Snow blower purchase
/ Snow blower purchase #21
I second Ariens as they sure make a practical and reliable machine.
To the best of my knowledge they also make a lot of private labeled units as well.
Also I like the Honda tracked machine.
Most popular I think is a 28" powered by 8-12 hp engines.
Nice sized wheels, not a bear to maneuver and choices of starting energy.
Most 'walk behinds' do suffer from, IMHO, too small skids for gravel drives but that is easily fixed.
/ Snow blower purchase #22
Several folks have commented about the muscle needed to turn these things. Is that true of the ones that have selfpropelled drive and "power steering"? Part of the reason to not use the tractor is walkways and other things where the tractor is just not practical.
Edit: May of the brands advertise "effortles" turning.....
The simplest self-propelled is a solid axle; steering is accomplished by sideways muscle on the handlebars. Many self-propelled have some sort of freewheeling arrangement that makes turning a little easier. "Power steering" is probably accomplished by either a clutch or brake arrangement so power is only delivered to one wheel/track. During a test run at a dealer there is probably no snow, no side resistance, and steering is "effortless" pivoting. In snow, the snowbank will exert resistance to turning on the end of the augur housing, and additional force (muscle) will be required. One could back and fill taking small bites to remove the snow resisting the turning moment.
It may be practical to approach a neighbor or friend who has a walk-behind and will let you try it to see how that particular machine behaves when there is snow on the ground.
/ Snow blower purchase #23
This is counterintuitive, but when I got my tractor Rear Pull snowblower, I sold my 8hp 26" 2stage snowblower. It was always a work out to use. I later bought a small 2cycle Toro snowthrower at an on line auction for $40. I had low expectations, but I absolutely love it! It is light and easy to use. I has electric start, but I never use it. It actually clears the sidewalk cleaner than my old one. 8" of snow doesn't even tax it. It makes no sense, but I love it.
This is counterintuitive, but when I got my tractor Rear Pull snowblower, I sold my 8hp 26" 2stage snowblower. It was always a work out to use. I later bought a c=small 2cycle Toro snowthrower at an on line auction. I had low expectations, but I absolutely love it! It is light and easy to use. I has electric start, but I never use it. It actually clears the sidewalk cleaner than my old one. 8" of snow doesn't even tax it. It makes no sense, but I love it.
I have a machince similar to that now that I use to clear the sidewalks and other areas covered in concrete. However the drive way is gravel and way too large for a small machine like that.
Thankfully after this latest round of snow I was able to spend the morning home from work and clear snow. That likely will not always be the case. So it would be nice for the wife to have a way to get some of that done so she can get the horses out and do her work caring for them. We run a boarding barn.
This is my fear. The ones with stearing that I am looking at have basically a brake handle on each side. You want to turn left pull the left handle it will slow that wheel down and the thing will turn that way. In the promo videos it all looks so nice and effortless.....
/ Snow blower purchase #26
Well then, use the little one for the sidewalks and buy a snowblowewr for your Boomer24!
/ Snow blower purchase #27
Having the wheel disconnects for steering does make a huge difference in effort going down the garden path. Makes it right quick at the end of the driveway to spin around to change directions. My Cub Cadet has this feature, was great in the city.
/ Snow blower purchase #28
I wrote those small single stage blowers off as too small for years. Now I think they're great! I use them for sidewalks, back patio, and around cars. I've never done a side to side test on larger areas, but I suspect my 22" single stage would keep up with the 2 stage 30" blower based on travel speed... At least in light to moderate snow.
They are certainly easier to handle.
/ Snow blower purchase #29
I believe most Ariens 2 stage blower have a spring loaded pin on the right wheel that you pull and rotate to unlock the wheels so they can turn independently. This makes a big difference in how hard they turn. Down side is in slippery conditions you have one wheel drive but simply turn pin turn blower a little side to side, pin engages and now you are back to solid axle both wheels drive. I rarely engaged two wheel drive feature in the years I had an Ariens.
I have used my friends power steering Cub and found it cumbersome and awkward to operate but I am sure with more use it would become easier to operate.
/ Snow blower purchase #30
The one in that video is 4-stroke. My in-laws have one. It works great on pavement as the rubber paddles make it almost self propelled, which is great....
Except for the OP, as he had two specific questions:
Grass and gravel.
