Need advice on a larger chainsaw for an older guy.
/ Need advice on a larger chainsaw for an older guy. #221
Did you ever try a modded saw from your son in laws older brother? I know you're not buying a new saw, but you really should see the difference modding makes.
/ Need advice on a larger chainsaw for an older guy. #222
I know.
I tried all the logical gymnastics that I could to justify a bigger saw but in the end being a lazy Scottish tightwad prevailed.
But, one of these days I’ll sharpen the chain on the MS 271. Maybe that will help.
Sometimes you just need to screw the logistics and get what feels good. Cheap labor is fine too though.
I have not pursued that. I guess it seems like modding a MS 271 is kind of like modding a Ford Escape or a Nissan Sentra. However, I did watch a video that compared larger home-owner models and the MS 271 was the more powerful among the group.
I'll have to ask him and see what he says. Wonder what the chances are that he might mess it up? As far as I know he hasn't messed any of his up but so far he only mods larger pro saws.
Oh I know. I got the bug. And using my son-in-laws big saw was not as intimidating as I was expecting. But I've got time. We'll see how things go.
Continuing off topic, I have never minded splitting wood. Kind of enjoy it. Granted, I’ve never spent hours or days on end doing it but a morning or afternoon of splitting wood is fairly pleasant. Knotty, twisty stuff excluded…..of course.
/ Need advice on a larger chainsaw for an older guy. #226
I enjoy it also. I’ve been retired about 2 years now. I spent the first few months splitting wood. Maybe only an hour or two at a time. That’s the beauty of retirement, no schedule and work when and as long as you feel like it. Truth is you spend more time handling the wood than actually splitting it.
/ Need advice on a larger chainsaw for an older guy. #228
I hand split 6-8 cords a year for 25+ years and finally treated myself to an electric 16 ton wood splitter about 10 years ago
No loud racket, no fumes and no sweat!
And, yes there is way more wood handling than splitting.
Not having to split a lot of wood I have had the luxury of not needing a log splitter. In fact, I don’t use wedges or a maul. I use my axe. An old Plumb felling axe that was my dad’s. My son-in-law tells me it’s not good for the edge to use a felling axe that way. I don’t care. I’m fairly good at it (one of very few things I have any talent for) and I enjoy a strong blow and a split log.
/ Need advice on a larger chainsaw for an older guy. #230
I used to use wedges and/or a maul. While pretty minor I’ve had shoulder problems and splitting wood made it worse. IF the wood was straight grained, I could probably keep up with a hydraulic splitter. The problems is the twisted stuff. I was stubborn and would split that stuff also.
/ Need advice on a larger chainsaw for an older guy. #231
I used to split a lot of wood with wedges and maul as a character builder, according to my father. Now that I heat our home with wood, I have a splitter. There's no way I could keep up with the splitter with wedges and a maul for more than a few minutes, let alone an afternoon.
/ Need advice on a larger chainsaw for an older guy. #232
Same here, an 8 pound maul did me fine, even with my arm having a titanium rod in it from a mountain biking accident.
Now with the gas splitter, I can do the 20-30" rounds real easy.
Maul is only used in the woods if I don't feel like noodling the rounds to move them.
/ Need advice on a larger chainsaw for an older guy. #233
I've resolved to only cutting telephone pole-sized trees on our place. I can't handle the rounds very efficiently. Too much work. We have thousands of black locust trees (the ones without the huge thorns) that size and they work great.
However, I did take a large Oak this year from a friend as a favor (it fell on his neighbor's house, yikes!). The 16" rounds are probably close to 600# each, as my machine can lift 800# at the quick attach, and it was tipping the machine on it's nose. Had to rip the rounds in half in order to pick them up.
/ Need advice on a larger chainsaw for an older guy. #234
If you are deadlifting 300 lb chunks of wood onto the splitter I salute you. I quarter the big rounds.
If I can carry the log to my processing area with the tractor I lift each split five times before it goes into the stove. For my usual 2.5 cords of hardwood per winter that's something over 30 tons lifted.
/ Need advice on a larger chainsaw for an older guy. #235
I enjoy using a maul. Swinging an axe for too many years took a toll on my arms though. Now I use my splitter to get pieces more manageable to stack, then split to size as I bring the wood from shed to woodbox.
Update on full chisel chain. There is certainly a difference but it isn't much. Which means that a brand new full chisel performed only a little bit better than my old semi-chisel chains which were sharpened by me. :rolleyes: I also did not notice appreciably worse kickback tendencies either. Seems like a wash to me. Although, someone mentioned in this thread that the sharpening on new chains isn't always perfect so I'll give the new full chisel chain a diligent sharpening and see if that makes any difference.
/ Need advice on a larger chainsaw for an older guy. #237
Semi vs full chisel has only seemed a small difference to me as well. But when cutting larger wood it adds up.
/ Need advice on a larger chainsaw for an older guy. #238
There’s also two kind of chisel, round is slow, vibrates more, and is more for dirty uses. Then there’s square chisel when I said I sharpen a new chain it’s to make the chain cut like they should with my expectations of how I need that chain to act in the wood I’m falling. Semi chisel is a much slower cutting chain it’s not as efficient of a cutter design it works really well in a harvester application because it can take more abuse since it doesn’t have a single working corner.
/ Need advice on a larger chainsaw for an older guy. #239
I use a Stihl MS 362 with 20 inch bar and Pole saw HT 131. I am 80 years old and I use them regularly on our tree farm. I try to not extend the pole saw too much but other than that I don't have any problems operating them
/ Need advice on a larger chainsaw for an older guy. #240
As far as splitting goes -
I bought one of those 10 Ton Hydraulic Log Splitters from HF, my fireplace of use was in the walkout basement.
Used it sort of like a Nordic Track to exercise my arms while watching TV.
2017 V-LITE TRAVEL TRAILER (A60736)
2017 V-LITE TRAVEL...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2011 Toyota Camry Sedan (A56859)
2011 Toyota Camry...
2014 KENWORTH T370 QUINT/A  DUMP TRUCK (A59906)
2014 KENWORTH T370...
2021 ISUZU NPR (INOPERABLE) (A60736)
2021 ISUZU NPR...
2007 International 7400 T/A Altec D4050A T 50ft Insulated Digger Derrick Truck (A60352)
2007 International...
