nisaacs
- Joined
- Mar 9, 2020
- Messages
- 850
- Location
- Snowflake, Arizona
- Tractor
- 970 John Deere 4x2, 970 John Deere 4x4, 4320 John Deere, 995 Case/IH
Minimum truck I require is a 1 ton.
I would never buy a Dodge 1500 or 2500 for that matter. Dodge went to inboard mounted coils on those trucks and coils are about ride quality, not cargo. Coils belong on a Impala, not a truck. If I was to ever buy a Dodge, would have to be a 1 ton with leaf springs put back and a Cummins diesel under the hood.
Other than rear suspension, there is virtually no difference between a new 2500 and a SO 3500 srw. Show me what you tow that my 2500 wont.
Coil springs are awesome. The ride is unreal and if you tow with a gooseneck ball, they are as stable (or more so) as any 1 ton. Think about it. 5 link is great. Just like traction bars only better. No axle wrap to cause drive line buck/misalignment. Track bar controls any sway you might encounter with axle/frame side movement, there is none. Then when you add air bags outboard of the frame, now you have support on both sides of the frame. What's not to like?
Then to top it off, the shocks are wide spaced because the frame is so wide. No leaf springs in the way. The shocks also both have a forward angle, so the resistance does not rock the axle like one mounted forward and one rearward.
A heavy overhead camper, not so much, but that is not what my truck is for.
I tow my dump trailer 20k miles per year, mostly off highway @ 26k+ gcw. It works for me.
