Advice on building a tractor shed?
/ Advice on building a tractor shed? #1
Hoodoo
Kioti CK2610
Well now that I have my new baby, I need to build a house for it. I'm thinking a pole style structure (but I cant find any poles, so I'll just use pressure treated posts. I'm also going to house my golf cart and riding mower in it as well. So I'm thinking 20 ft wide x 14 ft deep, using 9 poles (3 rows of 3). Shelves in the back for parts, oil, tools, etc..... Some kind of cover on the 3 side walls up to maybe 5-6 ft high....?
Can't decide yet whether to have a shed roof or gable....as I kinda have to place it, it will be facing more or less West and that is where the weather comes from (generally). But here in northern Arizona, we have not that much rain (15" yr) and it only snows a couple times a year, so I really just want to get these machines out of the direct weather and sun.
Thinking of running a couple of beams across at top plate level to hang/lift stuff from...?
All ideas welcome...I'm thinking you guys have done this before.... :)
Disclosure: I am a long time builder so don't need any construction advice (necessarily), just looking for tips and tricks
/ Advice on building a tractor shed? #3
It is very unlikely that you will ever regret building considerably bigger than your current needs. A building twice as big will cost more now, and considerably more later. If it were me I would be thinking more along the line of 20w by 28d. As the open end is facing west, 14' will not shelter your tractor from the sun completely, especially if you leave an attachment on the back and/or a loader on the front. UV is hard on paint and plastic.
/ Advice on building a tractor shed? #4
I don't know what kind of poles you're looking for but the pole buildings around my area use 6 X 6 pressure treated lumber for the poles. Many people prefer commercial girts for the added strength but builders generally do charge a little more for building that way.
/ Advice on building a tractor shed? #5
By 20 feet wide I assume you mean that is the access side. Can you go deeper? 14 feet seems really small. I would suggest forgetting the center posts. Use trusses to span the roof. I would never want center posts in a storage building. It would only be a matter of time before I hit one. :D
/ Advice on building a tractor shed? #6
Hard to beat the size, price, convenience of some of these carport companies.
/ Advice on building a tractor shed? #7
airbiscuit makes a good point.
Check out costing of steel vs lumber, and then availability. If you are handy, you can dress out a steel frame rather quickly.
/ Advice on building a tractor shed? #8
My tractor lives in the garage but I did build a three sided metal carport for my other toys (RV and pontoon boat). I built a 20x30 and all I can say is I wish it was 5 feet bigger in both directions.
/ Advice on building a tractor shed? #9
I thought I had plenty of space in my barn when I built it. I only had one tractor at the time, and needed some hay storage too.
since then, the horses and cattle are gone, but have added another tractor, 2 rv’s, UTV, trailers, implements, and a whole lot of tools and chemical storage.
The barn has been expanded to twice the original size, in addition to a secure shed for tools and chemicals.
Build bigger now, it’s cheaper than adding on in the future, and you will never regret it
/ Advice on building a tractor shed? #10
You might want to check with Eagle Carports. I was going to build a carport several years ago and after pricing out the materials, it was cheaper to order the carport than build. They have lots of different design options, including pole barn type. Just make sure that you have them install with the optional earth anchors. In the relatively low elevation Chino Valley where you live you may not get much snow load, but wind can be an issue, so I would order/design with the higher load ratings in mind.
/ Advice on building a tractor shed? #11
My tin shed was just a few months old the first time I said to myself, "dang-it, I should have made it bigger".
/ Advice on building a tractor shed? #12
In December I had a 20X24 shed installed to house my tractor and some attachments. With the price of lumber, and the challenge of digging posts where I live it was more cost effective to have an all metal structure built. All in less than 5K installed in three hours once it arrived.
/ Advice on building a tractor shed? #14
I like the design. Especially the openness of the rafters. Our winds and snow loads would reqire that the roof have more support.
/ Advice on building a tractor shed? #16
Actually I have one like this and with the earth anchors it has withstood 80 mph winds. And you can order it designed for 100# snow loads like I did.
/ Advice on building a tractor shed? #17
Our problem is the constant winds. We can have 40 mph winds for days. If the tin is not fastened down enough the vibration will tear the screws through the tin. The pictured building might very well be ok. It's one thing that I would be concerned about.
Thanks guys! Yeah, I started bigger and then started shrinking it due to cost.. I know you're all right about bigger is better. I just went into debt for the tractor and am feeling pinched.....but you're right....
I will do a cost comparison between metal and wood.....
/ Advice on building a tractor shed? #20
We also h
we also have constant winds in the spring. I have three of these buildings. The open carport with just a roof: no problem. The carport with sides facing the prevailing wind direction: no problem. The carport with sides and the open front facing prevailing winds: started to creak and tear screws through the tin. I fixed that by installing heavy cables in an X pattern on the inside wall. Now it stands up to winds without a creak. All of my structures have earth anchors at each corner augered into the ground.
New/Unused Landhonor 11ft x 19ft Carport with Open Side Walls (A61166)
New/Unused...
2002 Ford F-650 Crew Cab Landscape Dump Truck (A61568)
2002 Ford F-650...
2014 PETERBILT 367 6X4 TRI/A  SLEEPER TRUCK TRACTOR (A59908)
2014 PETERBILT 367...
2019 East Manufacturing 48ft. T/A Walking Floor Trailer (A61568)
2019 East...
Miller Millermatic 212 Auto-Set MIG welder (A63118)
Miller Millermatic...
Brock 48'x16' Flat Bottom Grain Storage Tank (A57148)
Brock 48'x16' Flat...
