What creates "bad diesel" fuel ?
/ What creates "bad diesel" fuel ? #61
What creates "bad diesel" fuel ?​
Fuel age and condensation.
I never use red off-road diesel, which for me would be from a Citgo station.
I pay more for fully taxed highway diesel from the busy Chevron.
I buy only nine gallons are a time. I almost empty the tractor tank before adding fresh diesel. Not a good idea to add fresh fuel to old fuel when the tractor tank is half full.
Fresh fuel is the bottom line.
Absolutely no difference between marked/dyed "off road" diesel and unmarked "on road" diesel...other than the colour and road taxes paid there are none at all
/ What creates "bad diesel" fuel ? #62
I was the laboratory manager for a small refinery in Kern County, CA for a number of years. Let’s clarify some things first. Each and every sales tank at any refinery in the US has an accompanimg signed data sheet showing that the product has passed the required ASTM tests for that product. Red diesel is just diesel colored red for road tax determination purposes.
The second point I would like to make is that diesel is a “wet” fuel, it’s a fraction that contains water. Being a wet fuel means that measures need to be taken to keep it dry, as it is when it leaves the refinery, microorganisms love wet fuels. This includes algae and bacteria.
My third point is that to your surprise there are two sources of diesel, paraffinic and asphaltenic. Paraffin based crudes produce a yellow sweet smelling high cetane fuel but with a rather high pour point grade #2 And #1 grade which has a much lower pour point. Asphaltene based crudes are cracked to make a product that resembles root beer color and has a bad odor. They are low cetane and have to be chemically boosted.
The third concern is sulfur which is now being reduced in diesel to 15 ppm and it promotes microbial growth and particulate formation.
So what are the issues with diesel fuel, paraffin (wax), asphalt - ugh and sulfur also an ugh and water. I would avoid dark asphaltenic diesel if at all possible. Number 2 diesel is great, when dry, but not in colder climates. Number 1 diesel is more highly refined a has a low pour point.
There is also a third diesel - marine diesel which is thick and waxy.
Depending upon the diesel you use choose the best additives if needed, keep your tanks full to avoid condensation, drain you water separators often, use #2 only in warm climates and use a fine filter screen when filling your tanks. If you do see or feel a scum if it light color and smells like diesel it is most likely wax but if it’s foul smelling it’s probably microbial.
/ What creates "bad diesel" fuel ? #63
New Holland Workmaster 50/60/70 owner’s manual advises keeping tank full, topping off as needed to prevent condensation. Just something to consider.
/ What creates "bad diesel" fuel ? #64
If your filter has black stuff in it, often tiny globules, it might be asphaltine 're-refining' in your engine. This happens when Diesel fuel is reheated, as in passing through the engine/injection pump and returned to the tank. The asphaltine is released and will then plug the filters on its second pass to the engine. Fleetguard makes an asphaltine conditioner that I run in my tractors (Case MB-4/94 Unimogs) when needed. Even from the same source, not all Diesel does that.
Forestgrump, bet you can expound on this!
/ What creates "bad diesel" fuel ? #65
I completely agree with you. Even with relatively fresh fuel that condensation is your fuel's enemy.
Here is an interesting link regarding the question does diesel go bad; well it does.
/ What creates "bad diesel" fuel ? #66
I have had my little B7300 now for 22 years, and I have never had a fuel problem. I purchase off road diesel 15 gallons at a time from a local fuel dealer who delivers gas/diesel/kerosene/heating fuel to homes/farms/contractors/businesses. However, a neighbor had a small JD CUT that he constantly had fuel problems with. He never really talked about it much to me, but did complain to other people. After a few years, I began to ask around, and found what might have been his problem. It turned out that he was siphoning heating fuel from his home heating oil tank and used that for his tractor fuel. His reasoning was it was cheaper and was sold and delivered as 'dyed diesel fuel", (which they no longer do). I surmised that his home heating fuel tank had some really bad stuff going on inside, besides water, and that might have been his issue. As a side note, he has been buying his home heating fuel from the same dealer that I do for years,
I agree with storage issues mentioned earlier. Buying from reputable, high volume dealers will avoid a lot of problems down the road. I also think that buying in excess, if not justified, may also be asking for problems. Either on or off road diesel should not be an issue, if there is high turnover at the dealer.
/ What creates "bad diesel" fuel ? #67
I have a JD 4010 sub compact purchased in 2007 with 500 hours. It has the original filter and so far I have never had a fuel problem! I purchase my red diesel fuel from a farm supply location in Southern Illinois. I plan on maintenance this spring and changing the filter is on the list along with all the fluids.
/ What creates "bad diesel" fuel ? #68
I tried off-road diesel once. $.30 less per gallon. Tractor didn't like it and I think it was water contaminated. The filter replacement that year was interesting, usually it's clear and clean with road diesel. I'm only buying 5 gal at a time in my scut so $1.50 extra per fill-up is cheap insurance for smooth running
/ What creates "bad diesel" fuel ? #69
Trouble was with a brand new Polaris diesel. D3aler put new engine and the customer sold it and bought gas model.
Biodiesel cleans fuel systems more vigorously than petroleum diesel. It is normal for new biodiesel users to have to change a fuel filter or two as their tractors or vehicles are cleaned up.
