YM187D Project tractor
/ YM187D Project tractor #1
Johndeere3720
Padawan Tractor Learner, Advertiser
NW Oregon
Bobcat T650, MT55, E42R, E10, John Deere 4410, 4200, x500
It was bound to happen… listed my 226D for a stupid price thinking no one will ever buy it yet I still sold it. 🤷🏻‍♂️
Timing wise it worked out though since I was moving into my new shop and needed to free up some space while I got settled in. Now that everything is put away it was time for another project. I did post another thread about some Hyster forklifts I was messing with but now that I’m mostly done outfitting my shop forklift another Yanmar made its way to my shop.
This one came up on marketplace about an hour away. Having had a 186 and 226 I really wanted to see how a 187 compared, plus I have a lead on a 187 parts tractor that I’m hoping to pick up Saturday. Nonetheless I was busy with work and the seller offered to deliver this 187 to me so naturally I said yes. Upon initial inspection the rear brakes are sticking, the skirting and stance tells me it was most likely from a Christmas tree farm, and it even has factory Yanmar weights hanging off the front. It’s got the typical non-functioning wiring, broken hour meter cable, a seat that’s ready to fall off, and a broken dash bezel.
Last night I got a chance to take a better look at the tractor and pulled off the skirting and canopy. Upon inspection I found the rear axle stubs are cut and the front axle was narrowed. They also installed some 8-16 rear tires which I’m pretty sure are too small explaining why the tires are so worn. I also found that the ROPS are actually for a YM180 and that the fenders were cut to allow them to fit snugly around the ROPS.
Looking forward to getting this 187 back up to par.
/ YM187D Project tractor #3
Looks like it's had a hard life on that farm.
/ YM187D Project tractor #4
Looks like he laid it on it's side, broke off the ROPS, then welded it back on, then repeated that, breaking it again at the heat-affected area by his repair weld. That thing has had a hard life.
I thought the 180 and 187 were identical except transmission, so same ROPS.
My Yanmars look a little rough but that one is a least a match!
With the narrowing, you might be better off moving parts onto the salvage tractor. Or if you clean up this one, strengthen the ROPS and sell it as a Christmas tree farm special. That narrow, I expect it will flop over from time to time.
I wish I had a YM187D. My YM186D is too tiny in the operator area to climb on/off easily. YM186D is a wonderful tractor overall - except for that continual nuisance. The later YM187D with more operator space was a great design improvement.
Related question: Ernie then Raffi in Portland, both in your region, must have sold their remaining stuff to somebody near there. Do you have any idea who has Raffi's parts now?
Funny you mention that. Yesterday I took a trip 3 hours south for a parts tractor. When I got there I noticed a bar none sticker on it which means this was one of Raffi’s parts tractors that was auctioned off earlier this year. The parts tractor is missing quite a bit but I think I can make one out of the 2.
This was the real bummer.. The right side knuckle is from a different tractor and was held on by 1 bolt. My main concern came true upon removal when I seen that the axle shaft was also gone.. I can rob the knuckle from my narrowed axle but still need a shaft since the narrowed one will be too short. Anyone have an idea what the other knuckle would be for? It’s similar but the bolt pattern is different where it mounts to the housing. Also has a slightly smaller lug pattern.
Basically I’m planning on stripping down the narrow 187 to redo the wiring and black paint. While it’s apart I’m going to try and get the parts tractor running with borrowed parts. I’ll swap the normal width stuff onto the narrow tractor (axles/rear fenders/platform) and then likely part out the rest. I need to make a list of what the parts tractor is missing but if someone needs something specific for a 187D I’d hope I could help someone out.
@California wants that hood I bet!
I’d be more than happy to sell the hood. The main draw back is the holes behind the 187 emblem for who knows what. This tractor had a loader at one time which explains its rougher looks.
Another update!
Tonight I started taking some things off the parts tractor. Before I go too far I wanted to try and get it running so I robbed the starter, fuel filter housing, and injector lines off of my runner and put them on the parts tractor. Hooked up my remote starter box and bled fresh fuel up to the injection pump. Unfortunately I don’t have much lying around for battery cables so the starter wouldn’t perform as well as it should have but I found out quickly that the injection pump is not pumping fuel at all. Ran out of time at that point but am thinking about robbing the pump off of my running tractor as well as getting some battery cables made up so I can know for sure if this engine is good or not.
Please excuse the electrical mess in which I tried to start it with. Jumper cables were less than ideal.
/ YM187D Project tractor #9
Love your hand cleaner "instant electrical system"! You get so much done so quickly. It is very impressive. Thanks for sharing.
All the best,
Peter
/ YM187D Project tractor #10
You're on to me! (y)
I did, in fact, already look it over carefully. Then went out and looked at mine.
