Must Tractor ROPS Be So High?
/ Must Tractor ROPS Be So High? #61
My Kubota barely clears...but that's good enough. However, I can rock it back about 30 degrees, and pin it there. It drops it by nearly a foot.
/ Must Tractor ROPS Be So High? #62
I would not cut the original one down, if you have the ability built a custom one then you can just replace the original if you want or need to sell the tractor. Just keep in mind that you are sacrificing some of the safety designed for the tractor make sure you know what you are doing
That is what I did on all of mine.
/ Must Tractor ROPS Be So High? #63
One consideration in buying a CUT is where you're going to store it. There are lots of stories where owners ran into the siding over the garage door. A foldable ROPS works until you forget to fold it down.
So my question is, Could CUT manufacturers design a ROPS that is more garage friendly? (Must they be so tall?)
The ROPS on my 1025R fits in my shop with no problem. The only time the ROPS on my 3046R is up is when it's in the way of using the back hoe.
/ Must Tractor ROPS Be So High? #64
If I was concerned about doing damage to the garage, I would mount a piece of PVC pipe as you see at a drive-thru.
I would set it so it hit me in the head just to make sure I noticed it. :D
The PVC pipe works but I prefer to use a tennis ball. It's easier on the forehead. :)
I attach the ball to a piece of string that I tie to the lower inside door handle. The ball is just a reminder for me to check the clearance of the tractor and any implements I have installed.
/ Must Tractor ROPS Be So High? #65
When fully raised, my ROPS will barely squeak under my garage door. But backing out, it will pucker the bottom lip of the door.
These photos show my ROPS in the second position. Does this look safe to you? It doesn't feel nearly safe to me. But if it's not as safe as fully raised, it makes me wonder why Kubota made that setting available.
For doing what you are doing. It’s meant to be fully raised while in use.
/ Must Tractor ROPS Be So High? #66
That was exactly my thought when my JD 790 wouldnt fit in my new garage after I finished it. But then you'ld hit your head every time you stood up and there would be issue on that, and some of the taller people would not be able to use tractors LOL...
/ Must Tractor ROPS Be So High? #67
Got mine at the 45 degree position now. Clears door and should be good enough for ROPS.
JDs didn't have this 45 degree position.
/ Must Tractor ROPS Be So High? #68
Do as you please but for others who want to know, the down position is to clear doors. It isn't an option for some other level of protection.
Not judging you or telling you what to do but rather providing context for those who follow and might think that down is approved by the manufacturer.
/ Must Tractor ROPS Be So High? #69
A folded ROPS is no longer a ROPS.
/ Must Tractor ROPS Be So High? #70
If they want us to use them, make them low enough to clear normal garage doors.
/ Must Tractor ROPS Be So High? #71
Thats why I love a foldable. Really requires minimal effort, once out, once going back in.
/ Must Tractor ROPS Be So High? #72
I work with the tractor a lot around low hanging tree limbs that are a problem to fully raised ROPS. Just not practical to keep up fully.
/ Must Tractor ROPS Be So High? #73
n
Ok, it has been said many times in this thread so you be the engineer and decide how you want your tractor modified.
Here are the choices:
lower the ground clearance
lower the seat
make humans shorter
shorten ROPS that fails tests to protect the operator
make hitch pins so ROPS fits under doorways
Just what would you choose?
/ Must Tractor ROPS Be So High? #75
Around 2018 or 2019, I started seeing new tractors being sold with a gas spring assist for the ROPS so I assume it became mandatory for the tractor manufacturers to add a gas spring assist to lift and lower the ROPS here in Europe. I've never really dug much into that. Anyways, the idea was to hopefully make people lifting their ROPS when height is not an issue since there have been so much deathly accidents due to roll overs.
This mostly done on the mid mounted ROPS, since it's a lot more mass to move. I have yet too see the same gas spring assist on rear mounted ROPS though.
In todays world, tractor manufacturers really should just include a gas spring on all types of foldable ROPS. It won't cost them a fortune and I'm sure they have plenty of profit margin.
Here is a picture illustrating what I'm saying. Note the gas spring attached to the ROPS post. From what I've seen, when lifting the ROPS, once it goes over 50-ish degrees, it will pretty much lift itself all the way. Before the 50 degrees, it's still an effortless lift that can easily be done with just one arm.
/ Must Tractor ROPS Be So High? #76
View attachment 731931 View attachment 731932
Psssttt,,,, your ROPS is in the wrong location.... :D
This is truly the first time I've saw a ROPS in that location.
Thanks for posting this Pedro!!!! :cool:
/ Must Tractor ROPS Be So High? #77
First time seeing that too. Does the ROPS need to be upright to open the hood?
/ Must Tractor ROPS Be So High? #80
Yeah, lowering cuts down some on the double whack in the head from small limbs. Also the wheelies when passing under a big limb. I tweaked my ROPS early on with a big pecan limb near the tree trunk.
Swict 66in Bucket Skid Steer Attachment (A64553)
Swict 66in Bucket...
2022 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A64556)
2022 Peterbilt 567...
UWS TBS-69 Truck Bed Tool Box (A64556)
UWS TBS-69 Truck...
1995 Ford LT9000 Tri-Axle Dump Truck (A64556)
1995 Ford LT9000...
2017 Volvo VNL T/A Sleeper Cab Truck Tractor (A64556)
2017 Volvo VNL T/A...
2023 Takeuchi TL6R Compact Track Loader Skid Steer w Low Hours (A63689)
2023 Takeuchi TL6R...
