Need advice on a larger chainsaw for an older guy.
   / Need advice on a larger chainsaw for an older guy. #231
I used to split a lot of wood with wedges and maul as a character builder, according to my father. Now that I heat our home with wood, I have a splitter. There's no way I could keep up with the splitter with wedges and a maul for more than a few minutes, let alone an afternoon.
   / Need advice on a larger chainsaw for an older guy. #232
Same here, an 8 pound maul did me fine, even with my arm having a titanium rod in it from a mountain biking accident.
Now with the gas splitter, I can do the 20-30" rounds real easy.
Maul is only used in the woods if I don't feel like noodling the rounds to move them.
   / Need advice on a larger chainsaw for an older guy. #233
I've resolved to only cutting telephone pole-sized trees on our place. I can't handle the rounds very efficiently. Too much work. We have thousands of black locust trees (the ones without the huge thorns) that size and they work great.
However, I did take a large Oak this year from a friend as a favor (it fell on his neighbor's house, yikes!). The 16" rounds are probably close to 600# each, as my machine can lift 800# at the quick attach, and it was tipping the machine on it's nose. Had to rip the rounds in half in order to pick them up.
   / Need advice on a larger chainsaw for an older guy. #234
If you are deadlifting 300 lb chunks of wood onto the splitter I salute you. I quarter the big rounds.
If I can carry the log to my processing area with the tractor I lift each split five times before it goes into the stove. For my usual 2.5 cords of hardwood per winter that's something over 30 tons lifted.
   / Need advice on a larger chainsaw for an older guy. #235
I enjoy using a maul. Swinging an axe for too many years took a toll on my arms though. Now I use my splitter to get pieces more manageable to stack, then split to size as I bring the wood from shed to woodbox.
Update on full chisel chain. There is certainly a difference but it isn't much. Which means that a brand new full chisel performed only a little bit better than my old semi-chisel chains which were sharpened by me. :rolleyes: I also did not notice appreciably worse kickback tendencies either. Seems like a wash to me. Although, someone mentioned in this thread that the sharpening on new chains isn't always perfect so I'll give the new full chisel chain a diligent sharpening and see if that makes any difference.
   / Need advice on a larger chainsaw for an older guy. #237
Semi vs full chisel has only seemed a small difference to me as well. But when cutting larger wood it adds up.
   / Need advice on a larger chainsaw for an older guy. #238
There’s also two kind of chisel, round is slow, vibrates more, and is more for dirty uses. Then there’s square chisel when I said I sharpen a new chain it’s to make the chain cut like they should with my expectations of how I need that chain to act in the wood I’m falling. Semi chisel is a much slower cutting chain it’s not as efficient of a cutter design it works really well in a harvester application because it can take more abuse since it doesn’t have a single working corner.
   / Need advice on a larger chainsaw for an older guy. #239
I use a Stihl MS 362 with 20 inch bar and Pole saw HT 131. I am 80 years old and I use them regularly on our tree farm. I try to not extend the pole saw too much but other than that I don't have any problems operating them
   / Need advice on a larger chainsaw for an older guy. #240
As far as splitting goes -
I bought one of those 10 Ton Hydraulic Log Splitters from HF, my fireplace of use was in the walkout basement.
Used it sort of like a Nordic Track to exercise my arms while watching TV.
HELI 5K FORKLIFT (A58216)
HELI 5K FORKLIFT...
2017 Ford F550 Bucket Truck - Powerstroke Diesel - Auto Trans - 4x4 - Versalift SST40 Boom (A55302)
2017 Ford F550...
2019 Ford F-350 (A55973)
2019 Ford F-350...
Computerized Wheel Balancer (New/Unused) (A59225)
Computerized Wheel...
2013 KENWORTH W900 TRIAXLE (A58214)
2013 KENWORTH W900...
INOP Kawasaki Bayou 250 Four Wheeler (A57453)
INOP Kawasaki...
