Mounting tire chains
/ Mounting tire chains #102
Thanks LouNY for posting your pics to help us out with a new idea. I'm on my tenth year of mounting chains and have made notes to myself and am getting better at it. I use the jack method now and find it not so difficult or frustrating. My happiest experience is to mount the chains and then never have enough snow that season to get in it.:D
Cheers,
MikeView attachment 579293View attachment 579294
That's my method also.
I generally use a bungee cord to hold the chain as I manually rotate a wheel to wrap the chain on then clip the inner followed by the outer.
Due to minimal fender clearance I also need inner and outer binders.
LOL, this year my jack bit the dust so I had to use a bottle jack.
/ Mounting tire chains #104
Welcome, it took quite a few years for me to start doing this the directions came with one of my sets of chains 5-6 years ago.
I did one tire my way, then tried the way the directions said to, it surprised me to the first time.
I can't seem to visualize why you specify laying the chains out with the outside down.
/ Mounting tire chains #105
because when you pick them up to lay them on top of the tire, the part that was facing down on the ground will now be facing up on the tire.
/ Mounting tire chains #106
i just put the chains on the tractor today/... always a fun chore
/ Mounting tire chains #107
That would be especially important if they are V bar ice or studded chains as mine are.
Not so if plain links.
But then even the cross bar attachments should also have the open ends facing outwards as should they stretch and open they could puncture the tire. (I occasionally need to re close some of mine)
from post #1;
1) lay the chains out with the outside, the ground contact side facing up
2) tie a short cord to the side chains, the length will depend on your tire size, on mine I end up with a V shape about 3 feet.
3) back up to your chain, take the cord and hang it on the tire treads.
4) drive forward slowly, stopping to spread the chain out on your tire.
5) continue doing this till you have rolled the chain up on the tire and have working room at the rear of the tire
6) your chain should be well centered on your tire and have very little slack.
7) fasten your chains.
/ Mounting tire chains #109
This is how I put them on. Similar to driving them on, but I just roll the tire and chains come up out of the pail. Easy to center when you can roll tire too.
/ Mounting tire chains #110
Not far off from what I do.
But this year my jack quit (OH coming up) so I used a small bottle jack.
I also use 'bungee' cords to help hold as I roll the tire loading my studded chains.
But all is well now as we've experienced our 2nd snow event.
No sheered bolts, frozen ground, all good to go 'til next spring.
/ Mounting tire chains #111
I put mine on last week, now waiting to get to use the tractor. The atv has been cleaning up the few inches we've picked up.
/ Mounting tire chains #112
had 4" of snow today....no plans on doing anything with it. will get warmer later this week. high yesterday 22, today 28, wed its supposed to me 39/
/ Mounting tire chains #113
I first lift the wheels off of the ground and crib them. I then pull the Schrader valves out of the tires to deflate my tires (because the beet juice clogs the valves when they are merely cracked open and makes a mess). Once deflated, I then reinstall the valves back int the valve stems. I then puzzle out which way the forestry studs should go and then (ideally) have a buddy helping so that while one of us is using a chain binder to pull the chains together at the top of the tire, the other person is adjusting the chains draping on the sides that get caught on the tire lugs. The second person also supplies an extra set of hands to screw in the pins into the clevises that my chains use to hold the chains together.
After the chains are mounted, I install a spring-loaded tensioner to help keep the chains biased toward the outside of wheel, air the tires back up to 25psi, and finally drop the tractor back down onto the ground ready to go!
/ Mounting tire chains #115
I mounted chains all around yesterday, we have mostly slushy summers in Montana anymore. Wetsnow/rain/freeze/ice........I have a FEL plow, so steering gets light all the time. Figured it was time to chain up on all four.
Kalispell is so mild anymore. I think the last major winter the whole NW MT area has had was 1996-97 when I was in Libby. We left Kal 4yrs ago for a real wintery high elevation area south of Jackson WY and tooled up into a Kioti NX6010 to combat the constant wind drifting. But when we move back to MT it's questionable if I'll need that much tractor again.
/ Mounting tire chains #116
Yeah, they've had whinings about warnings of winterstorms of 1 - 2 feet over the passes, and it was never below 34F all weekend even at night. So I didn't get ANY snow.
/ Mounting tire chains #117
The first time I tried to plow snow with the 4105, I spun around a couple times, and ended up in the apple orchard,,
That resulted in a photogenic picture, but, no snow got plowed,,
The 4105 has a HST, and no steering brakes, without steering brakes, the tractor needs front chains in snow.
I happened to have a set of chains that came with a Mitsubishi MT372, from LONG ago.
Those chains dropped right on the front of the JD 4105.
No fighting, no jack is needed, simply lay the chain over the tire, and flip the lever on the outside hook.
Put the tensioner on, plow snow.
The 584 IH has not had snow duty since I figured out how to chain the front tires on the 4105,,
/ Mounting tire chains #118
For us smaller tractor guys (TC29D) I just jacked it up and turned tires by hand. Super easy for the size.
/ Mounting tire chains #119
They had a fema warning posted for our area to expect 10-20” of snow. We got 4” then 40°. Now lots of slop.
/ Mounting tire chains #120
Your rear blade looks like it would leak live a sieve! 🥴
…but many people’s driveways probably should be screened for “surprises” before a snowblower finds them.
CATERPILLAR D6N LGP HI-TRACK CRAWLER DOZER (A65053)
CATERPILLAR D6N...
2000 STERLING T/A DAY CAB ROAD TRACTOR (A64278)
2000 STERLING T/A...
(APPROX. 450')LOT OF LATCH LOCK 6" IRRIGATION PIPE (A64278)
(APPROX. 450')LOT...
2022 JOHN DEERE 333G SKID STEER (A65053)
2022 JOHN DEERE...
2013 Mack CXU613 T/A Day Cab Truck Tractor (A64556)
2013 Mack CXU613...
2019 Cadillac XTS Stretch Limousine for Sale, S and S Coachbuilders, 70IN, 7731 Miles (A63689)
2019 Cadillac XTS...