/ What creates "bad diesel" fuel ? #70
One time when I decided to try some off road diesel was when I had some wax globs come out of solution. Had to syphon the tank and then use a 3 finger tool to fish out the globs that were mostly plugging the outlet from the tank.
Sounds like the fuel was not dewaxed at the refinery. They are supposed to do that even before hydrocracking.
/ What creates "bad diesel" fuel ? #71
It may be that the off road pump does not have as much turnover as the normal pump, resulting in more water, etc.
/ What creates "bad diesel" fuel ? #72
One bulk plant here was selling bio diesel and not telling anyone. The buyers had problems and couldn't figure out why. Once the customers figured the plant out, they bought somewhere else and problems went away.
Odd. Biodiesel is more expensive than petro diesel.
/ What creates "bad diesel" fuel ? #73
May I ask why?
I've always had the thought (and therefore practice) of filling my tanks when I'm done for the day, this way I:
1. Always start the next time with a full tank of fuel
2. Keep tank full, most of the air out.
3. When I fill the tanks on the machine, they're full. I can now go to the co-op and replace them giving me a full compliment of fuel for whatever is ahead of me. (I really hate running out of fuel, going to Co-op for 40 gallons, fill tractor, go BACK to Co-op and get another 40 gallons, put 20-30 into my backhoe, go BACK to the Co-op and finally get things topped off.
I much rather try to stay ahead of that game and keep machines full AND my 5-gallon tanks.
Note, if it matters, I've got metal/steel fuel tanks on tractor and backhoe. My understanding is if you get things warm, put it away, as they cool down they can draw in moisture from outdoors and this can condense inside the tank, giving you the very issues you are trying to avoid.
Not saying this is right, just what I've read.... so what's the other point of view of leaving the tank at x% of full when your done?
/ What creates "bad diesel" fuel ? #74
Are you trying to say avoid red dye diesel in cold climate ??
/ What creates "bad diesel" fuel ? #75
Several years ago I experienced a summer of "frequent" fuel filter changes. On the T1530 NH that I cut several fields with I had to change the filter often. The machine would just not maintain power & speed. After the filter change it would immediately be back to spec.
I was buying my diesel at the same location that year and when I finally decided that my filter issues were caused by the fuel I was using I changed to another source ................. and the issues went away. I've only changed the filter once in the last two years and the symptom is the rpm drop & power loss.
I'm suspicious that something in the fuel "coats" the filter. Anyone else have similar problems ?
Diesel fuel does not go bad like gas can. I have used diesel fuel that is 30+ years old without issue. However - Kerosene based fuels like diesel and jet fuels (wide cut fuels that include Kerosene) can be up to 7% entrained water. This gives bacteria the opportunity to grow and multiply in your tank or your suppliers tank. Warm summer days can help the bacteria to propagate. A product like BIOBOR JF should fix the problem. If you have a supplier selling you contaminated fuel they need to know as they may need to treat their tanks also.
/ What creates "bad diesel" fuel ? #76
Probably not hydrodewaxed, just solvent dewaxed, and the pour point depressant didn't work on the hydrocracked stuff.
Sorry. Didn't think. Don't think any diesel is solvent dewaxed. Their pour point depressant just didn't work.
/ What creates "bad diesel" fuel ? #77
Algae. Today's low sulphur fuel allows algae to form. So not only do you have to pay way high prices for this Gasoline by-product because they have to reduce the sulphur, BUT you have the added expense of putting a Biocide in the fuel tank.
/ What creates "bad diesel" fuel ? #78
This is typical. Your problem was fuel quality, not color of the fuel.
/ What creates "bad diesel" fuel ? #79
This is gonna sound dumb to you if you worked at a refinery. But here goes any way. "There is a third diesel ,marine diesel, which is thick and waxy". Is this third fuel also known as bunker fuel?
/ What creates "bad diesel" fuel ? #80
My nephew uses at least 500 gallons weekly, off highway of course, with no problem. I don’t have on site storage for my smaller usage so it’s off to town. The 2 places that sell off highway don’t move their fuel fast enough and I go through one water block filter every 200 gallons if I buy off highway. And water separators are 90% efficient so 10% still gets into my equipment. So I buy on highway from the station that moves more fuel and replace my water block filters once yearly. The only off highway I use anymore is from my nephew. I have talked to the station owners who admit they have problems but say they can’t afford to fix - meaning holes in underground storage. I don’t understand why they continue to sell if they know their fuel is contaminated but it’s their business.
UWS TBS-69 Truck Bed Tool Box (A64556)
UWS TBS-69 Truck...
2006 Snorkel AB50J 50ft 4x4 Articulating Boom Lift (A64553)
2006 Snorkel AB50J...
2014 GULF STREAM TRAILMASTER (A65643)
2014 GULF STREAM...
(2) INTERNATIONAL FERTILIZER DISTRIBUTORS (A64278)
(2) INTERNATIONAL...
2007 Western Star 4900 SA Tri-Axle Wet Kit Day Cab Truck Tractor (A61573)
2007 Western Star...
2019 East Manufacturing 48ft. T/A Walking Floor Trailer (A64556)
2019 East...