This blower that grabs the pavement and pulls itself along so well also grabs the grass and tends to dig in and stop (I blow an area in the grass for the in-law's dog, and have to use a lot of down pressure to keep the paddles out of the grass, which means I have to physically push it through the snow; no fun), and it grabs gravel really well, too.
If it was just paved areas, I'd recommend it in a heartbeat. It's a fantastic unit. (y)
/ Snow blower purchase #31
I bought the same Craftsman model as shown here Craftsman 8HP 27" Snowblower - farm & garden - by owner - sale over 10 years ago for $375, and it's still running strong today. If you can find one of these big wheel craftsman or similar they will serve you well for not a lot of money - $3-400.
Replaced the belts and adjusted the drive wheels 5 years ago and it still runs great. Elec Start, no fancy turn stuff, does have reverse, but I just walk it back. Does all our paths (several 100 feet each) across lawn and driveway where the tractor doesn't go.
But if you want new, an Ariens 24 or 28" 2 stage Professional model are very good, but also over $1K, and then Honda machines are great too, for $2K+. Depends on your budget and wife - what she prefers in running a SB - happy wife, happy life!
/ Snow blower purchase #32
Owned five different Ariens and rebuilt several. Currently own two: an Ariens Pro Hydro RapidTrack and the previous model Honda 928 track. Both tracked, hydrostatic machines.
The Ariens moves a lot more snow. The Honda throws far and is a lot lighter, so we use that one in the city.
The Ariens was purchased as a backup for our place in NH and we’ve maybe used it 10 hours. The tractor is a lot faster.
/ Snow blower purchase #33
How is the Arien tracked machine ease of handling wise? I have been debating adding tracks to my 30" Ariens, but I'm concerned it may be more difficult to handle.
I don't necessarily want new. I want something that will not throw my gravel drive into the lawn and something that will be easy for the wife to use when she needs to. Because as you say happy wife....
/ Snow blower purchase #35
My Father bought a new Ariens back in 1977 . The same year I graduated High school and went in the Navy. So he lost his snow shoveler. I believe the Ariens is a is An 8 hp 32inch cut. I am 62 now and am using the the same snowblower to my driveway. It is a beast! I do routine maintenance along with belts , a couple bearings and the rubber drive wheel. One thing I do every year is paint the inside of the chute ,auger, impeller and everything else in there with Kubota orange. Its a good color match and dries hard. I get the can of paint form tractor supply and brush it on. Snow does not stick. I believe it will out last me.
/ Snow blower purchase #36
I can recall many moons ago buying a 28" Ariens from a dealer in 'kit form'.
It had all new bearings and everything but a motor, paid $50.00
It so happened that I an industrial 6 hp Wisconsin that I adapted.
We ran that machine for a bunch of years (8-9), I say we as I shared it with my neighbor as I traveled a lot back then and he'd do my drive when I was away. His was double wide sunken garage so it was like 3 drives.
Never snapped a sheer pin either.
For sure Ariens gets my vote!
Early models had superior gear boxes in that they used bronze gears vs later being aluminum.
Also I've had a few that have passed thru my hands over the years and I've always admired them for being rugged and well designed.
They were never shy at using steel vs tin in their builds and also bearings vs plastic bushings.
/ Snow blower purchase #37
The only issue with the craftsman machine is the tiny rectangle discharge area that clogs very easily in our typical heavy snow. Add the Belting material on the impeller... Problem goes away.
It's called the Clarence modification. Kits are expensive, just buy the belting material at Farm supply type stores
/ Snow blower purchase #39
I have a honda hs1332. this is the only machine that requires 0 effort, except for slight hand strain. my mother is 78, and uses it. every single wheel machine needs to be man handles from time to time.
/ Snow blower purchase #40
If you are trying to stop throwing gravel with a snowblower take a look at ArmorSkids at snowblowerskids.com. They really do a great job of clearing my long pea stone drive without throwing the stones all over the place.
I think you can order them now from Home Depot online as well.
2021 DITCH WITCH HX30 TOWABLE VACUUM TRAILER (A63276)
2021 DITCH WITCH...
(APPROX. 85) 1X6X11 ROUGH SAWN PINE (A64276)
(APPROX. 85)...
2019 KUBOTA KX033-4 EXCAVATOR (A60429)
2019 KUBOTA...
2015 International ProStar T/A Day Cab Truck Tractor (A61573)
2015 International...
Harrell PT 6 Row Stalk Chopper (A64119)
Harrell PT 6 Row...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A61572)
2025 Kivel 48in...
