Best grapple for a cutover?
/ Best grapple for a cutover? #1
RollTide1974
Member
Alabama, Alabama
None
Instead of burning all the piles where they were left when they cut the land, I decided to find one spot and burn it all there. Which grapple (Root or Rake/Clamshell) would work best to pick up the left over timber? I haven't walked the entire land (48 acres), but doesn't seem like there is a lot of large logs to move. I have a Mahindra 4540 4WD.
/ Best grapple for a cutover? #2
/ Best grapple for a cutover? #3
A bit of free advice from a forester: making one huge burn pile is going to damage the soil. That is why we always distribute slash throughout the unit. Also, burned slash adds to soil nutrients if the burn isn’t a huge pile that burns too hot. When you remove all the slash from the land, you are also removing nutrients and reducing soil productivity.
/ Best grapple for a cutover? #4
I’ve been working on a similar mess which appears to have more trash left behind than yours. I found a grapple on my CTL to be almost worthless. It’s too tangled to pick anything up with a grapple. All the stumps don’t help. I found an excavator with a thumb to be much better at picking up and burning brush. Your land already looks fairly clean but picking apart those piles is much harder than it might seem.
/ Best grapple for a cutover? #5
I’ve been working on a similar mess which appears to have more trash left behind than yours. I found a grapple on my CTL to be almost worthless. It’s too tangled to pick anything up with a grapple. All the stumps don’t help. I found an excavator with a thumb to be much better at picking up and burning brush. View attachment 732891
On most forestry projects, we would establish perimeter fire lines, develop a burn prescription, and burn that slash in place during appropriate weather conditions. Talk to your state forestry people or a consultant forester to discuss some slash treatment options before spending months working on this.
Well....that kind of makes me think a little differently about this :) . What would you advice to do with all the slash piles? I'm guessing there is probably 20 of them spred through the property. i want to clean the land up some, but also want to keep the deer coming in ,and try and not damage to many pines that are planted.
I haven't walked mine entirely, but it does seem like they done a pretty good job cleaning up afterwards. I figure I have years to clean it up the way I want it.
/ Best grapple for a cutover? #9
There’s no regulation against doing that but the pile is too sloppy combined with 60 inches of annual rainfall. It just won’t burn in place.
/ Best grapple for a cutover? #12
I have the same problem . The deer seem to love all the Slash so I'm keeping most of it but as soon as I clear a path through it. The deer follow the path 70% of the time .
/ Best grapple for a cutover? #13
For best management practices for soil nutrients and your new forest, you should concentrate the heavy fuels into smaller piles and burn them. Have them well distributed throughout your block. Then just leave the smaller material and light accumulations scattered where they are. You can accelerate decomposition by either crushing the woody debris into the soil with equipment or just buck the longer sections into shorter lengths with a chainsaw to get full soil contact. That will speed decomposition. The key is you want some of the slash to melt into the soil and dispose of heavier concentrations by either burning or removal. You can also skid them into decks away from your tree seedlings if you’re ok with letting them sit until they rot. Burning a large pile just bakes that area into concrete and destroys soil properties.
/ Best grapple for a cutover? #14
you could also have a forestry mulcher come in and clean it up. Pretty fast since there are no huge logs. Things like this eat that stuff up
That is also an option, but costly. If you get much moisture, you can buck and or crush material into the soil so it rots faster.
/ Best grapple for a cutover? #15
Do your research, all grapples are different. Be sure and get one that has the ability to float or depth guide. I've had both and prefer the L shape one too because it holds more debris. Mine has a pipe between the bottom teeth that serves as a depth guide
/ Best grapple for a cutover? #16
Every place has a dry season. I’ve also seen people cover piles with plastic to dry them out. But diesel/gasoline mix works pretty well to get damp piles going. In the Forest Service we burn in the southeast US during the spring dry season. Where I live it’s the fall season.
/ Best grapple for a cutover? #17
If I pile everything up in nice piles it will burn but as far as burning everything where it lays on the ground isn’t happening. It actually works a lot better to start a small fire and continue adding on vs making a big pile and then trying to set it on fire.
/ Best grapple for a cutover? #18
I was explaining how we foresters do it. We broadcast burn large blocks. We also light piles and they burn (with a little gas/diesel mix). There are also consulting foresters who will burn blocks of land. But my main reason for adding to this discussion was not burning techniques. I wanted to caution against removing all of the course woody debris and reducing soil productivity. I see this way too often. Too clean isn’t good for the land and future forest development.
/ Best grapple for a cutover? #19
I use a wicked clamshell style on both of my tractors.
/ Best grapple for a cutover? #20
I have a clamshell, twin lid style. I like it because I can clamp smaller logs, raise them up, and buck them into 4-8' lengths standing up. Mine opens up to nearly 60" so I can grab a huge mouthful of brush.
JOHN DEERE 925F - 25' GRAIN HEAD (A64277)
JOHN DEERE 925F -...
New/Unused Landhonor 8ft x 10ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
40in. Skeleton Bucket Excavator Attachment (A61567)
40in. Skeleton...
2009 International 4300 Box Truck 24' (A62613)
2009 International...
2004 Winnebago Adventurer 38G 38ft. Class A Motorhome (A59231)
2004 Winnebago...
213135 (A64276)
213135 (A64276)
