
I had a tree service with a mulcher like that come in and mulch about 6 acres 5 years go. All standing live trees, mostly aspen and pine. Biggest was about 14” and not very many of those. Most were 8-10” in diameter. I left a number of nicer trees but made sure there was a minimum of 10’ between all trees so I could get equipment between them. Biggest problem I had was the area was over grown with Buckthorn. I now mow and disc the entire area several times a year. The tree mulch is now almost completely rotted and the area looks great. Cost me a few bucks, but am very happy with the results. Lots of wildlife in there now, rabbits, turkeys, deer, etc. I would go the mulching route again.
I also have clear cut several food plot areas about 1/2-1 acre each on a different piece of land. Just piled the slash at the edges to leave it rot. Some lime, fertilizer, and clover seed and they look beautiful.
/ Best grapple for a cutover? #37
if you have a lot of small stuff you want to pick up then I like the grapple used in post #2 as you can get under and tines help prevent fall through.
I have an AE wicked root grapple and every second slat on the bottom can be removed depending on whether you want more stuff to fall through or if you want to capture it.
I’m not sure how they planted them (I’m a city slicker 😁). We are buying the land from a timber company and they stated the Loblolly Pines were planted in Jan 2020. As far as we know, they planted all 48 acres like this. I figured it would look good if I could cut down all the sage and other bushes, and clean up the piles of wood left behind. Not sure that’s a great idea after reading some comments.
/ Best grapple for a cutover? #39
Depending on what your plans are, some of that debris is good for the seedings. Looks fairly clean all and all.
Might want to look into burning regulations, restrictions, seasons and what not. If its 20 odd piles scattered over 48 acres, they must not be overly large. I'd burn the piles right where they are.
Deer don't care about the slash piles, they care about the green food plants on the property. A burn spot from a slash pile, if it was not so large to scorch the dirt to bare minerals, yields a very good grow sight for all sorts of plants.
Far as tractor grapples go, ETA makes the best far as I can tell. I would go with single lid model. I would start with a 40 hp tractor for a minimum and go from there.
There’s a few large piles, but most aren’t that big. I just figure cutting the sage and brush will make the land look better. The grapple would help pick up a lot of the stray logs. I’ve got a 4540 Mahindra that should do the job. Just have to figure out how much I want to clean it up.
2016 BOBCAT E35I MINI EXCAVATOR (A62613)
2016 BOBCAT E35I...
2012 Kenworth T800 (A64127)
2012 Kenworth T800...
New 2200lb All Steel Adjustable Gantry Crane (A62679)
New 2200lb All...
John Deere 2755 Boom Mowing Tractor (A66285)
John Deere 2755...
2018 Ford F-750 IMT 6025 7 Ton Crane Mechanics Truck (A64194)
2018 Ford F-750...
John Deere 6150M (A64126)
John Deere 6150M...
