MHarryE
Elite Member
- Joined
- Feb 15, 2009
- Messages
- 2,982
- Location
- Northeastern Minnesota
- Tractor
- Kubota M7-171, M5-111, SVL75-2, RTV900XT & GR2120; CaseIH 1680 combine
From my engineering textbook, copyright 1952 but laws of physics haven’t changed. To maintain equilibrium, F, tractive force where tire meets ground times distance y1 must be less than weight at front tires W2 times distance x1. You tip backwards when W1 times y1 is greater than W2 times x1. Figure 14.8 shows what’s needed to calculate having drawbar pull not parallel to the ground, and also adding a slope. These free body diagrams should help illustrate things discussed here. Pulling from the 3 point raises or lowers distance y1. Usually there is enough weight at W2 to keep the system static but increase y1 too much and the front tires leave the ground.
