What creates "bad diesel" fuel ?
/ What creates "bad diesel" fuel ? #1
SARG
Upstate New York
NH T1030- NH T1530 - 49G Brockway
Several years ago I experienced a summer of "frequent" fuel filter changes. On the T1530 NH that I cut several fields with I had to change the filter often. The machine would just not maintain power & speed. After the filter change it would immediately be back to spec.
I was buying my diesel at the same location that year and when I finally decided that my filter issues were caused by the fuel I was using I changed to another source ................. and the issues went away. I've only changed the filter once in the last two years and the symptom is the rpm drop & power loss.
I'm suspicious that something in the fuel "coats" the filter. Anyone else have similar problems ?
/ What creates "bad diesel" fuel ? #2
One time when I decided to try some off road diesel was when I had some wax globs come out of solution. Had to syphon the tank and then use a 3 finger tool to fish out the globs that were mostly plugging the outlet from the tank.
/ What creates "bad diesel" fuel ? #4
I know of what you speak, a few years ago my neighbor said I should get my fuel at the local co-op to avoid the road taxes so I gave it a shot. Worst fuel I have ever had the misfortune of putting in my Deere. Went back to buying fuel where I had been and troubles went away. I think it had to do with the turn over, where I normally purchase fuel is the same place many of the local truckers use.
/ What creates "bad diesel" fuel ? #5
What creates "bad diesel" fuel ?​
Fuel age and condensation.
I never use red off-road diesel, which for me would be from a Citgo station.
I pay more for fully taxed highway diesel from the busy Chevron.
I buy only nine gallons are a time. I almost empty the tractor tank before adding fresh diesel. Not a good idea to add fresh fuel to old fuel when the tractor tank is half full.
Fresh fuel is the bottom line.
I agree with the "turnover" thought ........ the place I changed to sold much more diesel than the prior.
/ What creates "bad diesel" fuel ? #7
I contribute your issue, as well as the others posted, to old fuel, caused by limited sales at the vendor.
Let's not "cloud" (pun intended) this issue with red fuel versus clear fuel. This problem could be found in either.
I use the same vendor 99% of the time. Most of the local farmers use it also. Large volume of red/clear fuel. No issues at all.
/ What creates "bad diesel" fuel ? #8
One bulk plant here was selling bio diesel and not telling anyone. The buyers had problems and couldn't figure out why. Once the customers figured the plant out, they bought somewhere else and problems went away.
/ What creates "bad diesel" fuel ? #9
I have a Mack truck here and have been running it lately. Bought it ten years ago but haven't needed it. Fuel was 5 years old 10 years ago. We got it to put a log loader on the back of it, but the other truck kept going longer than we thought. It still cranks and runs fine. We had to put a front bumper on it with a fold up leg that holds the boom of the loader up as it goes past the front bumper at rest. Then we have to be able to fold it down to tilt hood.
/ What creates "bad diesel" fuel ? #10
I've been custom farming since 1987. I've added newly acquired diesel to fuel that's been in tractor tank for months. I've very rarely had a fuel condition problem.
/ What creates "bad diesel" fuel ? #11
I don't relate fuel problems with the specific age of the fuel. I relate it to contamination during storage, hauling, transfer.
Imagine an above ground storage tank that's half full or near empty. Imagine it sits that way for long periods of time. Right now our air temp is 10F, bright sunshine. What's going on inside that tank as the Sun heats it? Maybe that tank is never full. Maybe it does this process every single day. Would the old fuel that's there tend to get contaminated? Then imagine the contaminates that are added whenever more fuel is added? Pretty soon there are "new lifeforms" starting in there. We already know algae thrives in Diesel Fuel.
/ What creates "bad diesel" fuel ? #12
I've never had a problem either. When parking my tractors for any length of time I top off the tank to reduce condensation caused by our large temp swings here.
My Brother got algae in his storage tank several years ago. It was horrific. Contaminated all of his equipment before he admitted that was the problem. He kept blaming the fuel he bought. I kept telling him it was his storage. Me being the "Little Brother", he didn't listen. By Fall every diesel he owned was having problems.
One time of algae and you'll become a convert to fuel management. Same goes for gelling. One time. That's all it takes. :)
/ What creates "bad diesel" fuel ? #13
If a sufficient amount of water gets into the tank, bacteria and fungi can proliferate in the water while using the diesel as a food source. Waste biproducts from the microbial activity form a sludge that will clog filters.
You’ve probably heard the phrase “keep your powder dry”. In tractor terms the phrase becomes “keep your fuel dry”.
/ What creates "bad diesel" fuel ? #14
Truck has been half full for 15 years. We havent done any running but just to crank and move it.
/ What creates "bad diesel" fuel ? #15
I add Biobor biocide when buying off-road Diesel fuel, run it through Goldenrod filter when filling up my tractor or mowers and have never had problems using even over 10 years old fuel.
It's nice to be able to buy a bunch when it's cheap.
I currently utilize Howes, Power Service & Lucas treatments with my "stored" 30 gallons of diesel for the winter months. Based on the posts here so far I shall continue.
/ What creates "bad diesel" fuel ? #17
Yep. Good friend of mine has an old Dump Truck the same way.
I can hang around friends who have a Cold and not get it either. But some day I will if I put myself in that position enough times.
So I'm conscious of how I handle and treat my fuel. I've never had algae issues. Gelled once.
  • Good Post
Reactions: JWR
/ What creates "bad diesel" fuel ? #18
Use on road diesel for my Powerstroke. Always buy fuel from a high volume station. Dont use the truck much but always try to run the tank out by winter and fill with new fuel and additives. Fuel filter has always been like new for over 20 years.
Use off road red plus additives for the tractor and excavator. Fill a tank and keep the tank out of the weather. Never a issue here either.
Just like everything..... Maintain it and it will serve you well.
/ What creates "bad diesel" fuel ? #19
I'm 52 and have only heard of the bio diesel problem. Never heard of anyone having algae problem. Though I have known for years that there is such a problem out there somewhere. We have a gravity tank here. Dealt with stored fuel all my life. Even have my grandpa's tank from when he used to operate a road grader. Never had fuel problems. Never changed a filter because I had to, only because it was that time of year.
/ What creates "bad diesel" fuel ? #20
I use off road fuel.I get it at 135 gallons at a time.
I run all fuel thru a Mr.Funnel and never have a problem but now I've said that I'm doomed.
(30) 3"x9' Steel Posts (A66408)
(30) 3"x9' Steel...
Lowe Pontoon Boat and Trailer (A65579)
Lowe Pontoon Boat...
2020 Chevrolet Traverse SUV (A64557)
2020 Chevrolet...
2017 CATERPILLAR 289D SKID STEER (A65053)
2017 CATERPILLAR...
2005 DRAGON END DUMP TRAILER (A65643)
2005 DRAGON END...
2025 KENWORTH T880 DUMP TRUCK (A63276)
2025 KENWORTH T880...