I see that hood is dinged up worse than mine. It looks like the lower perimeter of the mesh grill is pushed in some. And it isn't resolved whether it's the same length, since YM187 is longer overall.
Shipping cost would tip the balance toward just getting mine straightened by a good body shop. If I cared. I tell guests who comment on my 'well used' (I bought them in that condition) tractors - "well I was better looking 40 years ago too".:)
Here's a picture of my first YM186D (left, no loader) and the replacement I've had since 2013. (with loader & power steering). Straightening this hood would be simple for a pro tinpounder. The complexity of taking the cowl apart and painting everything - sheet metal and chassis - is more than I feel like doing. Everything works as intended which is really all I need. I did clean up and paint those wheels. And I am going to buy the headlight bezel - some day. I don't remember any other bodywork.
All the best,
Peter
For as simple as it is it sure is handy for engines that don’t have a functioning electrical system handy. I built it for a Duetz F2L410 2 cylinder air cooled engine that I had out of an M600D Bobcat that I got running last year. I wanted everything in a box basically so I spent an afternoon stuffing wires, old bobcat parts (switch and volt gauge) and relays into that old tub of towels until I got the end result.
No worries! It’s better than some but certainly far from perfect. I may try to fix some of its imperfections and see how the paint responds to some wax.
/ YM187D Project tractor #13
Love the photos. You have the best toys there!
I see YM187 is substantially different from YM186. YM187 3-point top link mount is bolted to the back of the transmission like the larger Yanmars. YM186 3-point top link mount is bolted only to the top of the transmission and is L shaped to get down to the top link pin holes. I welded a plate onto that mount - just behind the holes - so I could add bolts next to the PTO cover. That YM187 flatter floor is an improvement too.
The hydraulic pump on the parts tractor looks like it might be a replacement. Maybe you got lucky and its higher capacity.
Sounds like Raffi's salvage tractors went to auction and are now scattered all over the west coast. I bought the YM240 replacement right axle housing from him. Great guy, reasonable price.
It does have a lot more in common to the 226 I had vs the 186. My buddy was offered all of Raffi’s parts tractors but before he could say yes everything was sent off to auction.
Small update. Havent gotten too far on the 187D, ended up picking up a bunch of forklifts to fix up which has pretty much consumed my shop space. Will be back on the Yanmar once I get these forklifts fixed up.
/ YM187D Project tractor #16
Hey California, what happened to Raffi that he sold out, did he move out of town or just got tired of the tractors?
I saw him a few years ago and he was doing fine..
/ YM187D Project tractor #17
Last December I asked if he had internal parts for the 3-point lift on my YM186D. (thread about my repair).
He replied he could furnish the housing complete if I wanted that.
Mid-February 2021 I told him I completed the repair. It was only a broken rollpin. And asked him to tell me if he got in a YM187D.
His reply to me:
All my inventory has been sold and gone thanks. -Raffi
OP noted above (Post #5) that his YM187D is a Raffi tractor that went through Bar-None auction site. So maybe he can tell us more.
That's all I know.
Anybody know of another Yanmar etc salvage yard in the West?
And what are you up to now? Did you ever come back home to the Left Coast? :)
/ YM187D Project tractor #18
His reply to me:
That's all I know.
California,
I retired and farm part time, I still have a shop full of branson tractors to keep me entertained and busy.
We are done with the left coast, the 2020 fires came a 1/4 mile close to our home, + the idiots legalized pot, and we had enough of their politics.
The only thing I really miss is the deer hunting on my land, I use to harvest 200 lb + bucks every year and that's history.
The weather where I'm at is wonderful, its 80 degrees here and 29 back in Ore-gone. I must say that I still miss opening up those containers of yanmars and seeing all that red metal.
It was really hard selling my 5 yanmars, all those years of mounting loaders and care for them came to an end. I sold the FX335-D to a good friend, and he takes good care of it.
I still have the FX235-D with a full roll bar canopy and a finish mower on the back, I couldn't bring myself to sell it when we moved.
Life goes on.... ;)
Small update:
Found a set of turf tires off of another 187D yesterday and got them mounted up. Now the drivetrain won’t work against itself in 4wd, the rear tires that were on it were from a 165D.
2014 International WorkStar 7600 T/A 20ft Flatbed Truck (A61568)
2014 International...
2017 Ford F-250 Service Truck (A61568)
2017 Ford F-250...
UNUSED RAYTREE RMSG29 - 29" HYD STUMP GRINDER (A62131)
UNUSED RAYTREE...
2011 Jeep Grand Cherokee AWD SUV (A61569)
2011 Jeep Grand...
UNUSED MGY-50KW FUEL HEATER (A62131)
UNUSED MGY-50KW...
2000 Dodge Ram 1500 4x4 Ext. Cab Pickup Truck (A61568)
2000 Dodge Ram...
