   / Share Pics of People Hauling or Towing Something Wrong #16,082
   / Share Pics of People Hauling or Towing Something Wrong #16,083
That's evil and genius
F150 is all wrong, that should really be a 1990s Explorer or the S10 type Blazer/Jimmy. They would roll over on their own if you just hurt their feelings.
   / Share Pics of People Hauling or Towing Something Wrong #16,084
It does in 49CFR571.121 S5.2.2 49 CFR § 571.121 - Standard No. 121; Air brake systems.
S5.2.2 Brake distribution and automatic adjustment. Each vehicle shall be equipped with a service brake system acting on all wheels.
Aaron Z
Not to take sides but that states "service brakes" not emergency (spring) brakes. Even service brakes weren't required on all axles until the 80s. Prior to that most class 8 trucks had no brakes on the front axle to avoid jackknifing.
   / Share Pics of People Hauling or Towing Something Wrong #16,085
Look at my last post where they say that all brakes are required to be applied automatically upon breakaway:
That is odd, Regulations Section says "Question 2: Are all brakes on a trailer required to be applied automatically upon breakaway? Guidance: Yes"
That would seem to imply that spring brake cans are required on both axles.
So if all axles are required to have brakes and all brakes on a trailer are required to be applied automatically upon breakaway, any trailer built after that requirement was enacted should have spring cans on all axles.
Aaron Z
   / Share Pics of People Hauling or Towing Something Wrong #16,086
Fair enough, and to that point I've never seen a trailer that didn't have spring brakes on every axle. Tractors however don't have spring brakes on tag and steering axles. I've never seen a drive axle without spring brakes though.
   / Share Pics of People Hauling or Towing Something Wrong #16,087
Cant disagree with that.
Aaron Z
   / Share Pics of People Hauling or Towing Something Wrong #16,088
None of our tandem axle tractors from the last several years have spring brakes on the front drive axle. The last 2 years with drum brakes and all of the disc bake units. I looked at them yesterday.
   / Share Pics of People Hauling or Towing Something Wrong #16,089
Same here. It’s almost guaranteed that a standard 5 axel semi will have 4 axels with spring brakes. Both drives and both trailer axels.
   / Share Pics of People Hauling or Towing Something Wrong #16,090
2022 Bobcat T66 (A53317)
2022 Bobcat T66...
2012 Freightliner M2 106 Altec TA37M 37ft Insulated Material Handling Bucket Truck (A60460)
2012 Freightliner...
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
2008 DOOSAN G25 GENERATOR (A58214)
2008 DOOSAN G25...
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
SET OF PALADIN JRB 60" PALLET FORKS (A52707)
SET OF PALADIN JRB...
